Hey guys,
pretty straight forward question and: If it indeed was, how could I achieve that?
Best wishes you lovely people!
Hey guys,
Hi @Slyfer1.
Well, both Manjaro and Konsole are open-source, so Iâm guessing so. You can find the artorrk here, I think:
Hey there Mirdarthos,
Thanks for chiming in! Youâre absolutely right. Iâm a bloody beginner so the more important question is probably how I could achieve that? Thank you for the link Any chance you have some further advice on how to install it?
Just found that out. Copy the .colorcheme
file to In ~/.local/share/konsole/
cp <file/location/.colorscheme> ~/.local/share/konsole/
Where:
is the file and youâve just downloadded; and~/.local/share/konsole/
is in you $HOME
is a Linux alias to your $HOIME`)What are you talking about exactly, because I think youâre talking about the ZSH theme/config, not the Konsole color scheme (which you can find probably in /etc/skel/
after showing hidden files, that you can then copy locally to your Home folder). I think you would also need the zsh-theme-powerlevel10K
package too.
//EDIT: so on Manjaro Konsole uses ZSH shell by default, so to reproduce Manjaroâs Konsole, youâll need the manjaro-zsh-config
package and its dependencies (which include the Power Level 10K theme and other stuff), and you need to configure Konsole to use ZSH shell, and you need to have the local ZSH config file that will make use of Manjaroâs configuration for ZSH.
Not sure it will be an easy thing to do for you as a noob.
Oof! Yeah, that sounds indeed like something I couldnât achieve currently However, what @Midarthos said worked as expected. However, @omano is right, that this only changes the color theme, not the way Konsole âbehavesâ. But thatâs fair enough for now haha.
Thank you guys!
But maybe you know a way to install Manjaroâs default global theme âBreathâ? Any chance I could easily apply/find that?
