Hi everyone,
I’ve noticed after a recent update (not exactly sure when) that my battery percentage has stopped changing. It’ll be correct if I turn on the computer from cold but doesn’t continue to update afterwards.
I found this Battery indicator doesn't update and attempted to run the fixes from it but it doesn’t seem to have made any difference. When I run acpi
in the terminal it shows the same information as the battery indicator.
I’m using a Huawei 14S with i7-11370H running Manjaro Gnome.
I’m a bit stumped on where to go with this since I can’t find anything where anyone has had similar issues recently. Thanks in advance!
EDIT: I’ve dropped back from kernel 5.19.1-3 to 5.15.60-1 and it appears to have solved it
