Best way to check for OS issues
xfce
os
#1
Hi all,
So yesterday i was trying to get a package installed and it was returning a 404 in the package manager gui.
I thought of trying to do it via the terminal to see if i had the same issues.
So quick google on how to use pacman from the terminal and i found this command “sudo pacman -Syyu” i forgot to read the last line where it said it updated your system and thought it would just do a local db rebuild.
Any ways, update runs i say yes a few times to let the updates through and then my screen drops back to the uefi splash screen (rog logo) and stays there. I was hoping it was just a graphics driver update and the upgrade would complete in the background and it would come back. So i left it for 30-45min nothing had changed so i had to do a hard power.
On reboot i ended up in the Bios and manually selecting my boot device just got me a grub command line.
I rebooted again to see if i could get into a live usb i had and work some thing out. But on reboot it booted as normal and i ended up at my login screen.
I was then able to install my package from the gui no issues.
Sorry for the story just wanted to give context to get the most complete answer.
Where would i go to be sure this maybe bad upgrade didn’t cause any issues and what steps can i take to prepare an OS refresh and data recovery if i am running encrypted drives? Say i can’t get back in next time.
In windows for example i can use SFC or DSIM to check system files and use a bootable windows iso to run a repair. I would like to have similar recovery options for Manjaro :slight_smile:
Thanking you in advance for your time.
*excuse formatting i typed it on mobile.
#2
First, yours was probably not synced with mirror or bad mirror. We do not mess with mirrors without syncing, and we do not sync without updating because partial upgrades.
[as in if all you wanted was a resync it would be pacman -Syy … but that is Not Supported]
So.
The kill-all for your problem and many others is
sudo pacman-mirrors -f && sudo pacman -Syyuu
Now. If you want to be super safe you should perform this outside of X in TTY:
Ctrl+Alt+F2
(Get back to normal desktop session with CTRL+Alt+F1)
Though, I have never actually needed to do it this way, save 1 specific systemd update, which we were all warned about at the time.
I just run sudo pacman -Syyu in my terminal application. And I pay attention. If something is wrong (rarely if ever) … then DO NOT REBOOT … again drop to TTY or similar if possible.
Want to see what pacman has done?
less /var/logs/pacman.log
Errors in general ? A good one is:
journalctl -b -p 3
#3
For Manjaro you can use a live USB/DVD to boot the machine (say your installation media…) and then ‘chroot’ into your system. From there you have access to the normal information gathering, delete/overwrite and update options you might need. This thread is good place to start: Can't login - black screen & chroot guide
A second suggestion is to make regular backups of your system, particularly before updates. Then if something goes wrong that you cannot fix it is simply a matter of restoring the backup. Timeshift and Clonezilla are two commonish options but a forum search will reveal others. :smile:
Thank you very much i will check it out!
closed #5
