remove also the video linux: sudo mhwd -r pci video-linux
then check again with: find /etc/X11/ -name "*.conf"
if the xorg.conf is removed;
and in: ls /etc/modprobe.d
if the: mhwd-gpu.conf
is removed, if not remove it; and install again the drivers: sudo mhwd -a pci free 0300
and enable early loading: sudo nano /etc/mkinitcpio.conf
and edit the MODULES section to look like this: MODULES=(amdgpu)
save it with ctrl+x, press ‘Y’, then enter, and update it: sudo mkinitcpio -P
reboot
I just rebooted again and its sorted. Thank you so much. I knew it was rescue able as I could get to a TTY but had no idea where to start. Thank you again.
