Bind mount a folder
if anybody is looking for bind mount, here is a guide:
https://utcc.utoronto.ca/~cks/space/blog/linux/SystemdBindMountUnits
Edit:- Moved from Support to Feedback.
I’ve moved it back. :stuck_out_tongue:
I agree that it doesn’t really belong in Support, but then again, it also doesn’t belong in Feedback, nor does it meet the criteria for Tutorials. :thinking: :man_shrugging:
Maybe:
  • Contributions → Helpful Comments ?
  • Contributions → Tips and Tricks ?
  • Contributions → Suggestions ?
(It just didn’t [still doesn’t] sit right in Support) :man_shrugging:
However, there was a recent thread on the topic…
perhaps it would fit there.
Nevermind; maybe it wasn’t so recent.
Moderators cannot create forum categories — only administrators can do that — but it does sound like a good suggestion. :+1:
@Yochanan?
Are you sure about that?
Remember, this is a support forum, not a social network. If a topic does not fit in a category, then it most likely doesn’t belong here. :wink:
@JPT Thanks for sharing, however that would be better suited to post things like that on our unofficial Manjaro subreddit or unofficial Manjaro Lemmy instance.
