I’m having a terrible battery life with Manjaro.
Even if I’ll use TLP(or CoreCtrl), set powersave everywhere, minimal brightness, even if I’ll disable all cores except 2 and reduce CPU TDP to 8W - barrely changes anything.
With 50% brightness and using browser on powersave it’s about 4h.
With WIndows it was 6-7h, so I’m kinda dissapointed.
I just want a battery life on par or better than with Windows, even at cost of performance. Maybe someone has an idea what to do?
Note: I’m using ryzenadj, so my TDP is increased, but it’s just an upper limit change, same bad battery life even if it isn’t used.
Full specs:
Kernel: 5.15.78-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=b11151cf-968d-43ca-b20e-de830fdcd43d rw rootflags=subvol=@
quiet udev.log_priority=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Acer product: Swift SF314-43 v: V1.04
serial: <superuser required>
Mobo: LN model: Sake_CA v: V1.04 serial: <superuser required> UEFI: Insyde
v: 1.04 date: 07/28/2021
ID-1: BAT1 charge: 46.2 Wh (91.7%) condition: 50.4/53.2 Wh (94.6%)
volts: 12.3 min: 11.6 model: COSMX AP20CBL type: Li-ion serial: <filter>
status: discharging
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608102
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1397 min/max: 1400/4056 boost: enabled scaling:
driver: acpi-cpufreq governor: powersave cores: 1: 1397 2: 1397 3: 1397
4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397 12: 1397
bogomips: 50326
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Lucienne vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:164c class-ID: 0300 temp: 40.0 C
Device-2: Quanta HD User Facing type: USB driver: uvcvideo bus-ID: 1-3:2
chip-ID: 0408:a094 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x683d built: 2019
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85")
diag: 355mm (14") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.42 5.15.78-1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1
chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x,snd_pci_acp5x pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound API: ALSA v: k5.15.78-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lite-On driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF-ID-1: tap-easytether state: down mac: <filter>
Device-1: Lite-On Wireless_Device type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 04ca:3802 class-ID: e001 serial: <filter>
Local Storage: total: 476.94 GiB used: 294.27 GiB (61.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3512B-AA1
lanes: 4 type: SSD serial: <filter> rev: EDFK0S03 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 456.64 GiB size: 456.64 GiB (100.00%)
used: 294.23 GiB (64.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 456.64 GiB size: 456.64 GiB (100.00%)
ID-4: /var/log raw-size: 456.64 GiB size: 456.64 GiB (100.00%)
ID-1: swap-1 type: partition size: 20 GiB used: 36 MiB (0.2%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 41.1 C mobo: N/A gpu: amdgpu temp: 40.0 C
Processes: 377 Uptime: 21m wakeups: 2557 Memory: 14.98 GiB
used: 8.84 GiB (59.0%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman
pkgs: 1590 libs: 467 tools: pamac,yay Shell: Zsh v: 5.9 default: Bash
v: 5.1.16 running-in: yakuake inxi: 3.3.23
