HaMa
January 7, 2022, 2:44pm
#1
Dear experts,
Information: I am running Manjaro XFCE and Windows 10 (2 separate M.2 drives, UEFI) on an AMD system (R9 3900X). The current Manjaro installation is ca. 4 months old. There were 1 or 2 earlier kernels supporting my RX 6700TX GPU but meanwhile these kernels are “unsupported” so I am currently running the kernel 5.14.21-2.
Problem: After a warm reboot from Manjaro, my computer gets stuck at a black screen with only the cursor blinking at the top left corner. That’s very early in the boot process before the POST so no memory/drive information etc. will be displayed. Cold boots are always working with no problems. When I perform a warm reboot from Windows 10 there’s also no problem. I get to see the POST screen and then the Grub boot menu etc.
I can’t tell when that started since I rarely perform warm reboots with Manjaro but as stated above, I have changed the kernel to a newer one once or twice due to an “unsupported kernel” message. It’s just a minor issue and I could live with that. However, it would be very nice if there was a solution. Do you know something? If you need more information please let me know.
Cheers
Hans
HaMa
January 7, 2022, 3:24pm
#2
P.S.: I had the idea to also provide the mainboard’s debug code and found that it’s A2 (IDE detect). Since it took some time to open the side panel and look up the code, I noticed that at some point the code switched to A0 an the computer actually booted as normal. It takes 35 seconds in state A2 before the boot proceeds. So I just wasn’t patient enough and always initiated a cold reboot before these 35 seconds had passed. But still, this long delay in state A2 only happens with Manjaro but not with Windows.
HaMa
January 7, 2022, 3:57pm
#4
inxi output:
$ inxi --admin --verbosity=7 --filter --width
Kernel: 5.14.21-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.14-x86_64
root=UUID=8f03cdf6-b193-4cbe-b764-bc593ab9a3a0 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7C36 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: PRESTIGE X570 CREATION (MS-7C36) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.D0
date: 05/20/2021
Device-1: hidpp_battery_0 model: Logitech K800 serial: <filter>
charge: 70% (should be ignored) rechargeable: yes status: Full
Device-2: hidpp_battery_1 model: Logitech Wireless Mouse MX Master
status: Discharging
RAM: total: 31.27 GiB used: 2.53 GiB (8.1%)
RAM Report:
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2275 high: 3599 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2878 2: 2053
3: 2400 4: 2199 5: 2193 6: 2200 7: 2200 8: 2200 9: 2198 10: 2199 11: 2199
12: 2201 13: 3599 14: 2055 15: 2057 16: 2199 17: 2200 18: 2198 19: 2198
20: 2199 21: 2198 22: 2200 23: 2200 24: 2198 bogomips: 182490
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
conditional, RSB filling
Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT / 6800M] vendor: Tul
driver: amdgpu v: kernel bus-ID: 33:00.0 chip-ID: 1002:73df class-ID: 0300
Device-2: Logitech C920 HD Pro Webcam type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-1:2 chip-ID: 046d:0892
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: amdgpu,ati unloaded: modesetting,radeon alternate: fbdev,vesa
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
s-diag: 777mm (30.6")
Monitor-1: DisplayPort-0 res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.2") diag: 685mm (27")
Device-1: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
driver: snd_hda_intel v: kernel bus-ID: 33:00.1 chip-ID: 1002:ab28
class-ID: 0403
Device-2: Thomann SC450USB type: USB driver: snd-usb-audio bus-ID: 1-5:5
chip-ID: 1346:0002 class-ID: 0102
Device-3: Logitech C920 HD Pro Webcam type: USB
Sound Server-1: ALSA v: k5.14.21-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Aquantia AQC107 NBase-T/IEEE 802.3bz Ethernet [AQtion]
vendor: Micro-Star MSI driver: atlantic v: kernel port: N/A bus-ID: 24:00.0
chip-ID: 1d6a:07b1 class-ID: 0200
IF: enp36s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel port: d000 bus-ID: 2b:00.0 chip-ID: 8086:1539 class-ID: 0200
IF: enp43s0 state: down mac: <filter>
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 2d:00.0
chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-4:4
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 11.85 TiB used: 63.16 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:7 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111110WD temp: 44.9 C scheme: GPT
ID-3: /dev/nvme2n1 maj-min: 259:2 vendor: Crucial model: CT1000P1SSD8
lanes: 4 type: SSD serial: <filter> rev: P3CR013 temp: 34.9 C scheme: GPT
ID-4: /dev/nvme3n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
lanes: 4 type: SSD serial: <filter> rev: P3CR013 temp: 31.9 C scheme: GPT
ID-5: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-6: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 PRO 512GB
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: MBR
ID-7: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 QVO 4TB
ID-8: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 850 PRO 512GB
type: SSD serial: <filter> rev: 1B6Q scheme: MBR
ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
used: 63.16 GiB (6.9%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:6
label: N/A uuid: 8f03cdf6-b193-4cbe-b764-bc593ab9a3a0
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:5
label: NO_LABEL uuid: 181A-4D4A
ID-1: /dev/nvme0n1p1 maj-min: 259:8 size: 100 MiB fs: vfat label: N/A
uuid: D400-CAFB
ID-2: /dev/nvme0n1p2 maj-min: 259:9 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:10 size: 930.89 GiB fs: ntfs
label: Windows 10 uuid: DC4803D24803AA7A
ID-4: /dev/nvme0n1p4 maj-min: 259:11 size: 524 MiB fs: ntfs label: N/A
uuid: A4C8B6F4C8B6C3B8
ID-5: /dev/nvme2n1p1 maj-min: 259:3 size: 931.51 GiB fs: ext4
label: Linux Data uuid: 107cc612-3472-4d14-9fc3-f39d0ca240cd
ID-6: /dev/nvme3n1p1 maj-min: 259:1 size: 931.51 GiB fs: ntfs
label: Windows Data uuid: 07E516480A01573E
ID-7: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-8: /dev/sda2 maj-min: 8:2 size: 3.64 TiB fs: ntfs label: Ablage_4TB_2
uuid: 1E8A1B0E8A1AE1D7
ID-9: /dev/sdb1 maj-min: 8:17 size: 476.94 GiB fs: ntfs
label: Windows Backup uuid: 64B2B7D35D2ED655
ID-10: /dev/sdc1 maj-min: 8:33 size: 16 MiB fs: <superuser required>
ID-11: /dev/sdc2 maj-min: 8:34 size: 3.64 TiB fs: ntfs label: Ablage_4TB_1
uuid: 782C01A12C015C0E
ID-12: /dev/sdd1 maj-min: 8:49 size: 349.47 GiB fs: ntfs
label: SSD_ALT - Windows 10 uuid: D0DC3D9ADC3D7BB2
ID-13: /dev/sdd2 maj-min: 8:50 size: 538 MiB fs: ntfs label: N/A
uuid: 0E40A43D40A42E01
ID-14: /dev/sdd3 maj-min: 8:51 size: 126.94 GiB fs: ntfs
label: SSD_ALT - Ablage uuid: D60C69BA0C6995F1
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Hub-2: 1-1:2 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
speed: 480 Mb/s power: 100mA chip-ID: 174c:2074 class-ID: 0900
Hub-3: 1-2:3 info: ASMedia ASM1074 High-Speed hub ports: 4 rev: 2.1
Device-1: 1-4:4 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-2: 1-5:5 info: Thomann SC450USB type: Audio driver: snd-usb-audio
interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 90mA chip-ID: 1346:0002
class-ID: 0102
Device-3: 1-6:6 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 2-1:2 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
speed: 5 Gb/s power: 8mA chip-ID: 174c:3074 class-ID: 0900
Hub-6: 2-2:3 info: ASMedia ASM1074 SuperSpeed hub ports: 4 rev: 3.0
Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-5:2 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c36 class-ID: 0300 serial: <filter>
Hub-8: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-9: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-10: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 5-1:2 info: Logitech C920 HD Pro Webcam type: Video,Audio
power: 500mA chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
Hub-11: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 41.9 C mobo: N/A gpu: amdgpu temp: 59.0 C
mem: 58.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Processes: 445 Uptime: 39m wakeups: 4 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1385 pacman: 1376 lib: 385 flatpak: 0
snap: 9 Shell: Bash v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
That kernel is EOL, you should switch to 5.15
(LTS).
HaMa
January 9, 2022, 2:21pm
#7
The latest LTS kernel offered to me in the kernel settings is 5.10.89.1. That did not work with my RX 9700XT GPU. The other unsupported one is still installed but I don’t use it (will deintsall it in a minute).
5.15 will be the next LTS (even it is not marked yet as LTS)
