Bonjour,
Comment puis-je installer Bibisco sur Manjaro SVP ? le lien du site !
How do I install Bibisco on Manjaro, please? link to see !
Merci
La documentation répond à la question, c’est la version zip avec Manjaro.
« Veuillez excuser ma réponse en anglais. »
Also I would be sure to look at alternatives:
- Manuskript – open-source, available in many distros’ repos.
- Plume Creator – lightweight, designed for novel writing.
- Quoll Writer – another free/open-source option with similar features.
The website for Bibisco requires an email.
If your operating system is Linux
download the latest version:
Zipped Directory
bibisco-linux-x64-4.0.1-SE.zip (Supporters Edition)
bibisco-linux-x64-4.0.1-CE.zip (Community Edition)
On Manjaro we have access to AUR:
❯ pamac install bibisco
Warning: bibisco is only available from AUR
Preparing...
Checking bibisco dependencies...
Resolving dependencies...
Checking inter-conflicts...
To build (1):
bibisco 4.0.1-1 AUR
And so you can build it.
❯ aur bibisco
📦 Name: bibisco
🌐 Upstream URL: https://bibisco.com
👍 Votes: 0
📈 Popularity: 0.00
🧩 Version: 4.0.1-1
💾 Size: 0 B
📝 Description: Novel writing software for authors
📅 First Submitted: 2025-12-17 19:25:26 (UTC)
🕒 Last Updated: 2025-12-17 19:25:26 (UTC)
🔗 Link: https://aur.archlinux.org/packages/bibisco
Follow the link to the AUR page, and you will see the instruction - you must manually download the zip file from your Bibisco account and put it in the same directory as the PKGBUILD.
TL;DR
- Give them your email, when you recieve the mail, download the zip.
pamac build bibisco
Merci bcp
