Hello ARM community.
Mostly point releases this time, as we prepare for the next stable update and release.
Some highlights:
- Most of our kernels got updated
- Code updated to 1.68.0
- And KDE Gear applications updated to 22.04.2
- LibreOffice updated to 7.3.4
- And Thunderbird updated to 91.10.0
- Lots of Mobile specific packages got updated
- Many python packages got updated
Tips And Tricks
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
- Install
waydroid-image
and all it’s dependencies. - Run
pkexec setup-waydroid
. - You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64 #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2 #disable cause kodi uses more
dtoverlay=rpivid-v4l2
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt
Arch Linux - News: Sorting out old password hashes
The ghostpcl
and ghostxps
requires manual intervention (if you have these installed):
The nss
package requires manual intervention:
The packages hplip
and firewalld
Package Changes
(Sun Jun 12 19:39:56 CEST 2022)
- arm-testing community aarch64: 405 new and 383 removed package(s)
- arm-testing core aarch64: 37 new and 35 removed package(s)
- arm-testing extra aarch64: 665 new and 664 removed package(s)
- arm-testing kde-unstable aarch64: 387 new and 387 removed package(s)
:: Different overlay package(s) in repository community aarch64
PACKAGE 2022-06-05 2022-06-12
callaudiod 0.1.4-1 0.1.4+1+gd380d60-1
chatty 0.6.4-1 0.6.6-1
code 1.67.2-1 1.68.0-1
dkms-rtl8723cs 2020.06.27-2 2021.09.02-1
electron 19.0.0-1 19.0.3-1
electron17 17.4.5-1 17.4.7-1
electron18 18.3.0-1 18.3.2-1
element-desktop 1.10.13-1 1.10.14-1
element-web 1.10.13-1 1.10.14-1
feedbackd 0.0.0+git20220208-1 0.0.0+git20220520-1
gtk3-mobile 3.24.33-1 3.24.34-1
kodi-rpi-git20.x.60452.e76baeac66-120.x.60481.ba4bb5e5af-2
kodi-rpi-git-dev20.x.60452.e76baeac66-120.x.60481.ba4bb5e5af-2
kodi-rpi-git-eventclients20.x.60452.e76baeac66-120.x.60481.ba4bb5e5af-2
kodi-rpi-git-tools-texturepacker20.x.60452.e76baeac66-120.x.60481.ba4bb5e5af-2
linux-lts-udl 5.15.44-2 5.15.45-1
linux-lts-udl-headers 5.15.44-2 5.15.45-1
linux-rpi4-udl 5.15.44-1 5.15.45-1
linux-rpi4-udl-headers 5.15.44-1 5.15.45-1
phoc 0.20.0+8+g0eda5aa-1 0.20.0+79+ge5a6514-1
phosh0.20.0beta1+3+ge5f33878-10.20.0beta1+11+ga63d1b2c-1
quartz64-post-install 20220603-1 20220607-1
gnome-shell-mobile -42.1+r143+g67603c924-1
:: Different sync package(s) in repository community aarch64
absl-py 1.0.0-1 1.1.0-1
allegro 5.2.7.0-3 5.2.8.0-1
amtk 5.4.1-1 5.5.1-1
ansible 5.8.0-1 5.9.0-1
ansible-lint 6.2.2-1 6.3.0-1
apm 2.6.5-2 -
archlinux-repro 20220116-1 20220606-1
argocd 2.3.4-1 2.4.0-1
asciinema 2.1.0-2 2.2.0-1
atuin 0.9.1-1 0.10.0-1
aubio 0.4.9-13 0.4.9-14
auto-multiple-choice 1.5.2-2 1.5.2-3
bacon 2.2.0-1 2.2.1-1
bat 0.20.0-2 0.21.0-1
birdfont 2.30.0-1 2.32.0-1
blender 17:3.1.2-2.2 17:3.2.0-1
blueman 2.2.4-1 2.2.5-1
blueprint-compiler 0+r153-1 0.2.0-1
boinctui 2.5.1-1 2.5.2-1
bpftrace 0.14.1-1 0.15.0-1
budgie-extras 1.3.0-1 1.4.0-1
budgie-screensaver 5.0.1-1 5.0.2-1
cadence 0.9.1-5 0.9.1-6
capnproto 0.9.1-1 0.10.1-1
cargo-c 0.9.9-1 0.9.10-1
cargo-nextest 0.9.16-1 0.9.18-1
cbatticon 1.6.12-2 1.6.13-1
certbot 1.27.0-1 1.28.0-1
certbot-apache 1.27.0-1 1.28.0-1
certbot-dns-cloudflare 1.27.0-1 1.28.0-1
certbot-dns-cloudxns 1.27.0-1 1.28.0-1
certbot-dns-digitalocean 1.27.0-1 1.28.0-1
certbot-dns-dnsimple 1.27.0-1 1.28.0-1
certbot-dns-dnsmadeeasy 1.27.0-1 1.28.0-1
certbot-dns-gehirn 1.27.0-1 1.28.0-1
certbot-dns-google 1.27.0-1 1.28.0-1
certbot-dns-linode 1.27.0-1 1.28.0-1
certbot-dns-luadns 1.27.0-1 1.28.0-1
certbot-dns-nsone 1.27.0-1 1.28.0-1
certbot-dns-ovh 1.27.0-1 1.28.0-1
certbot-dns-rfc2136 1.27.0-1 1.28.0-1
certbot-dns-route53 1.27.0-1 1.28.0-1
certbot-dns-sakuracloud 1.27.0-1 1.28.0-1
certbot-nginx 1.27.0-1 1.28.0-1
containerd 1.6.4-1 1.6.5-1
cosign 1.4.1-1 1.9.0-1
cri-o 1.24.0-1 1.24.1-1
crictl 1.24.1-1 1.24.2-1
critest 1.24.1-1 1.24.2-1
dagger 0.2.14-1 0.2.18-1
dart-sass 1.52.1-1 1.52.3-1
diffoscope 215-1 216-1
difftastic 0.28.0-2 0.29.0-1
diffuse 0.7.4-2 0.7.5-1
dns-over-https 2.3.0-2 2.3.1-1
docker 1:20.10.16-1 1:20.10.17-1
dos2unix 7.4.2-1 7.4.3-1
drumkv1 0.9.25-2 0.9.26-2
dub 1.27.0-2 1.29.0-1
fasd 1.0.1-3 1.0.2-1
filezilla 3.60.0-1 3.60.1-1
fingerterm 1.4.4-1 1.4.5-1
firefox-ublock-origin 1.42.2-1 1.43.0-1
firejail 0.9.68-1 0.9.70-2
flatbuffers 2.0.6-1 2.0.6-2
fluxctl 1.24.3-1 1.25.2-1
freeimage 3.18.0-12 3.18.0-15
frei0r-plugins 1.8.0-1 1.8.0-2
function2 4.2.0-1 4.2.1-1
gajim 1.4.2-1 1.4.3-1
ghostwriter 2.1.2-1 2.1.3-1
gimp-plugin-gmic 3.1.2-2 3.1.2-3
github-cli 2.11.3-1 2.12.1-1
gitlab-runner 15.0.0-1 15.0.0-2
gnome-initial-setup 42.1.1-1 42.2-1
gnuradio 3.10.2.0-4 3.10.2.0-5
gnuradio-companion 3.10.2.0-4 3.10.2.0-5
gnuradio-osmosdr 0.2.3-9 0.2.3-10
go-ethereum 1.10.17-1 1.10.18-1
gopass 1.14.2-1 1.14.3-1
goreleaser 1.7.0-2 1.9.2-1
groovy 4.0.1-1 4.0.3-1
gummi 2:0.8.2-2 2:0.8.3-1
hck 0.7.2-1 0.7.5-1
hostess 0.5.2-3 0.5.2-4
ibus-table 1.16.4-1 1.16.7-1
imapsync 2.178-1 2.200-1
inotify-tools 3.22.1.0-1 3.22.6.0-1
iwd 1.27-1 1.28-1
jacktrip 1.5.3-1 1.6.0-1
jalv 1.6.6-1 1.6.6-2
jenkins 2.350-1 2.354-1
jupyter-notebook 6.4.11-2 6.4.12-1
jupyter-server 1.17.0-1 1.17.1-1
jupyterlab 3.4.2-1 3.4.3-1
klayout 0.27.9-1 0.27.10-1
krita-plugin-gmic 3.1.2.2-1 3.1.2.3-1
kubeseal 0.17.3-1 0.17.5-1
kvantum-theme-materia 20220510-1 20220607-1
libantlr3c 3.5.2-4 3.5.3-1
libeatmydata 105.r16.g96f8f0e-2 130-1
libopenshot 0.2.7-10 0.2.7-11
librime-data 0.0.0.20211023-1 0.0.0.20220409-1
libstrophe 1:0.11.0-1 1:0.12.0-1
libstrophe-doc 1:0.11.0-1 1:0.12.0-1
libuhd 4.1.0.5-1.1 4.2.0.0-1
libuhd-firmware 4.1.0.1-2 4.2.0.0-1
libvirt 1:8.3.0-1 1:8.4.0-1
libvirt-python 1:8.3.0-1 1:8.4.0-1
libvirt-storage-gluster 1:8.3.0-1 1:8.4.0-1
libvirt-storage-iscsi-direct 1:8.3.0-1 1:8.4.0-1
lilv 0.24.12-4 0.24.14-2
logcli 2.4.2-2 2.5.0-1
loki 2.4.2-2 2.5.0-1
loki-canary 2.4.2-2 2.5.0-1
lua-language-server 3.2.4-1 3.2.5-1
lua-sec 2:1.0.2-1 2:1.1.0-1
lua51-sec 2:1.0.2-1 2:1.1.0-1
lua52-sec 2:1.0.2-1 2:1.1.0-1
lua53-sec 2:1.0.2-1 2:1.1.0-1
lucky-commit 2.2.0-1 2.2.1-1
lv2 1.18.2-1 1.18.4-2
marked 4.0.2-1 4.0.3-1
materia-kde 20220510-1 20220607-1
mathjax 3.2.1-1 3.2.2-1
matrix-synapse 1.59.1-1 1.60.0-1
maturin 0.12.17-1 0.12.19-1
mediawiki 1.38.0-2 1.38.1-1
meilisearch 0.27.1-1 0.27.2-1
mellite 3.12.0-2 3.13.2-1
minetest 5.5.0-1 5.5.1-1
minetest-common 5.5.0-1 5.5.1-1
minetest-server 5.5.0-1 5.5.1-1
mlt6 6.26.1-9 6.26.1-10
mod_passenger 6.0.14-1 6.0.14-2
nginx-mod-auth-pam 1.5.3-2 1.5.3-3
nginx-mod-brotli 1:1.0.0rc-4 1:1.0.0rc-5
nginx-mod-cache_purge 2.5.1-4 2.5.2-2
nginx-mod-echo 0.62-3 0.62-4
nginx-mod-geoip2 3.3-5 3.3-6
nginx-mod-headers-more 0.33-12 0.33-13
nginx-mod-memc 0.19-9 0.19-10
nginx-mod-modsecurity 1:1.0.3-1 1:1.0.3-2
nginx-mod-naxsi 1.3-5 1.3-6
nginx-mod-ndk 0.33+0.3.1-2 0.33+0.3.1-3
nginx-mod-njs 0.7.4-1 0.7.4-2
nginx-mod-passenger 6.0.14-1 6.0.14-2
nginx-mod-redis 0.3.9-9 0.3.9-10
nginx-mod-redis2 0.15-9 0.15-10
nginx-mod-set-misc 0.33+0.3.1-2 0.33+0.3.1-3
nginx-mod-srcache 0.32-4 0.32-5
nginx-mod-vts 0.1.18-5 0.1.18-6
nodejs-yaml 2.0.1-1 2.1.0-1
nomacs 1:3.17.2206-7 1:3.17.2206-8
npm-check-updates 13.0.4-1 13.1.2-1
nuitka 0.8-1 0.8.4-1
ocaml-base 0.14.3-1 0.15.0-1
ocaml-sexplib0 0.14.0-5 0.15.0-1
opencc 1.1.3-1 1.1.4-1
opencc-doc 1.1.3-1 1.1.4-1
opensubdiv 3.4.4-10 3.4.4-11
opentoonz 1.6.0-1 1.6.0-2
operator-sdk 1.20.1-1 1.21.0-1
osbuild 56-1 58-1
pacparser 1.3.7rc6-2 1.3.9-1
padthv1 0.9.25-2 0.9.26-1
papirus-icon-theme 20220508-1 20220606-1
patchage 1.0.4-1 1.0.6-2
pcsclite 1.9.7-1 1.9.8-1
pdal 2.4.1-1 2.4.2-1
picard 2.7.3-1 2.8.1-1
plocate 1.1.15-2 1.1.16-1
prjtrellis 1.1-4 1.2.1-1
promtail 2.4.2-2 2.5.0-1
prosody 1:0.12.0-2 1:0.12.1-1
pulumi 3.32.0-1 3.34.1-1
pyenv 2.3.0-1 2.3.1-1
pyright 1.1.252-1 1.1.253-1
python-acme 1.27.0-1 1.28.0-1
python-aioconsole 0.3.3-2 0.4.0-1
python-ansible-compat 2.0.4-1 2.1.0-1
python-aubio 0.4.9-13 0.4.9-14
python-bincopy 17.10.1-1 17.10.2-1
python-bottle 0.12.20-1 0.12.21-1
python-build 0.7.0-4 0.8.0-1
python-cheroot 8.6.0-1 8.6.0-2
python-cherrypy 18.6.1-3 18.6.1-4
python-cookiecutter 1.7.3-3 2.1.1-1
python-django-allauth 0.50.0-1 0.51.0-1
python-dulwich 0.20.42-1 0.20.43-1
python-filelock 3.5.0-1 3.5.1-1
python-flatbuffers 2.0.6-1 2.0.6-2
python-glfw 2.1.0-2 2.5.3-1
python-hsluv 5.0.2-2 5.0.3-1
python-igraph 0.9.10-1 0.9.11-1
python-ipykernel 6.13.0-1 6.13.1-1
python-irc 20.0.0-1 20.0.0-2
python-jack-client 0.5.3-3 0.5.4-1
python-jaraco 2022.2.21-1 -
python-jaraco.envs 2.1.1-3 2.2.0-1
python-jaraco.path 3.4.0-1 3.4.0-2
python-jaraco.test 5.0.0-3 5.0.0-4
python-jmespath 0.10.0-5 1.0.0-1
python-jupyter_client 7.3.1-1 7.3.4-1
python-kikit 0.7-2 1.0.5-1
python-logilab-common 1.8.3-1 1.9.1-1
python-markdown2 2.4.1-3 2.4.3-1
python-marshmallow 3.14.1-1 3.15.0-1
python-minio 7.1.8-1 7.1.9-1
python-mocket 3.10.5-1 3.10.6-1
python-moto 3.1.8-1 3.1.12-1
python-novaclient 17.7.0-1 18.0.0-1
python-openmdao 3.15.0-1 3.16.0-1
python-openstackclient 5.7.0-3 5.8.0-1
python-openstacksdk 0.59.0-4 0.60.0-1
python-orjson 3.6.8-1 3.7.2-1
python-pefile 2021.9.3-3 2022.5.30-1
python-pikepdf 5.1.3-1 5.1.5-1
python-pkginfo 1.8.2-2 1.8.3-1
python-pyalsa 1.2.6-2 1.2.7-1
python-pycapnp 1.1.0-4 1.1.0-5
python-pyglet 1.5.24-1 1.5.26-1
python-pylink-square 0.12.0-1 0.13.0-1
python-pylint 2.13.8-1 2.14.1-1
python-pynitrokey 0.4.22-1 0.4.24-1
python-pyocd 0.33.1-1 0.34.0-1
python-pyroute2 0.6.9-1 0.6.11-1
python-pyte 0.8.0-8 0.8.1-1
python-pytest-asyncio 0.18.0-1 0.18.1-1
python-pytest-black 0.3.12-5 0.3.12-6
python-pytest-enabler 1.2.1-1 1.2.1-2
python-pytest-httpx 0.17.3-1 0.21.0-1
python-pytest-randomly 3.10.1-1 3.10.2-1
python-pytest-subtests 0.7.0-1 0.8.0-1
python-pytest-xprocess 0.18.1-3 0.19.0-1
python-pywlroots 0.15.14-1 0.15.17-1
python-pyzmq 23.0.0-1 23.1.0-1
python-redis 4.0.1-1 4.0.2-1
python-sphinx-click 4.0.3-1 4.1.0-1
python-tempora 5.0.1-1 5.0.1-2
python-utils 3.2.3-1 3.3.3-1
python-validators 0.19.0-1 0.20.0-1
python-whitenoise 6.1.0-1 6.2.0-1
python-yg.lockfile 2.3-3 2.3-4
python-ziafont 0.3-1 0.3.1-1
python-zipp 3.8.0-1 3.8.0-2
qpid-proton 0.36.0-3 0.37.0-1
qxmledit 0.9.16-2 0.9.17-1
rabbitmq 3.8.22-1 3.10.1-1
rabbitmqadmin 3.8.22-1 3.10.1-1
rathole 0.4.1-1 0.4.2-1
redis 7.0.0-1 7.0.1-1
rime-emoji 0.0.0.20210909-1 0.0.0.20220315-1
rime-prelude 0.0.0.20211023-1 0.0.0.20220409-1
rosegarden 21.12-1 22.06-1
rsibreak 0.12.14-1 0.12.15-1
rstcheck 5.0.0-1 6.0.0.post1-1
ruby-atk 3.4.5-1 3.5.1-1
ruby-bundler 2.3.10-1 2.3.15-1
ruby-cairo-gobject 3.4.5-2 3.5.1-1
ruby-gdk3 3.4.5-1 3.5.1-1
ruby-gdk_pixbuf2 3.4.5-1 3.5.1-1
ruby-gio2 3.4.5-2 3.5.1-1
ruby-glib2 3.4.5-2 3.5.1-1
ruby-gobject-introspection 3.4.5-2 3.5.1-1
ruby-gtk2 3.4.3-1 -
ruby-gtk3 3.4.5-2 3.5.1-1
ruby-msgpack 1.5.1-1 1.5.2-1
ruby-native-package-installer 1.1.1-2 1.1.4-1
ruby-nats-pure 2.0.0-1 2.1.0-1
ruby-pango 3.4.5-2 3.5.1-1
ruby-pkg-config 1.4.6-1 1.4.7-1
ruby-thin 1.8.0-3 1.8.1-1
runc 1.1.2-1 1.1.3-1
rust-analyzer 20220530-1 20220606-1
samplv1 0.9.25-2 0.9.26-1
sbt 1:1.6.0-1 1:1.6.1-1
selene-linter 0.17.0-1 0.18.2-1
sentry-cli 2.0.4-1 2.1.0-1
serd 0.30.10-1 0.30.12-2
shfmt 3.5.0-1 3.5.1-1
shim 15.5-1 15.6-1
shotwell 2:0.30.16-1 2:0.30.16-2
sigil 1.9.10-1 1.9.10-2
sile 0.12.5-1 0.13.0-1
snd 22.3-1 22.4-1
soapyuhd 0.4.1-5 0.4.1-6
sonic-visualiser 4.5-1 4.5-3
sord 0.16.8-1 0.16.10-2
sqlc 1.13.0-2 1.14.0-1
sqlitebrowser 3.12.2-1 3.12.2-2
squid 5.5-1 5.6-1
sratom 0.6.8-3 0.6.10-3
strawberry 1.0.4-3 1.0.5-1
stylelint 14.8.5-1 14.9.1-1
stylelint-config-recommended 7.0.0-1 8.0.0-1
stylelint-config-standard 25.0.0-1 26.0.0-1
suil 0.10.10-2 0.10.12-2
swift-im 4.0.2-7 4.0.2-8
swiften 4.0.2-7 4.0.2-8
syncthing 1.20.1-1 1.20.2-1
syncthing-relaysrv 1.20.1-1 1.20.2-1
synthv1 0.9.25-3 0.9.26-1
tailscale 1.24.2-1 1.26.0-1
tanka 0.20.0-1 0.22.0-1
tepl 6.0.2-1 6.1.1-1
tmux 3.3-2 3.3_a-2
trace-cmd 3.0.3-1 3.1-1
traefik 2.6.0-1 2.7.0-1
ttc-iosevka 15.4.2-1 15.5.0-1
ttc-iosevka-aile 15.4.2-1 15.5.0-1
ttc-iosevka-curly 15.4.2-1 15.5.0-1
ttc-iosevka-curly-slab 15.4.2-1 15.5.0-1
ttc-iosevka-etoile 15.4.2-1 15.5.0-1
ttc-iosevka-slab 15.4.2-1 15.5.0-1
ttc-iosevka-ss01 15.4.2-1 15.5.0-1
ttc-iosevka-ss02 15.4.2-1 15.5.0-1
ttc-iosevka-ss03 15.4.2-1 15.5.0-1
ttc-iosevka-ss04 15.4.2-1 15.5.0-1
ttc-iosevka-ss05 15.4.2-1 15.5.0-1
ttc-iosevka-ss06 15.4.2-1 15.5.0-1
ttc-iosevka-ss07 15.4.2-1 15.5.0-1
ttc-iosevka-ss08 15.4.2-1 15.5.0-1
ttc-iosevka-ss09 15.4.2-1 15.5.0-1
ttc-iosevka-ss10 15.4.2-1 15.5.0-1
ttc-iosevka-ss11 15.4.2-1 15.5.0-1
ttc-iosevka-ss12 15.4.2-1 15.5.0-1
ttc-iosevka-ss13 15.4.2-1 15.5.0-1
ttc-iosevka-ss14 15.4.2-1 15.5.0-1
ttc-iosevka-ss15 15.4.2-1 15.5.0-1
ttc-iosevka-ss16 15.4.2-1 15.5.0-1
ttc-iosevka-ss17 15.4.2-1 15.5.0-1
ttc-iosevka-ss18 15.4.2-1 15.5.0-1
typescript-language-server 0.10.1-1 0.11.0-1
uglify-js 3.15.5-1 3.16.0-1
ugrep 3.8.0-1 3.8.2-1
ukui-biometric-auth 1.2.2-3 1.2.2-4
ukui-control-center 3.0.4-2.1 3.0.4-3
ukui-greeter 3.0.3-1 3.0.3-2
ukui-screensaver 3.0.2-3 3.0.2-4
urh 2.9.2-5 2.9.3-1
v2ray-domain-list-community 20220604062951-1 20220611055103-1
v2ray-geoip 202206020056-1 202206090051-1
vaultwarden-web 2.28.1-1 2022.05.0-1
volatility3 1.0.1-3 2.0.1-1
vscode-css-languageserver 1.67.0-1 1.68.0-1
vscode-html-languageserver 1.67.0-1 1.68.0-1
vscode-json-languageserver 1.67.0-1 1.68.0-1
wallabag 2.5.0-1 2.5.1-1
warpinator 1.2.9-1 1.2.10-1
web-ext 6.8.0-1 7.0.0-1
wgcf 2.2.14-1 2.2.15-1
x42-plugins 20220327-1 20220605-1
xdg-desktop-portal-wlr 0.5.0-1 0.6.0-1
xplr 0.18.0-1 0.19.0-1
yaegi 0.11.1-1 0.12.0-1
yaml-language-server 1.7.0-1 1.8.0-1
zellij 0.29.1-1 0.30.0-1
ghc-filesystem - 1.5.12-2
gnome-bluetooth - 3.34.5-4
hound - 0.5.0-1
httplz - 1.12.5-2
plumber - 1.8.0-1
python-calver - 2021.7.30-1
python-configupdater - 3.1-1
python-ini2toml - 0.10-1
python-jaraco.classes - 3.2.1-3
python-jaraco.collections - 3.5.1-2
python-jaraco.functools - 3.5.0-2
python-jaraco.itertools - 6.2.1-2
python-jaraco.logging - 3.1.1-2
python-jaraco.stream - 3.0.3-2
python-jaraco.text - 3.8.0-2
python-psycopg - 3.0.14-1
python-psycopg-pool - 3.1.1-2
python-rstcheck-core - 1.0.2-1
python-sphinx-reredirects - 0.1.0-1
qcustomplot - 2.1.0-1
qcustomplot-doc - 2.1.0-1
qhexedit2 - 0.8.9-1
reaper - 6.60-1
stb - r2126.af1a5bc-1
:: Different overlay package(s) in repository core aarch64
linux 5.18.1-3 5.18.3-2
linux-clockworkpi-a06 5.18.1-1 5.18.3-1
linux-clockworkpi-a06-headers 5.18.1-1 5.18.3-1
linux-headers 5.18.1-3 5.18.3-2
linux-lts 5.15.44-1 5.15.46-1
linux-lts-headers 5.15.44-1 5.15.46-1
linux-pinephone 5.18.1-1 5.18.3-1
linux-pinephone-headers 5.18.1-1 5.18.3-1
linux-pinephonepro 5.18.1-1 5.18.3-1
linux-pinephonepro-headers 5.18.1-1 5.18.3-1
linux-quartz64 5.17.0-3 5.19.0-0.3
linux-quartz64-headers 5.17.0-3 5.19.0-0.3
linux-rpi4 5.15.44-1 5.15.45-1
linux-rpi4-headers 5.15.44-1 5.15.45-1
linux-rpi4-mainline 5.18.1-1 5.18.2-1
linux-rpi4-mainline-headers 5.18.1-1 5.18.2-1
linux-rpi4-rc 5.18.rc7-1 5.19.rc1-1
linux-rpi4-rc-headers 5.18.rc7-1 5.19.rc1-1
uboot-pinebookpro 2022.04-2 2022.04-3
:: Different sync package(s) in repository core aarch64
btrfs-progs 5.18-1 5.18.1-1
dialog 1:1.3_20220414-1 1:1.3_20220526-1
grub 2:2.06-52:2.06.r261.g2f4430cc0-1
gssproxy 0.9.0-1 0.9.1-2
hwdata 0.359-1 0.360-1
krb5 1.19.3-1 1.19.3-3
libgpg-error 1.45-1 1.45-2
libnftnl 1.2.1-1 1.2.2-1
nettle 3.7.3-1.1 3.8-1
python 3.10.4-2 3.10.5-1
python-tests 3.10.4-2 3.10.5-1
s-nail 14.9.23-1 14.9.24-1
sudo 1.9.10-1 1.9.11.p1-1
wireless-regdb 2022.04.08-1 2022.06.06-1
xfsprogs 5.16.0-1 5.18.0-1
zstd 1.5.2-3 1.5.2-5
libbpf - 0.8.0-1
libverto - 0.3.2-4
:: Different overlay package(s) in repository extra aarch64
calamares 3.2.54-3 3.2.59-1
elisa-qtmm 22.04.1-1 22.04.2-1
libpamac 11.3.0-1 11.3.1-1
libpamac-flatpak-plugin 11.3.0-1 11.3.1-1
libpamac-snap-plugin 11.3.0-1 11.3.1-1
mesa-git22.2.0_devel.154891.4b3afed35a2-122.2.0_devel.155282.92f9a509cff0-1
okular 22.04.1-1 22.04.2-1
pamac-cli 10.4.0-2 10.4.1-1
pamac-gnome-integration 10.4.0-2 10.4.1-1
pamac-gtk 10.4.0-2 10.4.1-1
qt5-es2-base 5.15.4+kde+r146-1 5.15.4+kde+r152-1
qt5-es2-xcb-private-headers 5.15.4+kde+r146-1 5.15.4+kde+r152-1
:: Different sync package(s) in repository extra aarch64
akonadi 22.04.1-2 22.04.2-1
akonadi-calendar 22.04.1-1 22.04.2-1
akonadi-calendar-tools 22.04.1-1 22.04.2-1
akonadi-contacts 22.04.1-1 22.04.2-1
akonadi-import-wizard 22.04.1-1 22.04.2-1
akonadi-mime 22.04.1-1 22.04.2-1
akonadi-notes 22.04.1-1 22.04.2-1
akonadi-search 22.04.1-1 22.04.2-1
akonadiconsole 22.04.1-1 22.04.2-1
akregator 22.04.1-1 22.04.2-1
alsa-card-profiles 1:0.3.51-1 1:0.3.52-1
alsa-lib 1.2.6.1-1 1.2.7-2
alsa-ucm-conf 1.2.6.3-1 1.2.7-1
alsa-utils 1.2.6-1 1.2.7-1
analitza 22.04.1-1 22.04.2-1
ark 22.04.1-1 22.04.2-1
artikulate 22.04.1-1 22.04.2-1
audiocd-kio 22.04.1-1 22.04.2-1
baloo-widgets 22.04.1-1 22.04.2-1
bftpd 6.0-1 6.1-1
blinken 22.04.1-1 22.04.2-1
bomber 22.04.1-1 22.04.2-1
boost 1.78.0-2 1.78.0-3
boost-libs 1.78.0-2 1.78.0-3
bovo 22.04.1-1 22.04.2-1
calendarsupport 22.04.1-1 22.04.2-1
cantor 22.04.1-1 22.04.2-1
cbindgen 0.23.0-1 0.24.3-1
cervisia 22.04.1-1 22.04.2-1
chromium 102.0.5005.61-1 102.0.5005.115-1
composer 2.3.6-1 2.3.7-1
cups 1:2.4.2-1 1:2.4.2-3
digikam 7.6.0-3 7.6.0-4
directx-headers 1.600.10-1 1.602.0-1
dnsmasq 2.86-1 2.86-2
dolphin 22.04.1-1 22.04.2-1
dolphin-plugins 22.04.1-1 22.04.2-1
dragon 22.04.1-1 22.04.2-1
egl-wayland2:1.1.9+r3+g582b2d3-1 2:1.1.10-1
elisa 22.04.0-1 22.04.2-1
ell 0.50-1 0.51-1
eventviews 22.04.1-1 22.04.2-1
exo 4.16.3-1 4.16.4-1
falkon 22.04.1-1 22.04.2-1
ffmpegthumbs 22.04.1-1 22.04.2-1
filelight 22.04.1-1 22.04.2-1
firefox-i18n-ach 101.0-1 101.0.1-1
firefox-i18n-af 101.0-1 101.0.1-1
firefox-i18n-an 101.0-1 101.0.1-1
firefox-i18n-ar 101.0-1 101.0.1-1
firefox-i18n-ast 101.0-1 101.0.1-1
firefox-i18n-az 101.0-1 101.0.1-1
firefox-i18n-be 101.0-1 101.0.1-1
firefox-i18n-bg 101.0-1 101.0.1-1
firefox-i18n-bn 101.0-1 101.0.1-1
firefox-i18n-br 101.0-1 101.0.1-1
firefox-i18n-bs 101.0-1 101.0.1-1
firefox-i18n-ca 101.0-1 101.0.1-1
firefox-i18n-ca-valencia 101.0-1 101.0.1-1
firefox-i18n-cak 101.0-1 101.0.1-1
firefox-i18n-cs 101.0-1 101.0.1-1
firefox-i18n-cy 101.0-1 101.0.1-1
firefox-i18n-da 101.0-1 101.0.1-1
firefox-i18n-de 101.0-1 101.0.1-1
firefox-i18n-dsb 101.0-1 101.0.1-1
firefox-i18n-el 101.0-1 101.0.1-1
firefox-i18n-en-ca 101.0-1 101.0.1-1
firefox-i18n-en-gb 101.0-1 101.0.1-1
firefox-i18n-en-us 101.0-1 101.0.1-1
firefox-i18n-eo 101.0-1 101.0.1-1
firefox-i18n-es-ar 101.0-1 101.0.1-1
firefox-i18n-es-cl 101.0-1 101.0.1-1
firefox-i18n-es-es 101.0-1 101.0.1-1
firefox-i18n-es-mx 101.0-1 101.0.1-1
firefox-i18n-et 101.0-1 101.0.1-1
firefox-i18n-eu 101.0-1 101.0.1-1
firefox-i18n-fa 101.0-1 101.0.1-1
firefox-i18n-ff 101.0-1 101.0.1-1
firefox-i18n-fi 101.0-1 101.0.1-1
firefox-i18n-fr 101.0-1 101.0.1-1
firefox-i18n-fy-nl 101.0-1 101.0.1-1
firefox-i18n-ga-ie 101.0-1 101.0.1-1
firefox-i18n-gd 101.0-1 101.0.1-1
firefox-i18n-gl 101.0-1 101.0.1-1
firefox-i18n-gn 101.0-1 101.0.1-1
firefox-i18n-gu-in 101.0-1 101.0.1-1
firefox-i18n-he 101.0-1 101.0.1-1
firefox-i18n-hi-in 101.0-1 101.0.1-1
firefox-i18n-hr 101.0-1 101.0.1-1
firefox-i18n-hsb 101.0-1 101.0.1-1
firefox-i18n-hu 101.0-1 101.0.1-1
firefox-i18n-hy-am 101.0-1 101.0.1-1
firefox-i18n-ia 101.0-1 101.0.1-1
firefox-i18n-id 101.0-1 101.0.1-1
firefox-i18n-is 101.0-1 101.0.1-1
firefox-i18n-it 101.0-1 101.0.1-1
firefox-i18n-ja 101.0-1 101.0.1-1
firefox-i18n-ka 101.0-1 101.0.1-1
firefox-i18n-kab 101.0-1 101.0.1-1
firefox-i18n-kk 101.0-1 101.0.1-1
firefox-i18n-km 101.0-1 101.0.1-1
firefox-i18n-kn 101.0-1 101.0.1-1
firefox-i18n-ko 101.0-1 101.0.1-1
firefox-i18n-lij 101.0-1 101.0.1-1
firefox-i18n-lt 101.0-1 101.0.1-1
firefox-i18n-lv 101.0-1 101.0.1-1
firefox-i18n-mk 101.0-1 101.0.1-1
firefox-i18n-mr 101.0-1 101.0.1-1
firefox-i18n-ms 101.0-1 101.0.1-1
firefox-i18n-my 101.0-1 101.0.1-1
firefox-i18n-nb-no 101.0-1 101.0.1-1
firefox-i18n-ne-np 101.0-1 101.0.1-1
firefox-i18n-nl 101.0-1 101.0.1-1
firefox-i18n-nn-no 101.0-1 101.0.1-1
firefox-i18n-oc 101.0-1 101.0.1-1
firefox-i18n-pa-in 101.0-1 101.0.1-1
firefox-i18n-pl 101.0-1 101.0.1-1
firefox-i18n-pt-br 101.0-1 101.0.1-1
firefox-i18n-pt-pt 101.0-1 101.0.1-1
firefox-i18n-rm 101.0-1 101.0.1-1
firefox-i18n-ro 101.0-1 101.0.1-1
firefox-i18n-ru 101.0-1 101.0.1-1
firefox-i18n-sco 101.0-1 101.0.1-1
firefox-i18n-si 101.0-1 101.0.1-1
firefox-i18n-sk 101.0-1 101.0.1-1
firefox-i18n-sl 101.0-1 101.0.1-1
firefox-i18n-son 101.0-1 101.0.1-1
firefox-i18n-sq 101.0-1 101.0.1-1
firefox-i18n-sr 101.0-1 101.0.1-1
firefox-i18n-sv-se 101.0-1 101.0.1-1
firefox-i18n-szl 101.0-1 101.0.1-1
firefox-i18n-ta 101.0-1 101.0.1-1
firefox-i18n-te 101.0-1 101.0.1-1
firefox-i18n-th 101.0-1 101.0.1-1
firefox-i18n-tl 101.0-1 101.0.1-1
firefox-i18n-tr 101.0-1 101.0.1-1
firefox-i18n-trs 101.0-1 101.0.1-1
firefox-i18n-uk 101.0-1 101.0.1-1
firefox-i18n-ur 101.0-1 101.0.1-1
firefox-i18n-uz 101.0-1 101.0.1-1
firefox-i18n-vi 101.0-1 101.0.1-1
firefox-i18n-xh 101.0-1 101.0.1-1
firefox-i18n-zh-cn 101.0-1 101.0.1-1
firefox-i18n-zh-tw 101.0-1 101.0.1-1
freetds 1.3.11-1 1.3.12-1
gn 0.1967.80a40b07-1 0.2042.2ecd43a1-1
gnome-bluetooth-3.0 42.0-1 42.1-1
gnome-bluetooth 3.34.5-3 -
granatier 22.04.1-1 22.04.2-1
grantlee-editor 22.04.1-1 22.04.2-1
grantleetheme 22.04.1-1 22.04.2-1
gst-editing-services 1.20.2-1 1.20.2-2
gst-libav 1.20.2-1 1.20.2-2
gst-plugin-gtk 1.20.2-1 1.20.2-2
gst-plugin-opencv 1.20.2-1 1.20.2-2
gst-plugin-pipewire 1:0.3.51-1 1:0.3.52-1
gst-plugin-qmlgl 1.20.2-1 1.20.2-2
gst-plugin-va 1.20.2-1 1.20.2-2
gst-plugin-wpe 1.20.2-1 1.20.2-2
gst-plugins-bad 1.20.2-1 1.20.2-2
gst-plugins-bad-libs 1.20.2-1 1.20.2-2
gst-plugins-base 1.20.2-1 1.20.2-2
gst-plugins-base-libs 1.20.2-1 1.20.2-2
gst-plugins-good 1.20.2-1 1.20.2-2
gst-plugins-ugly 1.20.2-1 1.20.2-2
gst-python 1.20.2-1 1.20.2-2
gst-rtsp-server 1.20.2-1 1.20.2-2
gstreamer 1.20.2-1 1.20.2-2
gstreamer-docs 1.20.2-1 1.20.2-2
gstreamer-vaapi 1.20.2-1 1.20.2-2
gvim 8.2.5046-1 8.2.5046-2
gwenview 22.04.1-1 22.04.2-1
imagemagick 7.1.0.36-2 7.1.0.37-1
imagemagick-doc 7.1.0.36-2 7.1.0.37-1
incidenceeditor 22.04.1-1 22.04.2-1
irqbalance 1.8.0-2 1.9.0-1
itinerary 22.04.1-1 22.04.2-1
jasper 3.0.3-1 3.0.4-1
jasper-doc 3.0.3-1 3.0.4-1
jdk11-openjdk 11.0.15.u10-1 11.0.15.u10-2
jre11-openjdk 11.0.15.u10-1 11.0.15.u10-2
jre11-openjdk-headless 11.0.15.u10-1 11.0.15.u10-2
juk 22.04.1-1 22.04.2-1
k3b 1:22.04.1-1 1:22.04.2-1
kaccounts-integration 22.04.1-1 22.04.2-1
kaccounts-providers 22.04.1-1 22.04.2-1
kaddressbook 22.04.1-1 22.04.2-1
kajongg 22.04.1-1 22.04.2-1
kalarm 22.04.1-1 22.04.2-1
kalendar 22.04.1-1 22.04.2-1
kalgebra 22.04.1-1 22.04.2-1
kalzium 22.04.1-1 22.04.2-1
kamera 22.04.1-1 22.04.2-1
kamoso 22.04.1-1 22.04.2-1
kanagram 22.04.1-1 22.04.2-1
kapman 22.04.1-1 22.04.2-1
kapptemplate 22.04.1-1 22.04.2-1
kate 22.04.1-2 22.04.2-1
katomic 22.04.1-1 22.04.2-1
kbackup 22.04.1-1 22.04.2-1
kblackbox 22.04.1-1 22.04.2-1
kblocks 22.04.1-1 22.04.2-1
kbounce 22.04.1-1 22.04.2-1
kbreakout 22.04.1-1 22.04.2-1
kbruch 22.04.1-1 22.04.2-1
kcachegrind 22.04.1-1 22.04.2-1
kcachegrind-common 22.04.1-1 22.04.2-1
kcalc 22.04.1-1 22.04.2-1
kcalutils 22.04.1-1 22.04.2-1
kcharselect 22.04.1-1 22.04.2-1
kcolorchooser 22.04.1-1 22.04.2-1
kcron 22.04.1-1 22.04.2-1
kde-dev-scripts 22.04.1-1 22.04.2-1
kde-dev-utils 22.04.1-1 22.04.2-1
kdebugsettings 22.04.1-1 22.04.2-1
kdeconnect 22.04.1-1 22.04.2-1
kdeedu-data 22.04.1-1 22.04.2-1
kdegraphics-mobipocket 22.04.1-1 22.04.2-1
kdegraphics-thumbnailers 22.04.1-1 22.04.2-1
kdenetwork-filesharing 22.04.1-1 22.04.2-1
kdenlive 22.04.1-3 22.04.2-1
kdepim-addons 22.04.1-1 22.04.2-1
kdepim-runtime 22.04.1-1 22.04.2-1
kdesdk-kioslaves 22.04.1-1 22.04.2-1
kdesdk-thumbnailers 22.04.1-1 22.04.2-1
kdevelop 22.04.1-1 22.04.2-1
kdevelop-php 22.04.1-1 22.04.2-1
kdf 22.04.1-1 22.04.2-1
kdialog 22.04.1-1 22.04.2-1
kdiamond 22.04.1-1 22.04.2-1
keditbookmarks 22.04.1-1 22.04.2-1
kfind 22.04.1-1 22.04.2-1
kfloppy 22.04.1-1 22.04.2-1
kfourinline 22.04.1-1 22.04.2-1
kgeography 22.04.1-1 22.04.2-1
kget 22.04.1-1 22.04.2-1
kgoldrunner 22.04.1-1 22.04.2-1
kgpg 22.04.1-1 22.04.2-1
khangman 22.04.1-1 22.04.2-1
khelpcenter 22.04.1-1 22.04.2-1
kidentitymanagement 22.04.1-1 22.04.2-1
kig 22.04.1-1 22.04.2-1
kigo 22.04.1-1 22.04.2-1
killbots 22.04.1-1 22.04.2-1
kimagemapeditor 22.04.1-1 22.04.2-1
kimap 22.04.1-1 22.04.2-1
kio-extras 22.04.1-1 22.04.2-1
kio-gdrive 22.04.1-1 22.04.2-1
kirigami-gallery 22.04.1-1 22.04.2-1
kiriki 22.04.1-1 22.04.2-1
kiten 22.04.1-1 22.04.2-1
kitinerary 22.04.1-2 22.04.2-1
kjumpingcube 22.04.1-1 22.04.2-1
kldap 22.04.1-1 22.04.2-1
kleopatra 22.04.1-1 22.04.2-1
klettres 22.04.1-1 22.04.2-1
klickety 22.04.1-1 22.04.2-1
klines 22.04.1-1 22.04.2-1
kmag 22.04.1-1 22.04.2-1
kmahjongg 22.04.1-1 22.04.2-1
kmail 22.04.1-1 22.04.2-1
kmail-account-wizard 22.04.1-1 22.04.2-1
kmailtransport 22.04.1-1 22.04.2-1
kmbox 22.04.1-1 22.04.2-1
kmime 22.04.1-1 22.04.2-1
kmines 22.04.1-1 22.04.2-1
kmix 22.04.1-1 22.04.2-1
kmousetool 22.04.1-1 22.04.2-1
kmouth 22.04.1-1 22.04.2-1
kmplot 22.04.1-1 22.04.2-1
knavalbattle 22.04.1-1 22.04.2-1
knetwalk 22.04.1-1 22.04.2-1
knights 22.04.1-1 22.04.2-1
knotes 22.04.1-1 22.04.2-1
kolf 22.04.1-1 22.04.2-1
kollision 22.04.1-1 22.04.2-1
kolourpaint 22.04.1-1 22.04.2-1
kompare 22.04.1-1 22.04.2-1
konqueror 22.04.1-1 22.04.2-1
konquest 22.04.1-1 22.04.2-1
konsole 22.04.1-1 22.04.2-1
kontact 22.04.1-1 22.04.2-1
kontactinterface 22.04.1-1 22.04.2-1
kontrast 22.04.1-1 22.04.2-1
konversation 22.04.1-1 22.04.2-1
kopeninghours 22.04.1-1 22.04.2-1
kopete 22.04.1-1 22.04.2-1
korganizer 22.04.1-1 22.04.2-1
kosmindoormap 22.04.1-1 22.04.2-1
kpat 22.04.1-1 22.04.2-1
kpimtextedit 22.04.1-1 22.04.2-1
kpkpass 22.04.1-1 22.04.2-1
kpmcore 22.04.1-1 22.04.2-1
kpublictransport 22.04.1-1 22.04.2-1
kqtquickcharts 22.04.1-1 22.04.2-1
krdc 22.04.1-1 22.04.2-1
kreversi 22.04.1-1 22.04.2-1
krfb 22.04.1-1 22.04.2-1
kruler 22.04.1-1 22.04.2-1
kshisen 22.04.1-1 22.04.2-1
ksirk 22.04.1-1 22.04.2-1
ksmtp 22.04.1-1 22.04.2-1
ksnakeduel 22.04.1-1 22.04.2-1
kspaceduel 22.04.1-1 22.04.2-1
ksquares 22.04.1-1 22.04.2-1
ksudoku 22.04.1-1 22.04.2-1
ksystemlog 22.04.1-1 22.04.2-1
kteatime 22.04.1-1 22.04.2-1
ktimer 22.04.1-1 22.04.2-1
ktnef 22.04.1-1 22.04.2-1
ktorrent 22.04.1-1 22.04.2-1
ktouch 22.04.1-1 22.04.2-1
ktuberling 22.04.1-1 22.04.2-1
kturtle 22.04.1-1 22.04.2-1
kubrick 22.04.1-1 22.04.2-1
kwalletmanager 22.04.1-1 22.04.2-1
kwave 22.04.1-1 22.04.2-1
kwordquiz 22.04.1-1 22.04.2-1
kwrite 22.04.1-2 22.04.2-1
ldb 2:2.5.0-1 2:2.5.1-1
libakonadi 22.04.1-2 22.04.2-1
libbluray 1.3.0-2 1.3.1-1
libbpf 0.8.0-1 -
libbytesize 2.6-3 2.7-1
libcups 1:2.4.2-1 1:2.4.2-3
libdrm 2.4.110-1 2.4.111-1
libgravatar 22.04.1-1 22.04.2-1
libkcddb 22.04.1-1 22.04.2-1
libkcompactdisc 22.04.1-1 22.04.2-1
libkdcraw 22.04.1-1 22.04.2-1
libkdegames 22.04.1-1 22.04.2-1
libkdepim 22.04.1-1 22.04.2-1
libkeduvocdocument 22.04.1-1 22.04.2-1
libkexiv2 22.04.1-1 22.04.2-1
libkgapi 22.04.1-1 22.04.2-1
libkleo 22.04.1-1 22.04.2-1
libkmahjongg 22.04.1-1 22.04.2-1
libkomparediff2 22.04.1-1 22.04.2-1
libksane 22.04.1-1 22.04.2-1
libksieve 22.04.1-1 22.04.2-1
libktorrent 22.04.1-1 22.04.2-1
liblouis 3.21.0-1 3.22.0-1
libreoffice-fresh 7.3.3-3 7.3.4-1
libreoffice-fresh-af 7.3.3-1 7.3.4-1
libreoffice-fresh-am 7.3.3-1 7.3.4-1
libreoffice-fresh-ar 7.3.3-1 7.3.4-1
libreoffice-fresh-as 7.3.3-1 7.3.4-1
libreoffice-fresh-ast 7.3.3-1 7.3.4-1
libreoffice-fresh-be 7.3.3-1 7.3.4-1
libreoffice-fresh-bg 7.3.3-1 7.3.4-1
libreoffice-fresh-bn 7.3.3-1 7.3.4-1
libreoffice-fresh-bn-in 7.3.3-1 7.3.4-1
libreoffice-fresh-bo 7.3.3-1 7.3.4-1
libreoffice-fresh-br 7.3.3-1 7.3.4-1
libreoffice-fresh-brx 7.3.3-1 7.3.4-1
libreoffice-fresh-bs 7.3.3-1 7.3.4-1
libreoffice-fresh-ca 7.3.3-1 7.3.4-1
libreoffice-fresh-ca-valencia 7.3.3-1 7.3.4-1
libreoffice-fresh-ckb 7.3.3-1 7.3.4-1
libreoffice-fresh-cs 7.3.3-1 7.3.4-1
libreoffice-fresh-cy 7.3.3-1 7.3.4-1
libreoffice-fresh-da 7.3.3-1 7.3.4-1
libreoffice-fresh-de 7.3.3-1 7.3.4-1
libreoffice-fresh-dgo 7.3.3-1 7.3.4-1
libreoffice-fresh-dsb 7.3.3-1 7.3.4-1
libreoffice-fresh-dz 7.3.3-1 7.3.4-1
libreoffice-fresh-el 7.3.3-1 7.3.4-1
libreoffice-fresh-en-gb 7.3.3-1 7.3.4-1
libreoffice-fresh-en-za 7.3.3-1 7.3.4-1
libreoffice-fresh-eo 7.3.3-1 7.3.4-1
libreoffice-fresh-es 7.3.3-1 7.3.4-1
libreoffice-fresh-et 7.3.3-1 7.3.4-1
libreoffice-fresh-eu 7.3.3-1 7.3.4-1
libreoffice-fresh-fa 7.3.3-1 7.3.4-1
libreoffice-fresh-fi 7.3.3-1 7.3.4-1
libreoffice-fresh-fr 7.3.3-1 7.3.4-1
libreoffice-fresh-fur 7.3.3-1 7.3.4-1
libreoffice-fresh-fy 7.3.3-1 7.3.4-1
libreoffice-fresh-ga 7.3.3-1 7.3.4-1
libreoffice-fresh-gd 7.3.3-1 7.3.4-1
libreoffice-fresh-gl 7.3.3-1 7.3.4-1
libreoffice-fresh-gu 7.3.3-1 7.3.4-1
libreoffice-fresh-gug 7.3.3-1 7.3.4-1
libreoffice-fresh-he 7.3.3-1 7.3.4-1
libreoffice-fresh-hi 7.3.3-1 7.3.4-1
libreoffice-fresh-hr 7.3.3-1 7.3.4-1
libreoffice-fresh-hsb 7.3.3-1 7.3.4-1
libreoffice-fresh-hu 7.3.3-1 7.3.4-1
libreoffice-fresh-id 7.3.3-1 7.3.4-1
libreoffice-fresh-is 7.3.3-1 7.3.4-1
libreoffice-fresh-it 7.3.3-1 7.3.4-1
libreoffice-fresh-ja 7.3.3-1 7.3.4-1
libreoffice-fresh-ka 7.3.3-1 7.3.4-1
libreoffice-fresh-kab 7.3.3-1 7.3.4-1
libreoffice-fresh-kk 7.3.3-1 7.3.4-1
libreoffice-fresh-km 7.3.3-1 7.3.4-1
libreoffice-fresh-kmr-latn 7.3.3-1 7.3.4-1
libreoffice-fresh-kn 7.3.3-1 7.3.4-1
libreoffice-fresh-ko 7.3.3-1 7.3.4-1
libreoffice-fresh-kok 7.3.3-1 7.3.4-1
libreoffice-fresh-ks 7.3.3-1 7.3.4-1
libreoffice-fresh-lb 7.3.3-1 7.3.4-1
libreoffice-fresh-lo 7.3.3-1 7.3.4-1
libreoffice-fresh-lt 7.3.3-1 7.3.4-1
libreoffice-fresh-lv 7.3.3-1 7.3.4-1
libreoffice-fresh-mai 7.3.3-1 7.3.4-1
libreoffice-fresh-mk 7.3.3-1 7.3.4-1
libreoffice-fresh-ml 7.3.3-1 7.3.4-1
libreoffice-fresh-mn 7.3.3-1 7.3.4-1
libreoffice-fresh-mni 7.3.3-1 7.3.4-1
libreoffice-fresh-mr 7.3.3-1 7.3.4-1
libreoffice-fresh-my 7.3.3-1 7.3.4-1
libreoffice-fresh-nb 7.3.3-1 7.3.4-1
libreoffice-fresh-ne 7.3.3-1 7.3.4-1
libreoffice-fresh-nl 7.3.3-1 7.3.4-1
libreoffice-fresh-nn 7.3.3-1 7.3.4-1
libreoffice-fresh-nr 7.3.3-1 7.3.4-1
libreoffice-fresh-nso 7.3.3-1 7.3.4-1
libreoffice-fresh-oc 7.3.3-1 7.3.4-1
libreoffice-fresh-om 7.3.3-1 7.3.4-1
libreoffice-fresh-or 7.3.3-1 7.3.4-1
libreoffice-fresh-pa-in 7.3.3-1 7.3.4-1
libreoffice-fresh-pl 7.3.3-1 7.3.4-1
libreoffice-fresh-pt 7.3.3-1 7.3.4-1
libreoffice-fresh-pt-br 7.3.3-1 7.3.4-1
libreoffice-fresh-ro 7.3.3-1 7.3.4-1
libreoffice-fresh-ru 7.3.3-1 7.3.4-1
libreoffice-fresh-rw 7.3.3-1 7.3.4-1
libreoffice-fresh-sa-in 7.3.3-1 7.3.4-1
libreoffice-fresh-sat 7.3.3-1 7.3.4-1
libreoffice-fresh-sd 7.3.3-1 7.3.4-1
libreoffice-fresh-sdk 7.3.3-3 7.3.4-1
libreoffice-fresh-si 7.3.3-1 7.3.4-1
libreoffice-fresh-sid 7.3.3-1 7.3.4-1
libreoffice-fresh-sk 7.3.3-1 7.3.4-1
libreoffice-fresh-sl 7.3.3-1 7.3.4-1
libreoffice-fresh-sq 7.3.3-1 7.3.4-1
libreoffice-fresh-sr 7.3.3-1 7.3.4-1
libreoffice-fresh-sr-latn 7.3.3-1 7.3.4-1
libreoffice-fresh-ss 7.3.3-1 7.3.4-1
libreoffice-fresh-st 7.3.3-1 7.3.4-1
libreoffice-fresh-sv 7.3.3-1 7.3.4-1
libreoffice-fresh-sw-tz 7.3.3-1 7.3.4-1
libreoffice-fresh-szl 7.3.3-1 7.3.4-1
libreoffice-fresh-ta 7.3.3-1 7.3.4-1
libreoffice-fresh-te 7.3.3-1 7.3.4-1
libreoffice-fresh-tg 7.3.3-1 7.3.4-1
libreoffice-fresh-th 7.3.3-1 7.3.4-1
libreoffice-fresh-tn 7.3.3-1 7.3.4-1
libreoffice-fresh-tr 7.3.3-1 7.3.4-1
libreoffice-fresh-ts 7.3.3-1 7.3.4-1
libreoffice-fresh-tt 7.3.3-1 7.3.4-1
libreoffice-fresh-ug 7.3.3-1 7.3.4-1
libreoffice-fresh-uk 7.3.3-1 7.3.4-1
libreoffice-fresh-uz 7.3.3-1 7.3.4-1
libreoffice-fresh-ve 7.3.3-1 7.3.4-1
libreoffice-fresh-vec 7.3.3-1 7.3.4-1
libreoffice-fresh-vi 7.3.3-1 7.3.4-1
libreoffice-fresh-xh 7.3.3-1 7.3.4-1
libreoffice-fresh-zh-cn 7.3.3-1 7.3.4-1
libreoffice-fresh-zh-tw 7.3.3-1 7.3.4-1
libreoffice-fresh-zu 7.3.3-1 7.3.4-1
librsvg 2:2.54.3-1 2:2.54.4-1
librsvg-docs 2:2.54.3-1 2:2.54.4-1
libtiff 4.3.0-2 4.4.0-1
libva-mesa-driver 22.1.1-1 22.1.1-2
libx11 1.8-1 1.8.1-2
lighttpd 1.4.64-1 1.4.65-1
lokalize 22.04.1-1 22.04.2-1
lskat 22.04.1-1 22.04.2-1
mailcommon 22.04.1-1 22.04.2-1
mailimporter 22.04.1-1 22.04.2-1
marble 22.04.1-1 22.04.2-1
marble-common 22.04.1-1 22.04.2-1
marble-maps 22.04.1-1 22.04.2-1
marble-qt 22.04.1-1 22.04.2-1
markdownpart 22.04.1-1 22.04.2-1
mbox-importer 22.04.1-1 22.04.2-1
mesa 22.1.1-1 22.1.1-2
mesa-amber 21.3.8-5 21.3.9-1
mesa-vdpau 22.1.1-1 22.1.1-2
messagelib 22.04.1-1 22.04.2-1
minuet 22.04.1-1 22.04.2-1
mlt 7.6.0-1 7.6.0-2
mtools 1:4.0.39-1 1:4.0.40-1
mutt 2.2.5-1 2.2.6-1
network-manager-applet 1.26.0-1 1.28.0-1
nftables 1:1.0.2-1 1:1.0.4-1
nginx 1.20.2-1 1.22.0-2
nginx-prometheus-exporter 0.10.0-2 0.10.0-3
nginx-src 1.20.2-1 1.22.0-2
nm-connection-editor 1.26.0-1 1.28.0-1
opencl-mesa 22.1.1-1 22.1.1-2
opencv 4.5.5-5 4.6.0-2
opencv-samples 4.5.5-5 4.6.0-2
openjdk11-src 11.0.15.u10-1 11.0.15.u10-2
openmpi 4.1.2-1 4.1.4-1
ostree 2022.3-1 2022.4-1
palapeli 22.04.1-1 22.04.2-1
parley 22.04.1-1 22.04.2-1
partitionmanager 22.04.1-1 22.04.2-1
perl-net-dns 1.33-3 1.34-1
php 8.1.6-1 8.1.7-1
php-apache 8.1.6-1 8.1.7-1
php-cgi 8.1.6-1 8.1.7-1
php-dblib 8.1.6-1 8.1.7-1
php-embed 8.1.6-1 8.1.7-1
php-enchant 8.1.6-1 8.1.7-1
php-fpm 8.1.6-1 8.1.7-1
php-gd 8.1.6-1 8.1.7-1
php-imap 8.1.6-1 8.1.7-1
php-intl 8.1.6-1 8.1.7-1
php-odbc 8.1.6-1 8.1.7-1
php-pgsql 8.1.6-1 8.1.7-1
php-phpdbg 8.1.6-1 8.1.7-1
php-pspell 8.1.6-1 8.1.7-1
php-snmp 8.1.6-1 8.1.7-1
php-sodium 8.1.6-1 8.1.7-1
php-sqlite 8.1.6-1 8.1.7-1
php-tidy 8.1.6-1 8.1.7-1
php-xsl 8.1.6-1 8.1.7-1
picmi 22.04.1-1 22.04.2-1
pim-data-exporter 22.04.1-1 22.04.2-1
pim-sieve-editor 22.04.1-1 22.04.2-1
pimcommon 22.04.1-1 22.04.2-1
pipewire-alsa 1:0.3.51-1 1:0.3.52-1
pipewire-docs 1:0.3.51-1 1:0.3.52-1
pipewire-jack 1:0.3.51-1 1:0.3.52-1
pipewire-pulse 1:0.3.51-1 1:0.3.52-1
pipewire-v4l2 1:0.3.51-1 1:0.3.52-1
pipewire-x11-bell 1:0.3.51-1 1:0.3.52-1
pipewire-zeroconf 1:0.3.51-1 1:0.3.52-1
poxml 22.04.1-1 22.04.2-1
print-manager 22.04.1-1 22.04.2-1
python-numpy 1.22.3-1 1.22.4-1
python-opencv 4.5.5-5 4.6.0-2
python-platformdirs 2.5.0-1 2.5.1-1
python-pyxdg 0.27-4 0.28-1
python-setuptools 1:60.6.0-1 1:60.10.0-1
qcachegrind 22.04.1-1 22.04.2-1
qt5-base 5.15.4+kde+r146-1 5.15.4+kde+r168-1
qt5-imageformats 5.15.4+kde+r1-1 5.15.4+kde+r2-1
qt5-script 5.15.9-2 5.15.10-1
qt5-tools 5.15.4+kde+r0-1 5.15.4+kde+r1-1
qt5-webengine 5.15.9-3 5.15.10-1
qt5-xcb-private-headers 5.15.4+kde+r146-1 5.15.4+kde+r168-1
qtcreator 7.0.2-1 7.0.2-2
qtcreator-devel 7.0.2-1 7.0.2-2
rocs 22.04.1-1 22.04.2-1
samba 4.16.1-3 4.16.1-4
signon-kwallet-extension 22.04.1-1 22.04.2-1
skanlite 22.04.1-1 22.04.2-1
skanpage 22.04.1-1 22.04.2-1
smbclient 4.16.1-3 4.16.1-4
spectacle 22.04.1-2 22.04.2-1
step 22.04.1-1 22.04.2-1
svgpart 22.04.1-1 22.04.2-1
sweeper 22.04.1-1 22.04.2-1
talloc 2.3.3-3 2.3.4-1
tdb 1.4.6-1 1.4.7-1
telepathy-kde-accounts-kcm 22.04.1-1 22.04.2-1
telepathy-kde-approver 22.04.1-1 22.04.2-1
telepathy-kde-auth-handler 22.04.1-1 22.04.2-1
telepathy-kde-call-ui 22.04.1-1 22.04.2-1
telepathy-kde-common-internals 22.04.1-1 22.04.2-1
telepathy-kde-contact-list 22.04.1-1 22.04.2-1
telepathy-kde-contact-runner 22.04.1-1 22.04.2-1
telepathy-kde-desktop-applets 22.04.1-1 22.04.2-1
telepathy-kde-filetransfer-handler 22.04.1-1 22.04.2-1
telepathy-kde-integration-module 22.04.1-1 22.04.2-1
telepathy-kde-send-file 22.04.1-1 22.04.2-1
telepathy-kde-text-ui 22.04.1-1 22.04.2-1
tevent 1:0.11.0-3 1:0.12.1-1
thunderbird 91.9.1-1 91.10.0-1
thunderbird-i18n-af 91.9.1-1 91.10.0-1
thunderbird-i18n-ar 91.9.1-1 91.10.0-1
thunderbird-i18n-ast 91.9.1-1 91.10.0-1
thunderbird-i18n-be 91.9.1-1 91.10.0-1
thunderbird-i18n-bg 91.9.1-1 91.10.0-1
thunderbird-i18n-br 91.9.1-1 91.10.0-1
thunderbird-i18n-ca 91.9.1-1 91.10.0-1
thunderbird-i18n-cak 91.9.1-1 91.10.0-1
thunderbird-i18n-cs 91.9.1-1 91.10.0-1
thunderbird-i18n-cy 91.9.1-1 91.10.0-1
thunderbird-i18n-da 91.9.1-1 91.10.0-1
thunderbird-i18n-de 91.9.1-1 91.10.0-1
thunderbird-i18n-dsb 91.9.1-1 91.10.0-1
thunderbird-i18n-el 91.9.1-1 91.10.0-1
thunderbird-i18n-en-gb 91.9.1-1 91.10.0-1
thunderbird-i18n-en-us 91.9.1-1 91.10.0-1
thunderbird-i18n-es-ar 91.9.1-1 91.10.0-1
thunderbird-i18n-es-es 91.9.1-1 91.10.0-1
thunderbird-i18n-et 91.9.1-1 91.10.0-1
thunderbird-i18n-eu 91.9.1-1 91.10.0-1
thunderbird-i18n-fi 91.9.1-1 91.10.0-1
thunderbird-i18n-fr 91.9.1-1 91.10.0-1
thunderbird-i18n-fy-nl 91.9.1-1 91.10.0-1
thunderbird-i18n-ga-ie 91.9.1-1 91.10.0-1
thunderbird-i18n-gd 91.9.1-1 91.10.0-1
thunderbird-i18n-gl 91.9.1-1 91.10.0-1
thunderbird-i18n-he 91.9.1-1 91.10.0-1
thunderbird-i18n-hr 91.9.1-1 91.10.0-1
thunderbird-i18n-hsb 91.9.1-1 91.10.0-1
thunderbird-i18n-hu 91.9.1-1 91.10.0-1
thunderbird-i18n-hy-am 91.9.1-1 91.10.0-1
thunderbird-i18n-id 91.9.1-1 91.10.0-1
thunderbird-i18n-is 91.9.1-1 91.10.0-1
thunderbird-i18n-it 91.9.1-1 91.10.0-1
thunderbird-i18n-ja 91.9.1-1 91.10.0-1
thunderbird-i18n-ka 91.9.1-1 91.10.0-1
thunderbird-i18n-kab 91.9.1-1 91.10.0-1
thunderbird-i18n-kk 91.9.1-1 91.10.0-1
thunderbird-i18n-ko 91.9.1-1 91.10.0-1
thunderbird-i18n-lt 91.9.1-1 91.10.0-1
thunderbird-i18n-ms 91.9.1-1 91.10.0-1
thunderbird-i18n-nb-no 91.9.1-1 91.10.0-1
thunderbird-i18n-nl 91.9.1-1 91.10.0-1
thunderbird-i18n-nn-no 91.9.1-1 91.10.0-1
thunderbird-i18n-pa-in 91.9.1-1 91.10.0-1
thunderbird-i18n-pl 91.9.1-1 91.10.0-1
thunderbird-i18n-pt-br 91.9.1-1 91.10.0-1
thunderbird-i18n-pt-pt 91.9.1-1 91.10.0-1
thunderbird-i18n-rm 91.9.1-1 91.10.0-1
thunderbird-i18n-ro 91.9.1-1 91.10.0-1
thunderbird-i18n-ru 91.9.1-1 91.10.0-1
thunderbird-i18n-sk 91.9.1-1 91.10.0-1
thunderbird-i18n-sl 91.9.1-1 91.10.0-1
thunderbird-i18n-sq 91.9.1-1 91.10.0-1
thunderbird-i18n-sr 91.9.1-1 91.10.0-1
thunderbird-i18n-sv-se 91.9.1-1 91.10.0-1
thunderbird-i18n-th 91.9.1-1 91.10.0-1
thunderbird-i18n-tr 91.9.1-1 91.10.0-1
thunderbird-i18n-uk 91.9.1-1 91.10.0-1
thunderbird-i18n-uz 91.9.1-1 91.10.0-1
thunderbird-i18n-vi 91.9.1-1 91.10.0-1
thunderbird-i18n-zh-cn 91.9.1-1 91.10.0-1
thunderbird-i18n-zh-tw 91.9.1-1 91.10.0-1
umbrello 22.04.1-1 22.04.2-1
upower 0.99.18-1 0.99.19-1
vim-runtime 8.2.5046-1 8.2.5046-2
vlc 3.0.17.4-2 3.0.17.4-4
vulkan-broadcom 22.1.1-1 22.1.1-2
vulkan-mesa-layers 22.1.1-1 22.1.1-2
vulkan-panfrost 22.1.1-1 22.1.1-2
vulkan-radeon 22.1.1-1 22.1.1-2
vulkan-swrast 22.1.1-1 22.1.1-2
xscreensaver 6.03-1 6.04-1
yakuake 22.04.1-1 22.04.2-1
zanshin 22.04.1-1 22.04.2-1
zeroconf-ioslave 22.04.1-1 22.04.2-1
python-nspektr - 0.4.0-1
python-trove-classifiers - 2022.5.19-1
python-validate-pyproject - 0.9-1
:: Different overlay package(s) in repository kde-unstable aarch64
akonadi22.04.1.r12759.gd279087db-122.04.2.r12766.g9b2b51157-1
akonadi-calendar22.04.1.r2116.g939d98b-122.04.2.r2124.gb9fdbb0-1
akonadi-calendar-tools22.04.1.r952.geacbf30-122.04.2.r952.geacbf30-1
akonadi-contacts22.04.1.r3178.ge3bdf2c8-122.04.2.r3187.g292eebb1-1
akonadi-import-wizard22.04.1.r1832.gb91b7a9-122.04.2.r1832.gb91b7a9-1
akonadi-mime22.04.1.r1725.g1882bb2-122.04.2.r1726.gb105bee-1
akonadi-notes22.04.1.r1075.gfbbd2dd-122.04.2.r1075.gfbbd2dd-1
akonadi-search22.04.1.r1228.g0bc6a0f-122.04.2.r1236.gb2714ea-1
akonadiconsole22.04.1.r1589.ga6d2c3e-122.04.2.r1592.gc805f1c-1
akregator22.04.1.r6422.gb24a980d-122.04.2.r6431.gf78fdc6a-1
alligator 22.04.r17.gdb0a2a2-1 22.04.r22.gafffa26-1
analitza22.04.1.r2340.ge77e2099-122.04.2.r2340.ge77e2099-1
angelfish 22.04.r27.gd8c0094-1 22.04.r30.g27f4ad5-1
ark22.04.1.r4762.g149289be-122.04.2.r4775.g71ad43ee-1
artikulate22.04.1.r1418.ge6d9441-122.04.2.r1419.g1761afe-1
attica5.94.0.r865.g735bad1-15.94.0.r866.g7be6ede-1
audiocd-kio22.04.1.r1064.g96e5180-122.04.2.r1067.g27e5dab-1
audiotube 22.04.r45.g0f111b4-1 22.04.r49.gd498d6a-1
baloo5.94.0.r3051.gbfc96abd-15.94.0.r3054.gbcc58b5a-1
baloo-widgets22.04.1.r756.g0b918ae-122.04.2.r758.g72fa5d6-1
blinken22.04.1.r667.g4c10df6-122.04.2.r670.g641a45b-1
bluedevil1:5.24.5.r2401.g75b5dc7d-11:5.24.5.r2406.g0cd64f35-1
bluez-qt5.94.0.r710.g5a4f5ef-15.94.0.r711.g0615523-1
bomber22.04.1.r562.g6920357-122.04.2.r564.gd9de16c-1
bovo22.04.1.r777.gaae9a5d-122.04.2.r779.gae412fe-1
breeze5.24.5.r2402.g9120bcb1-15.24.5.r2409.gc00fd4f4-1
breeze-icons5.94.0.r1897.g3851024f-15.94.0.r1900.gfe012918-1
calendarsupport22.04.1.r708.g42d3be6-122.04.1.r709.gc6c9b3f-1
calindori 22.04.r16.g2294fa1-1 22.04.r22.g7f3c5de-1
cervisia22.04.1.r1665.g210246c-122.04.2.r1669.g93f2f24-1
discover5.24.5.r8695.ge1aa6b37-15.24.5.r8698.gb9b40f2b-1
dolphin22.04.1.r6998.g8df1ea332-122.04.2.r7007.ga7f35a01c-1
dolphin-plugins22.04.1.r656.g768b99e-122.04.2.r661.gb08107a-1
dragon22.04.1.r1040.g114ad97-122.04.2.r1044.gd3d59ff-1
drkonqi5.24.5.r788.g91359a6a-15.24.5.r789.g662f567f-1
elisa22.04.1.r2977.g285fbb57-122.04.2.r2980.ge09c5ac0-1
elisa-qtmm22.04.1.r2977.g285fbb57-122.04.2.r2980.ge09c5ac0-1
eventviews22.04.1.r847.gc838197-122.04.1.r848.g5c7dd31-1
extra-cmake-modules5.94.0.r3485.gf4cb940b-15.94.0.r3488.g1ea9e424-1
ffmpegthumbs22.04.1.r215.g188a562-122.04.2.r220.g06b17f9-1
filelight22.04.1.r1120.g017adbe-122.04.2.r1131.g390deee-1
frameworkintegration5.94.0.r637.ga3e55e4-15.94.0.r638.g65e03e1-1
granatier22.04.1.r976.gfffaaea-122.04.2.r977.g67a6e3f-1
grantlee-editor22.04.1.r823.g0bb5f15-122.04.2.r823.g0bb5f15-1
grantleetheme22.04.1.r401.gb4f46cb-122.04.2.r401.gb4f46cb-1
gwenview22.04.1.r6854.g5e598cad-122.04.2.r6858.g7276743f-1
incidenceeditor22.04.1.r900.gf10a4ab-122.04.2.r902.g5f92a15-1
index-fm 2.1.2.r8.g29d42cc-1 2.1.2.r25.gba89ced-1
itinerary22.04.1.r1856.gca419f9-122.04.2.r1891.g225ae0e-1
juk22.04.1.r3151.g6ee00082-122.04.2.r3154.g84e9cd76-1
k3b1:22.04.1.r6783.g00198586c-11:22.04.2.r6789.g0ede72063-1
kaccounts-integration22.04.1.r1258.g95165c3-122.04.2.r1258.g95165c3-1
kaccounts-providers22.04.1.r398.g1ecceb7-122.04.2.r398.g1ecceb7-1
kactivities5.94.0.r1395.g0fa51036-15.94.0.r1396.gcf0bdeb6-1
kactivities-stats5.94.0.r407.gfbad574-15.94.0.r408.g1dfdef1-1
kactivitymanagerd5.24.5.r1400.ga300aea-15.24.5.r1401.gc6a8ee5-1
kaddressbook22.04.1.r6190.g7eb27521-122.04.2.r6202.g155ff339-1
kajongg22.04.1.r4343.g31a0eefc-122.04.2.r4344.g8e98986f-1
kalarm22.04.1.r7924.gf1ad849a-122.04.2.r7929.geaba0e02-1
kalgebra22.04.1.r2061.ge6aa7a2-122.04.2.r2063.g8b90945-1
kalk 22.04.r12.g1be3b73-1 22.04.r13.g1ef6c26-1
kalzium22.04.1.r4357.gb3c4fe43-122.04.2.r4358.gc512b24a-1
kamera22.04.1.r716.g90bfffa-122.04.2.r720.gf4ed624-1
kamoso22.04.1.r1462.gab85179-122.04.2.r1465.g9a98cf2-1
kanagram22.04.1.r1312.g7a2382d-122.04.2.r1313.gddb7b30-1
kapman22.04.1.r652.ge55596b-122.04.2.r654.g89f00ad-1
kapptemplate22.04.1.r992.gff712af-122.04.2.r994.gd63178c-1
karchive5.94.0.r543.g0288029-15.94.0.r545.g09b9002-1
kasts 22.04.r38.gcc480fa-1 22.04.r49.g7254d08-1
kate22.04.1.r19070.g378d8b51d-122.04.2.r19102.g78126c435-1
katomic22.04.1.r959.g00ed714-122.04.2.r960.g4e950df-1
kauth5.94.0.r498.g4e32555-15.94.0.r499.ge7d71ac-1
kbackup22.04.1.r438.ge32cf3a-122.04.2.r441.ga3fe030-1
kblackbox22.04.1.r764.g76662e9-122.04.2.r766.g62e4564-1
kblocks22.04.1.r715.g8eb2d1c-122.04.2.r716.g1e4294b-1
kbookmarks5.94.0.r460.g7a369da-15.94.0.r461.g6a19b06-1
kbounce22.04.1.r847.g1bfd57c-122.04.2.r848.g3cbb1f2-1
kbreakout22.04.1.r917.g5180bf9-122.04.2.r919.g15eb32e-1
kbruch22.04.1.r864.gb4f073b-122.04.2.r867.g0aa5d3c-1
kcachegrind22.04.1.r1182.g1d2150e-122.04.2.r1184.g2a25c3e-1
kcachegrind-common22.04.1.r1182.g1d2150e-122.04.2.r1184.g2a25c3e-1
kcalc22.04.1.r1611.g38321ea-122.04.2.r1613.g324280d-1
kcalendarcore5.94.0.r1324.g2fffbf0a0-15.94.0.r1325.gb4366b936-1
kcalutils22.04.1.r966.g868c4edf0-122.04.2.r966.g868c4edf0-1
kcharselect22.04.1.r530.ge9392f7-122.04.2.r531.gf5b0724-1
kclock 22.04.r20.g484da38-1 22.04.r22.gf3d3929-1
kcmutils5.94.0.r639.g63ea6c2-15.94.0.r641.g9cb74ec-1
kcodecs5.94.0.r421.ga188c7d-15.94.0.r422.g80d6a55-1
kcolorchooser22.04.1.r271.ga611715-122.04.2.r272.g774e0b7-1
kcompletion5.94.0.r493.g3fbc676-15.94.0.r494.gd0b541b-1
kconfig5.94.0.r957.g4785f8ad-15.94.0.r958.g4e51b692-1
kconfigwidgets5.94.0.r741.gf0ae5fd-15.94.0.r742.gafadfea-1
kcontacts1:5.94.0.r3333.gb2946319-11:5.94.0.r3334.g08d12955-1
kcoreaddons5.94.0.r1496.gdb6eb80f-15.94.0.r1503.g21e10c10-1
kcrash5.94.0.r445.gee91713-15.94.0.r447.gb01f547-1
kcron22.04.1.r843.g2ba816a-122.04.2.r845.g73f6e5b-1
kdav1:5.94.0.r1342.gb3fc940-11:5.94.0.r1343.g643e335-1
kdbusaddons5.94.0.r415.gb2c970d-15.94.0.r416.g1e67d39-1
kde-cli-tools5.24.5.r1937.gd428644-15.24.5.r1940.gdc0c68a-1
kde-dev-scripts22.04.1.r4146.g04f44a1-122.04.2.r4146.g04f44a1-1
kde-dev-utils22.04.1.r584.g58b1425-122.04.2.r589.ga98af95-1
kdebugsettings22.04.1.r925.g9fbafb4-122.04.2.r926.ga6d383b-1
kdeclarative5.94.0.r1003.gac048c3-15.94.0.r1004.g48fc37d-1
kdeconnect22.04.1.r3457.g0f3d60b6-122.04.2.r3463.gf4b1f842-1
kded5.94.0.r460.gbf1c2be-15.94.0.r461.g656e8fc-1
kdeedu-data22.04.1.r17.g1b749b8-122.04.2.r17.g1b749b8-1
kdegraphics-mobipocket22.04.1.r272.ge2624e9-122.04.2.r273.g416f47e-1
kdegraphics-thumbnailers22.04.1.r266.g79fe9b1-122.04.2.r270.g49c71ed-1
kdelibs4support5.94.0.r1087.g2bd98825-15.94.0.r1089.g7834c9f4-1
kdenetwork-filesharing22.04.1.r944.g4976d62-122.04.2.r948.gf5b9946-1
kdenlive22.04.1.r16174.g6e90d733e-122.04.2.r16231.g8d9869d25-1
kdepim-addons22.04.1.r4665.g097aca1df-122.04.2.r4672.ge3d9c7822-1
kdepim-runtime22.04.1.r15535.g9dd2c1dd9-122.04.2.r15546.g9e6daf04f-1
kdeplasma-addons5.24.5.r8850.g51d71ab62-15.24.5.r8857.g6f47e15fd-1
kdesdk-kioslaves22.04.1.r503.g5a8c59f-122.04.2.r503.g5a8c59f-1
kdesdk-thumbnailers22.04.1.r91.g97befb5-122.04.2.r91.g97befb5-1
kdesignerplugin5.94.0.r353.g8d42012-15.94.0.r354.gb096102-1
kdesu5.94.0.r506.g5a84e16-15.94.0.r507.g1ea4137-1
kdewebkit5.94.0.r301.g7d36253-15.94.0.r302.gc988bec-1
kdf22.04.1.r853.g521e3fa-122.04.2.r857.gd210dbe-1
kdialog22.04.1.r1224.gc7b369b79-122.04.2.r1226.gbd2024735-1
kdiamond22.04.1.r724.g21568bd-122.04.2.r725.gebc5929-1
kdnssd5.94.0.r349.g10b41e7-15.94.0.r350.gddacb9c-1
kdoctools5.94.0.r659.gf4cbcba-15.94.0.r661.g260675e-1
keditbookmarks22.04.1.r2765.ge15b5e87e-122.04.2.r2765.ge15b5e87e-1
kemoticons5.94.0.r415.gb27ee59-15.94.0.r416.gd9d73b7-1
keysmith 22.04.r10.gcf38cf5-1 22.04.r14.g40ba9f6-1
kfilemetadata5.94.0.r861.g1ca01a7-15.94.0.r862.gf5bfc2f-1
kfind22.04.1.r2692.ge44c66716-122.04.2.r2697.g8c0c4d5cb-1
kfloppy22.04.1.r793.gbdac023-122.04.2.r794.gd3a1176-1
kfourinline22.04.1.r1026.g31fef80-122.04.2.r1027.g7155641-1
kgamma55.24.5.r476.ga605082-15.24.5.r477.g85a4bf9-1
kgeography22.04.1.r1156.ga2c1e95-122.04.2.r1158.g2855b54-1
kget22.04.1.r3196.gbd473aa0-122.04.2.r3201.gd47ea836-1
kglobalaccel5.94.0.r521.g9e9bcbd-15.94.0.r524.g1a8e8cb-1
kgoldrunner22.04.1.r1279.g67e6a0e-122.04.2.r1280.g6a6c08a-1
kgpg22.04.1.r3188.g181a0531-122.04.2.r3191.g5d3c044b-1
kguiaddons5.94.0.r471.g04ddcec-15.94.0.r472.gcf020f9-1
khangman22.04.1.r1610.g60d1f6d-122.04.2.r1612.g64cb6a6-1
khealthcertificate 22.04.r6.g8303996-1 22.04.r7.gd34cbfe-1
khelpcenter22.04.1.r2741.gd73cacfc-122.04.2.r2744.g98d313b0-1
kholidays1:5.94.0.r1035.ge977380-11:5.94.0.r1037.g6d647f4-1
khotkeys5.24.5.r2135.g8a37a03-15.24.5.r2137.gf1891e9-1
khtml5.94.0.r583.g20ea224-15.94.0.r586.gd37fa51-1
ki18n5.94.0.r554.g5fc3c06-15.94.0.r556.g3708d6a-1
kiconthemes5.94.0.r600.g584acbd-15.94.0.r602.geb2035a-1
kidentitymanagement22.04.1.r3889.ga02996b3-122.04.2.r3889.ga02996b3-1
kidletime5.94.0.r355.g4fd7c98-15.94.0.r356.g9a34611-1
kig22.04.1.r3187.gcc961512-122.04.2.r3188.g91e0bee1-1
kigo22.04.1.r566.gfcb40dc-122.04.2.r567.g0fb4a28-1
killbots22.04.1.r787.ga67b1c7-122.04.2.r788.gbdde38e-1
kimageformats5.94.0.r403.g2a84dd6-15.94.0.r404.g2aec1d3-1
kimagemapeditor22.04.1.r489.g67a89e9-122.04.2.r493.ge1a2e5c-1
kimap22.04.1.r1194.gb218217-122.04.2.r1194.gb218217-1
kinfocenter5.24.5.r2092.g974b5ff3-15.24.5.r2095.ga42bb35c-1
kinit5.94.0.r436.ge3dc918-15.94.0.r437.gcb24988-1
kio5.94.0.r5494.g41463b985-15.94.0.r5502.gfbddc3c07-1
kio-extras22.04.1.r7250.gfccd1735-122.04.2.r7257.g41a6d351-1
kio-gdrive22.04.1.r599.gb0961ad-122.04.2.r604.gcc3dac9-1
kirigami-addons 1:0.2.r30.g762eea5-1 1:0.2.r31.g891a36e-1
kirigami-gallery22.04.1.r240.g7efbc75-122.04.2.r242.g389a897-1
kirigami25.94.0.r3141.gd03c06bf-15.94.0.r3146.g43751efe-1
kiriki22.04.1.r450.ga635e3d-122.04.2.r451.g67b9e37-1
kitemmodels5.94.0.r606.g8457927-15.94.0.r607.gc02f2d8-1
kitemviews5.94.0.r370.g8cd9580-15.94.0.r371.g99465ed-1
kiten22.04.1.r1184.g2c622ae-122.04.2.r1185.g1e0da08-1
kitinerary22.04.1.r2219.gc1a37a6-122.04.2.r2245.gc93acfe-1
kjobwidgets5.94.0.r414.g307dbce-15.94.0.r415.ge8239db-1
kjs5.94.0.r361.gcbe7055-15.94.0.r362.gdb0d84f-1
kjsembed5.94.0.r325.ga813cb8-15.94.0.r326.gae85182-1
kjumpingcube22.04.1.r823.g17122ff-122.04.2.r824.gd091b62-1
kldap22.04.1.r949.g58c9601-122.04.2.r949.g58c9601-1
kleopatra22.04.1.r6537.g76ae38e3-122.04.2.r6555.g8d50e6ad-1
klettres22.04.1.r961.g9b1866e-122.04.2.r962.g3c4ed84-1
klickety22.04.1.r672.g16a6f22-122.04.2.r673.gd8d1a11-1
klines22.04.1.r814.ge126fa0-122.04.2.r815.gd0e2223-1
kmag22.04.1.r734.g744b1d5-122.04.2.r736.g4a8ca00-1
kmahjongg22.04.1.r1529.gb0a401b-122.04.2.r1549.g687c34a-1
kmail22.04.1.r26392.g6bbf6d36c-122.04.2.r26412.gdf82fa4fe-1
kmail-account-wizard22.04.1.r883.g23a736d-122.04.2.r886.g50bd247-1
kmailtransport22.04.1.r1744.g6e1b2a5-122.04.2.r1744.g6e1b2a5-1
kmbox22.04.1.r597.gfe3edbc-122.04.2.r598.g4fba26c-1
kmediaplayer5.94.0.r316.g7df07d1-15.94.0.r317.g5843afa-1
kmenuedit5.24.5.r1040.ge91b389-15.24.5.r1041.gdf1efd2-1
kmime22.04.1.r1515.gbefbbea-122.04.2.r1517.g6bf8b7b-1
kmines22.04.1.r1764.g423ef92-122.04.2.r1765.g80458c8-1
kmix22.04.1.r2450.gf456545b-122.04.2.r2451.g9bb7ee36-1
kmousetool22.04.1.r439.geece315-122.04.2.r444.g9be51b9-1
kmouth22.04.1.r728.gdb7edab-122.04.2.r728.gdb7edab-1
kmplot22.04.1.r1492.gec52b32-122.04.2.r1495.g8c295cd-1
knavalbattle22.04.1.r1429.ge9b2a89-122.04.2.r1430.gc88b30f-1
knetwalk22.04.1.r699.g9298298-122.04.2.r700.gca8f4f9-1
knewstuff5.94.0.r1339.gcbe3424b-15.94.0.r1349.g4b2e1167-1
knights22.04.1.r1135.gff96c28-122.04.2.r1140.g298b00e-1
knotes22.04.1.r3659.g5d27b365-122.04.2.r3667.ge1c43fc8-1
knotifications5.94.0.r738.g774a5de-15.94.0.r739.g0cdaaae-1
knotifyconfig5.94.0.r381.g151f62c-15.94.0.r383.g5ea70c4-1
koko 22.04.r17.g1865e46-1 22.04.r22.gf90b596-1
kolf22.04.1.r1500.gb8e43ca-122.04.2.r1501.g4c15e42-1
kollision22.04.1.r534.ga766f3a-122.04.2.r535.gcb67278-1
kolourpaint22.04.1.r2408.g37c2d3c3-122.04.2.r2410.g897e92cb-1
kompare22.04.1.r1136.gab3f8d4-122.04.2.r1141.ga5986f0-1
kongress 22.04.r9.g9dd537d-1 22.04.r15.gb1d311a-1
konqueror22.04.1.r15112.g56f85cd95-122.04.2.r15118.g709bc77f1-1
konquest22.04.1.r929.g7c7f67f-122.04.2.r930.gdaf22b6-1
konsole22.04.1.r8449.g2d70ab55-122.04.2.r8467.gdff5c1fa-1
kontact22.04.1.r5519.g16392876-122.04.2.r5533.g1ccb9b7a-1
kontactinterface22.04.1.r687.g87fdf44-122.04.2.r691.g76e2942-1
kontrast22.04.1.r202.g3659c12-122.04.2.r207.gac08e3d-1
konversation22.04.1.r9112.gf9d8ae6a-122.04.2.r9117.g06251138-1
kopeninghours22.04.1.r330.gdb6b104-122.04.2.r331.g9676833-1
kopete22.04.1.r16433.gc77173ad5-122.04.2.r16437.gd6e89297d-1
korganizer22.04.1.r11707.gd261b0211-122.04.2.r11718.gd3205f8c3-1
kosmindoormap22.04.1.r732.ge99d511-122.04.2.r734.gc9b32b7-1
kpackage5.94.0.r750.gc1ad10e-15.94.0.r751.g8faa108-1
kparts5.94.0.r584.gefa998b-15.94.0.r585.g23de3a2-1
kpat22.04.1.r2614.g4f013c2c-122.04.2.r2617.g36da91eb-1
kpeople5.94.0.r1374.g2ebb48c-15.94.0.r1375.g48fd77a-1
kpimtextedit22.04.1.r1596.g4170e58-122.04.2.r1596.g4170e58-1
kpipewire5.24.5.r105.g72fa8bb-15.24.5.r110.gf5dd13a-1
kpkpass22.04.1.r297.ge731000-122.04.2.r297.ge731000-1
kplotting5.94.0.r322.g4bfe58d-15.94.0.r323.g7174d74-1
kpmcore22.04.1.r1284.g9b01566-122.04.2.r1285.geb50358-1
kpty5.94.0.r373.g5e4980c-15.94.0.r374.g593dc86-1
kpublictransport22.04.1.r2017.g54bb9816-122.04.2.r2020.gb732d04e-1
kqtquickcharts22.04.1.r75.g188b79d-122.04.2.r75.g188b79d-1
kquickcharts5.94.0.r517.g3c721a6-15.94.0.r518.g467561f-1
kquickimageeditor r69.g43b8194-1 r70.gbe39cdb-1
krdc22.04.1.r1592.gc237f21-122.04.2.r1595.g239d395-1
krecorder 22.04.r19.g06cce4f-1 22.04.r20.gea2d0f5-1
kreversi22.04.1.r1269.gbd50ef9-122.04.2.r1270.g3425b3c-1
krfb22.04.1.r1492.ga03b8db-122.04.2.r1495.g1722292-1
kross5.94.0.r357.ge05a14d-15.94.0.r358.ge186dad-1
kross-interpreters22.04.1.r724.g2a6213a-122.04.2.r724.g2a6213a-1
kruler22.04.1.r734.g21ce109-122.04.2.r735.g9fc56a2-1
krunner5.94.0.r762.g70aed4a-15.94.0.r765.g8410293-1
kscreen5.24.5.r1471.g0999a68-15.24.5.r1472.g7811d81-1
kscreenlocker5.24.5.r949.gfdbba67-15.24.5.r952.ge851369-1
kservice5.94.0.r1009.g4414310-15.94.0.r1014.g48b10de-1
kshisen22.04.1.r1240.gf1014dc-122.04.2.r1243.g6ab1cb6-1
ksirk22.04.1.r1028.g459f181-122.04.2.r1029.ga5a331e-1
ksmtp22.04.1.r448.gce2f022-122.04.2.r448.gce2f022-1
ksnakeduel22.04.1.r845.g98212bf-122.04.2.r846.g0dde9cf-1
kspaceduel22.04.1.r670.g7b70f7b-122.04.2.r671.gb7accb7-1
ksquares22.04.1.r557.g25e8a9d-122.04.2.r558.g2abf6be-1
ksudoku22.04.1.r1109.g2d10bad-122.04.2.r1111.gb89b6d8-1
ksysguard5.24.5.r3529.g7b55ce26-15.24.5.r3530.gcfa80101-1
ksystemlog22.04.1.r725.gfd529f3-122.04.2.r730.g09e735a-1
kteatime22.04.1.r757.g78f972a-122.04.2.r758.g3f8f2a0-1
ktexteditor5.94.0.r3410.g025f9564-15.94.0.r3413.g895524a2-1
ktextwidgets5.94.0.r446.g806cb54-15.94.0.r447.g2adcaa6-1
ktimer22.04.1.r516.g4f99c76-122.04.2.r517.gcdcc455-1
ktnef22.04.1.r718.g42c3edb-122.04.2.r718.g42c3edb-1
ktorrent22.04.1.r2850.g63207e50-122.04.2.r2856.g88ed88d5-1
ktouch22.04.1.r2180.g98899a2-122.04.2.r2182.g510b582-1
ktrip 22.04.r7.g1bd4e07-1 22.04.r10.g0787d0f-1
ktuberling22.04.1.r1040.g780576d-122.04.2.r1042.g10bbd81-1
kturtle22.04.1.r1169.gfebebfd-122.04.2.r1171.ga68e065-1
kubrick22.04.1.r406.ge35698b-122.04.2.r407.g92980bc-1
kunitconversion5.94.0.r416.ge792664-15.94.0.r417.g8fcc890-1
kwallet5.94.0.r1146.gf72cf1e-15.94.0.r1150.g26b7551-1
kwalletmanager22.04.1.r1270.gaa26133-122.04.2.r1271.g20e42b5-1
kwave22.04.1.r3789.gfb7131f9-122.04.2.r3794.g1b4d6e6b-1
kwayland5.94.0.r1162.g590cc34-15.94.0.r1163.g6f94454-1
kweather 22.04.r24.gaa8962a-1 22.04.r25.g83a4e48-1
kweathercore 0.5.r27.gdb88280-1 0.5.r28.g654cd01-1
kwidgetsaddons5.94.0.r942.ga3ab1de6-15.94.0.r943.g41da9dda-1
kwin5.24.5.r22559.g529c3c29d-15.24.5.r22576.gdc9c431fe-1
kwindowsystem5.94.0.r681.gf6a55f0-15.94.0.r683.gc3fa9ca-1
kwordquiz22.04.1.r1180.g8d04f58-122.04.2.r1183.g3c7c07d-1
kwrite22.04.1.r19070.g378d8b51d-122.04.2.r19102.g78126c435-1
kxmlgui5.94.0.r877.g891ffe59-15.94.0.r882.gb025ee95-1
kxmlrpcclient5.94.0.r480.g6f28e610d-15.94.0.r481.g0d4d74420-1
layer-shell-qt5.24.5.r58.g563b61c-15.24.5.r59.g34e7c90-1
libakonadi22.04.1.r12759.gd279087db-122.04.2.r12766.g9b2b51157-1
libgravatar22.04.1.r424.g29c8756-122.04.2.r424.g29c8756-1
libkcddb22.04.1.r762.gca224c5-122.04.2.r762.gca224c5-1
libkcompactdisc22.04.1.r396.g25896b1-122.04.2.r396.g25896b1-1
libkdcraw22.04.1.r1153.ga4a99cf-122.04.2.r1153.ga4a99cf-1
libkdegames22.04.1.r2233.gfef5ac21-122.04.2.r2233.gfef5ac21-1
libkdepim22.04.1.r908.g024c373-122.04.2.r908.g024c373-1
libkeduvocdocument22.04.1.r1810.g5b20cc7-122.04.2.r1810.g5b20cc7-1
libkexiv222.04.1.r823.g6dce742-122.04.2.r823.g6dce742-1
libkgapi22.04.1.r1363.g765620a-122.04.2.r1363.g765620a-1
libkipi22.04.1.r1278.g4ec0a9a-122.04.2.r1279.g5b90094-1
libkleo22.04.1.r1173.gb8a0ab7-122.04.2.r1173.gb8a0ab7-1
libkmahjongg22.04.1.r481.g848e1a2-122.04.2.r481.g848e1a2-1
libkomparediff222.04.1.r342.gf465f1a-122.04.2.r342.gf465f1a-1
libksane22.04.1.r596.gccb6b71-122.04.2.r596.gccb6b71-1
libksieve22.04.1.r1703.g9ba9ef59-122.04.2.r1717.gbd666860-1
libktorrent22.04.1.r548.g361f3ce-122.04.2.r548.g361f3ce-1
lokalize22.04.1.r1823.gb2d57a27-122.04.2.r1828.g20cd498c-1
lskat22.04.1.r852.gc0fb883-122.04.2.r853.g3bbd499-1
mailcommon22.04.1.r1243.g63d153e-122.04.2.r1243.g63d153e-1
mailimporter22.04.1.r519.gc5d4208-122.04.2.r520.g659950e-1
marble22.04.1.r13438.ga78addf66-122.04.2.r13445.gc8d57df6e-1
marble-common22.04.1.r13438.ga78addf66-122.04.2.r13445.gc8d57df6e-1
marble-qt22.04.1.r13438.ga78addf66-122.04.2.r13445.gc8d57df6e-1
markdownpart22.04.1.r120.gc3962f1-122.04.2.r125.g7e27b35-1
maui-clip 2.1.2.r2.ge76ba55-1 2.1.2.r4.g335a9dd-1
maui-nota 2.1.2.r2.gfdf52b1-1 2.1.2.r5.g44f8193-1
maui-pix 2.1.2.r5.gdb21d28-1 2.1.2.r8.gc5ad85f-1
maui-shell 0.5.0.r30.ge3892ea-1 0.5.0.r31.g7cfc7c8-1
mauikit-accounts 2.1.2.r0.g0efebb4-1 2.1.2.r2.g4338583-1
mauikit-filebrowsing 2.1.2.r3.ga3bceae-1 2.1.2.r5.ge9136cf-1
mauikit-imagetools 2.1.2.r1.gd696757-1 2.1.2.r2.gb58ccc3-1
mauikit-texteditor 2.1.2.r1.ga683ed4-1 2.1.2.r3.g17e1da7-1
mbox-importer22.04.1.r568.g198ae0a-122.04.2.r568.g198ae0a-1
messagelib22.04.1.r6572.gdb0ba0243-122.04.2.r6576.g546a6f306-1
minuet22.04.1.r608.g8c15a22-122.04.2.r611.g9dd35fc-1
modemmanager-qt5.94.0.r553.g1dba164-15.94.0.r554.g1427c53-1
neochat22.04.r57.g7216da8b-122.04.r72.g72994d03-1
networkmanager-qt5.94.0.r1152.g99619ac-15.94.0.r1153.gb3af371-1
okular22.04.1.r9742.g86a7a2996-122.04.2.r9754.g12a222c95-1
oxygen5.24.5.r4479.g9460d56e-15.24.5.r4482.g301b69e8-1
palapeli22.04.1.r1281.g6c360f5-122.04.2.r1284.gf1a4bbd-1
parley22.04.1.r4521.g5060a646-122.04.2.r4523.g0acdabee-1
partitionmanager22.04.1.r1622.g003915b-122.04.2.r1629.g64c42a2-1
picmi22.04.1.r563.gabee479-122.04.2.r563.gabee479-1
pim-data-exporter22.04.1.r2754.g6d764277-122.04.2.r2757.gf9ca308b-1
pim-sieve-editor22.04.1.r1626.geca54df-122.04.2.r1628.g27329f5-1
pimcommon22.04.1.r1242.gac0c486-122.04.1.r1243.g223bd77-1
plasma-browser-integration5.24.5.r1325.g46a77d32-15.24.5.r1327.gebbdb0f0-1
plasma-camera 1.0.r123.g17c5e71-1 1.0.r125.gd3e8648-1
plasma-desktop5.24.5.r9309.g9364198f5-15.24.5.r9319.gf251558c6-1
plasma-dialer 22.04.r27.g53e5203-1 22.04.r32.g69bbfa4-1
plasma-disks5.24.5.r274.g32df7a5-15.24.5.r275.gb7ad094-1
plasma-firewall5.24.5.r624.g78094b1-15.24.5.r625.g0b29f4c-1
plasma-framework5.94.0.r16322.g8eac3ff4e-15.94.0.r16337.gd444c3452-1
plasma-mobile5.24.5.r1806.gf1bce20b3-15.24.5.r1818.g23b4ad1f0-1
plasma-mobile-nm5.24.5.r3253.g0a9f212c-15.24.5.r3256.g5af8b689-1
plasma-nano5.24.5.r185.g2e66026-15.24.5.r186.g8422e10-1
plasma-nm5.24.5.r3253.g0a9f212c-15.24.5.r3256.g5af8b689-1
plasma-phonebook 22.04.r17.g81ce887-1 22.04.r20.g9294660-1
plasma-remotecontrollers r89.g177174f-1 r90.gaa77d1e-1
plasma-sdk5.24.5.r2358.g1d9daac3-15.24.5.r2361.g87b50a99-1
plasma-settings 22.04.r34.gaf06a8b-1 22.04.r40.gff651c4-1
plasma-systemmonitor5.24.5.r570.g3731b7d-15.24.5.r571.g651908a-1
plasma-vault5.24.5.r381.g5d8ad5f-15.24.5.r382.gd5bb749-1
plasma-wayland-protocols1.4.0.r1053.g26fb07b-11.4.0.r1054.g0469915-1
plasma-wayland-session5.24.5.r11900.gb76853389-15.24.5.r11940.g0e699f49e-1
plasma-workspace5.24.5.r11900.gb76853389-15.24.5.r11940.g0e699f49e-1
plasma-workspace-wallpapers5.24.5.r342.g8aa7dcf-15.24.5.r347.g6f61fb5-1
plasmatube 22.04.r12.g56bd023-1 22.04.r13.g8b9e1aa-1
polkit-kde-agent5.24.5.r524.g65e424a-15.24.5.r525.g56ad717-1
powerdevil5.24.5.r2544.ge5eb9745-15.24.5.r2547.g278f9d25-1
poxml22.04.1.r282.g2615361-122.04.2.r282.g2615361-1
print-manager22.04.1.r1133.g0287b75-122.04.2.r1134.g2c584b8-1
prison5.94.0.r384.gb4051ac-15.94.0.r386.g33118b8-1
purpose5.94.0.r971.g6fa1d78-15.94.0.r974.g08006d7-1
qcachegrind22.04.1.r1182.g1d2150e-122.04.2.r1184.g2a25c3e-1
qmlkonsole 22.04.r26.g3bb424f-1 22.04.r31.gba5ce5f-1
qqc2-breeze-style5.24.5.r244.g28c6153-15.24.5.r247.g0a28fc4-1
qqc2-desktop-style5.94.0.r616.g25f20bd-15.94.0.r622.gae16062-1
rocs22.04.1.r3078.g96aa2bff-122.04.2.r3081.gc6ae7d1f-1
sddm-kcm5.24.5.r654.g77052b0-15.24.5.r657.g74e187b-1
signon-kwallet-extension22.04.1.r79.g87b0c1e-122.04.2.r79.g87b0c1e-1
solid5.94.0.r768.g626fa4a-15.94.0.r769.g48bdc56-1
sonnet5.94.0.r695.g4eb8f88-15.94.0.r696.g9b0f16a-1
spacebar 22.04.r20.gcaa6b4d-1 22.04.r23.g48fc06d-1
spectacle22.04.1.r1351.ge28ba9c-122.04.2.r1354.ge1253ee-1
step22.04.1.r1188.g7e7857c-122.04.2.r1191.g63fe411-1
svgpart22.04.1.r220.g9edc716-122.04.2.r224.g406ed03-1
sweeper22.04.1.r569.g765b3dd-122.04.2.r572.g3bc29ce-1
syndication5.94.0.r871.g01aacf0-15.94.0.r872.ge2f42e9-1
syntax-highlighting5.94.0.r1834.g8664e6eb-15.94.0.r1836.g3557b4fd-1
systemsettings5.24.5.r2666.g702017f0-15.24.5.r2667.g6a7c670b-1
telepathy-kde-accounts-kcm22.04.1.r1215.gd84ca0c-122.04.2.r1216.ga98e69c-1
telepathy-kde-approver22.04.1.r304.geea421c-122.04.2.r304.geea421c-1
telepathy-kde-auth-handler22.04.1.r283.gece2e65-122.04.2.r283.gece2e65-1
telepathy-kde-call-ui22.04.1.r449.g4c30cd2-122.04.2.r449.g4c30cd2-1
telepathy-kde-common-internals22.04.1.r2014.gb1c99ea-122.04.2.r2016.gc63b3dc-1
telepathy-kde-contact-list22.04.1.r1091.gbad1b7a-122.04.2.r1091.gbad1b7a-1
telepathy-kde-contact-runner22.04.1.r260.g5ccf4e3-122.04.2.r260.g5ccf4e3-1
telepathy-kde-desktop-applets22.04.1.r1003.g1b9eb63-122.04.2.r1003.g1b9eb63-1
telepathy-kde-filetransfer-handler22.04.1.r226.g89862cf-122.04.2.r226.g89862cf-1
telepathy-kde-integration-module22.04.1.r400.gd2643d8-122.04.2.r400.gd2643d8-1
telepathy-kde-send-file22.04.1.r235.ga2969bb-122.04.2.r235.ga2969bb-1
telepathy-kde-text-ui22.04.1.r2040.g8a4bd81-122.04.2.r2043.ga0f4b60-1
threadweaver5.94.0.r539.g557d9bd-15.94.0.r540.g0a6e3c2-1
tokodon 22.04.r41.gc80bd74-1 22.04.r45.g16da6cf-1
umbrello22.04.1.r8467.g695802346-122.04.2.r8470.ge68f65b97-1
vakzination 22.04.r22.gac91dc7-1 22.04.r26.g31dc285-1
vvave 2.1.2.r9.g950ed58-1 2.1.2.r16.g4db7199-1
xdg-desktop-portal-kde5.24.5.r491.g9699dfd-15.24.5.r495.g9865283-1
yakuake22.04.1.r795.gb3e81b2-122.04.2.r796.gf0f382b-1
zeroconf-ioslave22.04.1.r383.gd599d47-122.04.2.r385.gd0d85c6-1
- Run this command to switch branch:
sudo pacman-mirrors -aS testing && sudo pacman -Syyu
. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
0 voters
