Hi,
I’m on KDE on my Aspire mm1571
This is the error recevied when I try to run bauh
. I’m on the Stable branch.
I think this error is related to python
$ bauh
File "/usr/bin/bauh", line 33, in <module>
sys.exit(load_entry_point('bauh==0.9.11', 'console_scripts', 'bauh')())
File "/usr/lib/python3.9/site-packages/bauh/app.py", line 50, in main
from bauh.manage import new_manage_panel
File "/usr/lib/python3.9/site-packages/bauh/manage.py", line 13, in <module>
from bauh.view.core.controller import GenericSoftwareManager
File "/usr/lib/python3.9/site-packages/bauh/view/core/controller.py", line 22, in <module>
from bauh.view.core.update import check_for_update
File "/usr/lib/python3.9/site-packages/bauh/view/core/update.py", line 5, in <module>
from pkg_resources import parse_version
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3239, in <module>
def _initialize_master_working_set():
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3222, in _call_aside
f(*args, **kwargs)
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 3251, in _initialize_master_working_set
working_set = WorkingSet._build_master()
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 567, in _build_master
ws.require(__requires__)
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 884, in require
needed = self.resolve(parse_requirements(requirements))
File "/usr/lib/python3.9/site-packages/pkg_resources/__init__.py", line 770, in resolve
raise DistributionNotFound(req, requirers)
pkg_resources.DistributionNotFound: The 'python-dateutil>=2.7' distribution was not found and is required by bauh
