Hello there
Yesterday I started updates via the GUI(I’m running gnome). But I’ve forgotten to wait till it is finished and then shutdown the computer. So when I tried to boot my computer this morning the following message appeard:
error file `boot/initramfs-s5.15-x86_64.img` not found
Press any key to continue
When I press any key (besides CTRL + ALT + DEL, which reboots) or wait long enough I get the following message (truncated):
TSC_DEADLINE disabled due to Errata: please updat
microcode to version: 0x22 (or later)
I tried the recovery kernel and older kernels. Some have a bit other error messages, but the behaviour is the same.
a quit old kernel: 5.9.16-1 wokrs and I can boot it normaly, but it falls in to emergency mode. So I tried to look around and found the following: The last three lines of /var/log/pacman.log
are:
[ALPM-SCRIPTLET] ->Running build hook: [filesystem]
[ALPM-SCRIPTLET] ==> Generating module dependencies
[ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/inittramfs-5.10-x86_64.img
I tried to fix that with pacman -Syu
, which responds that it can’t lock the database.
Removing that lock, solves that problem but just errors out, because there is no network.
So I run pacman -Qk
and it gave me some warnings.
I suspect, that if there is a way to continue the installation/restart I will be fine. Do you have any idea, how I can do that?
Or other ideas how I can fix that problem?
