Black screen at boot and no shell after reboot and chroot problems
I am not entirely sure if it’s my relatively old computer but it became black screen after reboot and update using pamac.
It doesn’t go to Grub bootloader ever since first installation so can’t select old kernels.
There is no terminal showing even if I used Ctrl+Alt+F2/F3/F4/F5 or F6
Tried using live disc and via chroot but I am not sure if they are correct as there are errors showing which I have to change the command. For example, I have to change it to /mnt/@ among others.
As far as I checked, the sda drive is
sda1 - root
sda2 - /home/
sda3 - efi? boot? (I don’t remember exactly but I think I’m leaning more it’s boot as it’s 100MB)
Any help will be appreciated.
Edit: Here’s what I try to do with manjaro-chroot:
[manjaro@manjaro ~]$ su
[manjaro manjaro]# mount /dev/sda1 /mnt
[manjaro manjaro]# mount /dev/sda3 /mnt/boot
mount: /mnt/boot: mount point does not exist.
[manjaro manjaro]# mount /dev/sda3 /mnt/@/boot
[manjaro manjaro]# manjaro-chroot /mnt /bin/bash
mount: /mnt/proc: mount point does not exist.
==> ERROR: failed to setup API filesystems in chroot /mnt
umount: bad usage
Try 'umount --help' for more information.
[manjaro manjaro]# manjaro-chroot /mnt/@ /bin/bash
[manjaro /]#
Hello @ota-coder :wink:
Please post also your system summary:
inxi -Fazy
Could be possible it is related to the nvidia renaming. Because the nvidia driver is now a rolling release here.
for x in $(ls /etc/X11/xorg.conf.d/); do echo -e "---$x---\n\n $(cat /etc/X11/xorg.conf.d/$x)\n\n"; done
for x in $(ls /var/log/ | grep Xorg); do echo -e "---$x---\n\n $(cat /var/log/$x)\n"; done
Thank you for the response @megavolt
Anyway, I actually removed the nvidia driver before you responded and I can finally was able to login.
I am now facing a different problem now as is no internet and cannot detect wired connection or it’s intermittent - which is already offtopic. Will just research how to fix this.
Thanks again!
Hi @megavolt - as I Timeshifted and back to the original black screen (can’t get the wired ethernet to work at all), I decided to get back to the original problem. Anyway, here are the outputs:
[manjaro@manjaro ~]$ inxi -Fazy
  Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
  misobasedir=manjaro misolabel=MANJARO_KDE_202 quiet systemd.show_status=1
  apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
  radeon.modeset=1
  Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Desktop Mobo: MSI model: Z97 PC Mate(MS-7850) v: 1.0 serial: <filter>
  UEFI: American Megatrends v: 4.6 date: 11/07/2014
  Info: Quad Core model: Intel Core i7-4790K bits: 64 type: MT MCP
  arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28
  L2 cache: 8192 KiB
  bogomips: 64026
  Speed: 4401 MHz min/max: 800/4400 MHz Core speeds (MHz): 1: 901 2: 900
  3: 900 4: 900 5: 901 6: 901 7: 900 8: 901
  Type: l1tf
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics
  vendor: Micro-Star MSI driver: i915 v: kernel bus ID: 00:02.0
  chip ID: 8086:0412
  Device-2: NVIDIA GK104 [GeForce GTX 760] vendor: eVga.com. driver: nouveau
  v: kernel bus ID: 01:00.0 chip ID: 10de:1187
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
  driver: intel,nouveau unloaded: modesetting alternate: fbdev,nv,vesa
  display ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x285mm (40.0x11.2")
  s-diag: 1055mm (41.5")
  Monitor-1: DVI-I-1 res: 1920x1080 hz: 60 dpi: 96
  size: 509x286mm (20.0x11.3") diag: 584mm (23")
  Monitor-2: HDMI-3 res: 1920x1080 hz: 60 dpi: 82 size: 598x336mm (23.5x13.2")
  diag: 686mm (27")
  OpenGL: renderer: NVE4 v: 4.3 Mesa 20.2.3 direct render: Yes
  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio
  vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:03.0
  chip ID: 8086:0c0c
  Device-2: Intel 9 Series Family HD Audio vendor: Micro-Star MSI
  driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:8ca0
  Device-3: NVIDIA GK104 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
  v: kernel bus ID: 01:00.1 chip ID: 10de:0e0a
  Sound Server: ALSA v: k5.9.11-3-MANJARO
  vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus ID: 03:00.0
  chip ID: 10ec:8168
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 14.56 TiB used: 53.79 GiB (0.4%)
  ID-1: /dev/sda vendor: Western Digital model: WD40EZRZ-00GXCB0
  size: 3.64 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 5400 rpm serial: <filter> rev: 0A80 scheme: GPT
  ID-2: /dev/sdb vendor: Western Digital model: WD40EZRZ-00GXCB0
  ID-3: /dev/sdc vendor: Western Digital model: WD20EARS-00S8B1 size: 1.82 TiB
  block size: physical: 512 B logical: 512 B speed: 3.0 Gb/s serial: <filter>
  rev: 0A80 scheme: MBR
  ID-4: /dev/sdd vendor: Western Digital model: WD30EZRX-00D8PB0
  size: 2.73 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  ID-5: /dev/sde vendor: Western Digital model: WD10EZEX-08WN4A0
  size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: 1A01 scheme: GPT
  ID-6: /dev/sdf vendor: Western Digital model: WD20EARX-00PASB0
  size: 1.82 TiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
  serial: <filter> rev: AB51 scheme: MBR
  ID-7: /dev/sdg type: USB vendor: Imation model: Nano Pro size: 7.21 GiB
  block size: physical: 512 B logical: 512 B serial: <filter> rev: PMAP
  scheme: MBR
  ID-1: / raw size: N/A size: 11.32 GiB used: 208.3 MiB (1.8%) fs: overlay
  source: ERR-102
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 40.0 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 1140
  Processes: 253 Uptime: 9m Memory: 15.09 GiB used: 1.23 GiB (8.1%)
  Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1224 lib: 332
  flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.08
Inside chroot:
[manjaro /]# for x in $(ls /etc/X11/xorg.conf.d/); do echo -e "---$x---\n\n $(cat /etc/X11/xorg.conf.d/$x)\n\n"; done
---00-keyboard.conf---
 # Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
        Identifier "system-keyboard"
        MatchIsKeyboard "on"
        Option "XkbLayout" "ph"
        Option "XkbModel" "pc105"
EndSection
---30-touchpad.conf---
    Identifier "touchpad"
    Driver "libinput"
    MatchIsTouchpad "on"
    Option "Tapping" "on"
EndSection
---90-mhwd.conf---
 # nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 440.82
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
        Option "NoLogo" "1"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
[manjaro /]# for x in $(ls /var/log/ | grep Xorg); do echo -e "---$x---\n\n $(cat /var/log/$x)\n"; done
---Xorg.0.log---
 [   101.554] (--) Log file renamed from "/var/log/Xorg.pid-1215.log" to "/var/log/Xorg.0.log"
[   101.554]
X.Org X Server 1.20.10
[   101.554] Build Operating System: Linux Manjaro Linux
[   101.554] Current Operating System: Linux ayumin 5.9.11-3-MANJARO #1 SMP PREEMPT Sat Nov 28 09:08:57 UTC 2020 x86_64
[   101.554] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.9-x86_64 root=UUID=653c7d91-a061-40ba-9c64-e4fd20a57d39 rw rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3
[   101.554] Build Date: 03 December 2020  08:59:12AM
[   101.554]
[   101.554] Current version of pixman: 0.40.0
[   101.554]    Before reporting problems, check http://wiki.x.org
[   101.554] Markers: (--) probed, (**) from config file, (==) default setting,
[   101.554] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Dec 24 16:47:42 2020
[   101.555] (==) Using config directory: "/etc/X11/xorg.conf.d"
[   101.555] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   101.555] (==) ServerLayout "layout"
[   101.555] (**) |-->Screen "Screen0" (0)
[   101.555] (**) |   |-->Monitor "Monitor0"
[   101.555] (**) |   |-->Device "Device0"
[   101.555] (==) Automatically adding devices
[   101.555] (==) Automatically enabling devices
[   101.555] (==) Automatically adding GPU devices
[   101.555] (==) Automatically binding GPU devices
[   101.555] (==) Max clients allowed: 256, resource mask: 0x1fffff
[   101.555] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[   101.555]    Entry deleted from font path.
[   101.555] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[   101.555] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[   101.555]    (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[   101.555] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[   101.555]    (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[   101.555] (==) FontPath set to:
        /usr/share/fonts/misc,
        /usr/share/fonts/TTF
[   101.555] (==) ModulePath set to "/usr/lib/xorg/modules"
[   101.555] (**) Extension "COMPOSITE" is enabled
[   101.555] (II) The server relies on udev to provide the list of input devices.
[   101.555] (II) Module ABI versions:
[   101.555]    X.Org ANSI C Emulation: 0.4
[   101.555]    X.Org Video Driver: 24.1
[   101.555]    X.Org XInput driver : 24.1
[   101.555]    X.Org Server Extension : 10.0
[   101.555] (++) using VT number 1
[   101.556] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[   101.556] (II) xfree86: Adding drm device (/dev/dri/card0)
[   101.557] (--) PCI: (0@0:2:0) 8086:0412:1462:7850 rev 6, Mem @ 0xf7400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64
[   101.557] (--) PCI:*(1@0:0:0) 10de:1187:3842:3768 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/134217728, 0xe8000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[   101.557] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[   101.557] (II) LoadModule: "glx"
[   101.558] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   101.558] (II) Module glx: vendor="X.Org Foundation"
[   101.558]    compiled for 1.20.10, module version = 1.0.0
[   101.558]    ABI class: X.Org Server Extension, version 10.0
[   101.558] (II) LoadModule: "nvidia"
[   101.558] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[   101.559] (II) Module nvidia: vendor="NVIDIA Corporation"
[   101.559]    compiled for 1.6.99.901, module version = 1.0.0
[   101.559]    Module class: X.Org Video Driver
[   101.559] (II) NVIDIA dlloader X Driver  440.100  Fri May 29 08:21:27 UTC 2020
[   101.559] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[   101.559] (II) Loading sub module "fb"
[   101.559] (II) LoadModule: "fb"
[   101.559] (II) Loading /usr/lib/xorg/modules/libfb.so
[   101.559] (II) Module fb: vendor="X.Org Foundation"
[   101.559]    compiled for 1.20.10, module version = 1.0.0
[   101.559]    ABI class: X.Org ANSI C Emulation, version 0.4
[   101.559] (II) Loading sub module "wfb"
[   101.559] (II) LoadModule: "wfb"
[   101.559] (II) Loading /usr/lib/xorg/modules/libwfb.so
[   101.559] (II) Module wfb: vendor="X.Org Foundation"
[   101.559] (II) Loading sub module "ramdac"
[   101.559] (II) LoadModule: "ramdac"
[   101.559] (II) Module "ramdac" already built-in
[   101.561] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[   101.562] (EE) NVIDIA:     system's kernel log for additional error messages and
[   101.562] (EE) NVIDIA:     consult the NVIDIA README for details.
[   101.562] (EE) No devices detected.
[   101.562] (EE)
Fatal server error:
[   101.562] (EE) no screens found(EE)
[   101.562] (EE)
Please consult the The X.Org Foundation support
         at http://wiki.x.org
 for help.
[   101.562] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   101.562] (EE)
[   101.562] (EE) Server terminated with error (1). Closing log file.
---Xorg.0.log.old---
 [    98.091] (--) Log file renamed from "/var/log/Xorg.pid-1189.log" to "/var/log/Xorg.0.log"
[    98.206]
[    98.206] Build Operating System: Linux Manjaro Linux
[    98.206] Current Operating System: Linux ayumin 5.9.11-3-MANJARO #1 SMP PREEMPT Sat Nov 28 09:08:57 UTC 2020 x86_64
[    98.206] Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-5.9-x86_64 root=UUID=653c7d91-a061-40ba-9c64-e4fd20a57d39 rw rootflags=subvol=@ quiet apparmor=1 security=apparmor udev.log_priority=3
[    98.206] Build Date: 03 December 2020  08:59:12AM
[    98.206]
[    98.206] Current version of pixman: 0.40.0
[    98.206]    Before reporting problems, check http://wiki.x.org
[    98.206] Markers: (--) probed, (**) from config file, (==) default setting,
[    98.207] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Dec 24 16:47:39 2020
[    98.207] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    98.207] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    98.207] (==) ServerLayout "layout"
[    98.207] (**) |-->Screen "Screen0" (0)
[    98.207] (**) |   |-->Monitor "Monitor0"
[    98.208] (**) |   |-->Device "Device0"
[    98.208] (==) Automatically adding devices
[    98.208] (==) Automatically enabling devices
[    98.208] (==) Automatically adding GPU devices
[    98.208] (==) Automatically binding GPU devices
[    98.208] (==) Max clients allowed: 256, resource mask: 0x1fffff
[    98.345] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[    98.345]    Entry deleted from font path.
[    98.345] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[    98.345] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
[    98.345]    (Run 'mkfontdir' on "/usr/share/fonts/100dpi").
[    98.345] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
[    98.345]    (Run 'mkfontdir' on "/usr/share/fonts/75dpi").
[    98.345] (==) FontPath set to:
[    98.345] (==) ModulePath set to "/usr/lib/xorg/modules"
[    98.345] (**) Extension "COMPOSITE" is enabled
[    98.345] (II) The server relies on udev to provide the list of input devices.
[    98.345] (II) Module ABI versions:
[    98.345]    X.Org ANSI C Emulation: 0.4
[    98.345]    X.Org Video Driver: 24.1
[    98.345]    X.Org XInput driver : 24.1
[    98.345]    X.Org Server Extension : 10.0
[    98.346] (++) using VT number 1
[    98.346] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[    98.348] (II) xfree86: Adding drm device (/dev/dri/card0)
[    98.353] (--) PCI: (0@0:2:0) 8086:0412:1462:7850 rev 6, Mem @ 0xf7400000/4194304, 0xd0000000/268435456, I/O @ 0x0000f000/64
[    98.353] (--) PCI:*(1@0:0:0) 10de:1187:3842:3768 rev 161, Mem @ 0xf6000000/16777216, 0xe0000000/134217728, 0xe8000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/131072
[    98.353] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[    98.353] (II) LoadModule: "glx"
[    98.353] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    98.487] (II) Module glx: vendor="X.Org Foundation"
[    98.487]    compiled for 1.20.10, module version = 1.0.0
[    98.487]    ABI class: X.Org Server Extension, version 10.0
[    98.487] (II) LoadModule: "nvidia"
[    98.487] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[    98.665] (II) Module nvidia: vendor="NVIDIA Corporation"
[    98.665]    compiled for 1.6.99.901, module version = 1.0.0
[    98.665]    Module class: X.Org Video Driver
[    98.665] (II) NVIDIA dlloader X Driver  440.100  Fri May 29 08:21:27 UTC 2020
[    98.665] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[    98.665] (II) Loading sub module "fb"
[    98.665] (II) LoadModule: "fb"
[    98.665] (II) Loading /usr/lib/xorg/modules/libfb.so
[    98.691] (II) Module fb: vendor="X.Org Foundation"
[    98.691]    compiled for 1.20.10, module version = 1.0.0
[    98.691]    ABI class: X.Org ANSI C Emulation, version 0.4
[    98.691] (II) Loading sub module "wfb"
[    98.691] (II) LoadModule: "wfb"
[    98.691] (II) Loading /usr/lib/xorg/modules/libwfb.so
[    98.724] (II) Module wfb: vendor="X.Org Foundation"
[    98.724]    compiled for 1.20.10, module version = 1.0.0
[    98.724]    ABI class: X.Org ANSI C Emulation, version 0.4
[    98.724] (II) Loading sub module "ramdac"
[    98.724] (II) LoadModule: "ramdac"
[    98.724] (II) Module "ramdac" already built-in
[    98.729] (EE) NVIDIA: Failed to initialize the NVIDIA kernel module. Please see the
[    98.729] (EE) NVIDIA:     system's kernel log for additional error messages and
[    98.729] (EE) NVIDIA:     consult the NVIDIA README for details.
[    98.729] (EE) No devices detected.
[    98.729] (EE)
Fatal server error:
[    98.729] (EE) no screens found(EE)
[    98.729] (EE)
 for help.
[    98.729] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[    98.729] (EE)
[    98.729] (EE) Server terminated with error (1). Closing log file.
Okay, got it to work. The reason behind the last one probably had the ethernet disabled is probably because I also accidentally touched the networking settings when I removed the nvidia-driver-440xx.
I installed nvidia-driver-450xx this time instead of the free version(?) and now, the ethernet and display works.
Thanks either way! :smiley:
