When I launch Bitwarden it throws a error on Arm64
[corey@manjaro-pi ~]$ bitwarden-desktop
App threw an error during load
Error: The module '/tmp/.org.chromium.Chromium.DwCGLx'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 85. This version of Node.js requires
NODE_MODULE_VERSION 87. Please try re-compiling or re-installing
the module (for instance, using `npm rebuild` or `npm install`).
at process.func [as dlopen] (electron/js2c/asar_bundle.js:5:1846)
at Object.Module._extensions..node (internal/modules/cjs/loader.js:1138:18)
at Object.func [as .node] (electron/js2c/asar_bundle.js:5:2073)
at Module.load (internal/modules/cjs/loader.js:935:32)
at Module._load (internal/modules/cjs/loader.js:776:14)
at Function.f._load (electron/js2c/asar_bundle.js:5:12789)
at Module.require (internal/modules/cjs/loader.js:959:19)
at require (internal/modules/cjs/helpers.js:88:18)
at Object.<anonymous> (/usr/lib/bitwarden/resources/app.asar/node_modules/desktop-idle/index.js:1:21)
at Module._compile (internal/modules/cjs/loader.js:1078:30)
A JavaScript error occurred in the main process
Uncaught Exception:
