upower -i /org/freedesktop/UPower/devices/battery_BAT0
native-path: BAT0
vendor: SMP
model: 45N1149
serial: 508
power supply: yes
updated: mar. 15 juin 2021 13:43:45 (118 seconds ago)
has history: yes
has statistics: yes
battery
present: yes
rechargeable: yes
state: charging
warning-level: none
energy: 22,3 Wh
energy-empty: 0 Wh
energy-full: 39,93 Wh
energy-full-design: 56,16 Wh
energy-rate: 0,0418103 W
voltage: 11,084 V
percentage: 55%
capacity: 71,1004%
technology: lithium-ion
icon-name: ‘battery-good-charging-symbolic’
I guess battery just died…RIP.
Do you have tlp
installed?
I had a similar problem sometimes on my previous laptop. The battery wasn’t dead but spent a long time starting to charge properly. The charge-percentage would not change for a while before it would start to slowly creep up.
I recommend trying to keep it plugged in and monitoring the battery charge, preferably with some decimal places. I use:
sudo tlp-stat -b
and am checking the value for charge
(second from bottom).
I also had a problem where the battery indicator would stop working all of a sudden, but that is probably a Cinnamon issue Hope that helps
Some laptops do indeed offer a possibility to limit charging (often to something like 50-60%) in order to preserve the battery.
That can be useful if you work plugged-in a lot.
It’s just a wild guess, but maybe the update introduced something which recognized that mode for your laptop and activated it.
