I have legion 5 15ARH05 with GTX 1650ti the problem is the that after the laptop suspends sometimes it shows the cursor and sometimes I can’t see it and I can’t interact with the laptop only way to get it back running is by forcing shutdown then opening it up again.
P.S.: The same problem has occurred on every kernel I have used my guess is that it’s a problem caused by nvidia gpu.
OS: Manjaro
Kernel: 5.18.5-1
Laptop: Lenovo legion 5 15ARH05
CPU: Ryzen 5
GPU: GTX 1650ti
