/bin in the $PATH variable when installing KDE Edition via Architect Installer.
As the title says, /bin is in the $PATH variable on plasma-desktop and everywhere in the desktop (Konsole and other terminals, all the shells- zsh, bash etc). This is causing apps like Netbeans to not start as the startup script requires to be launched from /usr/bin/ instead.
I know that /bin should not be in the $PATH variable and that is the case when I’m ssh-ing into the machine or running echo $PATH in a tty. See below-
Running echo $PATH from Konsole inside Plasma Desktop-
~ >>> echo $PATH
/bin:/usr/local/sbin:/usr/local/bin:/usr/bin:/var/lib/flatpak/exports/bin:/usr/lib/jvm/default/bin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
Running echo $PATH from tty2-
~ >>> echo $PATH
Couldn’t find anything relevant which would cause the bug in .zshrc, .bashrc, .bash_profile etc files. Also this bug only happens in architect installation (kde full + zsh shell). It doesn’t happen in regular install from KDE ISO, even after manually installing zsh with manjaro stuffs.
So this is definitely an Architect-only bug.
Any help is appreciated.
Best regards.
Depends how you did the search and if you connected the dots. :slight_smile: Se here:
The /bin folder is completely normal and on Arch based distributions it is symlinked to /usr/bin.
~ >>> echo $PATH
/usr/bin:/bin:/usr/local/sbin:/usr/bin/site_perl:/usr/bin/vendor_perl:/usr/bin/core_perl
