Battery indicator stuck in 100%
Hello
I've recently installed manjaro i3 in another laptop of mine, an older Eee PC Seashell, from Asus. It is working great so far, but I've encountered this problem. The battery indicator is stuck in 100%, and doesn't change.
This is the output of cat /sys/class/power_supply/BAT0/uevent
POWER_SUPPLY_NAME=BAT0
POWER_SUPPLY_STATUS=Discharging
POWER_SUPPLY_PRESENT=1
POWER_SUPPLY_TECHNOLOGY=Li-ion
POWER_SUPPLY_CYCLE_COUNT=0
POWER_SUPPLY_VOLTAGE_MIN_DESIGN=14032000
POWER_SUPPLY_VOLTAGE_NOW=65535000
POWER_SUPPLY_CURRENT_NOW=1000
POWER_SUPPLY_CHARGE_FULL_DESIGN=4300000
POWER_SUPPLY_CHARGE_FULL=4200000
POWER_SUPPLY_CHARGE_NOW=4200000
POWER_SUPPLY_CAPACITY=100
POWER_SUPPLY_CAPACITY_LEVEL=Normal
POWER_SUPPLY_MODEL_NAME=1015PE
POWER_SUPPLY_MANUFACTURER=ASUS
POWER_SUPPLY_SERIAL_NUMBER=
[ayhon@matrix ~]$
Following my own investigation, I came accross a similar issue here, but it didn't solve it for me (to set last_full_capacity = false in the /etc/i3status.conf). Also, in the other guys post, his POWER_SUPPLY_CAPACITY was 72, yet mine remains as 100.
Any help is appreciated.
What do
acpi -V
and
upower -i `upower -e | grep 'BAT'`
show?
[ayhon@matrix ~]$  acpi -V; echo "--------"; upower -i `upower -e | grep 'BAT'`
Battery 0: Charging, 100%,  until charged
Battery 0: design capacity 4300 mAh, last full capacity 4200 mAh = 97%
Adapter 0: on-line
Thermal 0: ok, 60.0 degrees C
Thermal 0: trip point 0 switches to mode critical at temperature 101.0 degrees C
Thermal 0: trip point 1 switches to mode passive at temperature 98.0 degrees C
Cooling 0: Processor 0 of 10
Cooling 1: Processor 0 of 10
Cooling 2: Processor 0 of 10
Cooling 3: LCD 9 of 10
Cooling 4: Processor 0 of 10
  native-path:          BAT0
  vendor:               ASUS
  model:                1015PE
  power supply:         yes
  updated:              mar 02 jul 2019 11:59:05 CEST (104 seconds ago)
  has history:          yes
  has statistics:       yes
  battery
    present:             yes
    rechargeable:        yes
    state:               charging
    warning-level:       none
    energy:              58,9344 Wh
    energy-empty:        0 Wh
    energy-full:         58,9344 Wh
    energy-full-design:  60,3376 Wh
    energy-rate:         0,014032 W
    voltage:             65,535 V
    percentage:          100%
    capacity:            97,6744%
    technology:          lithium-ion
    icon-name:          'battery-full-charging-symbolic'
  History (charge):
    1562856194	100,000	charging
    1562856109	0,000	unknown
    1562832777	100,000	charging
  History (rate):
    1562856194	0,014	charging
    1562832777	0,014	charging
The computer is not connected to a charger, btw
Ok that's funny but first:
please set the time - that looks very wrong and can get you into a lot of problems. For a lot of stuff you need a correct system time.
Besides that:
I guess you did a vanilla install without a custom kernel or something like that?
Still could you give me: zgrep BAT /proc/config.gz and zgrep ACPI /proc/config.gz and inxi -Bxxx?
Also: If you've got a live system please boot that and paste the acpi/upower output.
I noticed my time was off a minute ago, so I fixed it using timedatectl set-ntp true
[ayhon@matrix ~]$ zgrep BAT /proc/config.gz and zgrep ACPI /proc/config.gz; echo "--------"; inxi -Bxxx/proc/config.gz:CONFIG_ARCH_WANT_BATCHED_UNMAP_TLB_FLUSH=y
/proc/config.gz:CONFIG_ACPI_BATTERY=m
/proc/config.gz:CONFIG_BATMAN_ADV=m
/proc/config.gz:CONFIG_BATMAN_ADV_BATMAN_V=y
/proc/config.gz:CONFIG_BATMAN_ADV_BLA=y
/proc/config.gz:CONFIG_BATMAN_ADV_DAT=y
/proc/config.gz:CONFIG_BATMAN_ADV_NC=y
/proc/config.gz:CONFIG_BATMAN_ADV_MCAST=y
/proc/config.gz:CONFIG_BATMAN_ADV_DEBUGFS=y
/proc/config.gz:# CONFIG_BATMAN_ADV_DEBUG is not set
/proc/config.gz:CONFIG_GENERIC_ADC_BATTERY=m
/proc/config.gz:CONFIG_BATTERY_88PM860X=m
/proc/config.gz:CONFIG_BATTERY_ACT8945A=m
/proc/config.gz:CONFIG_BATTERY_CPCAP=m
/proc/config.gz:CONFIG_BATTERY_DS2760=m
/proc/config.gz:CONFIG_BATTERY_DS2780=m
/proc/config.gz:CONFIG_BATTERY_DS2781=m
/proc/config.gz:CONFIG_BATTERY_DS2782=m
/proc/config.gz:CONFIG_BATTERY_LEGO_EV3=m
/proc/config.gz:CONFIG_BATTERY_SBS=m
/proc/config.gz:CONFIG_BATTERY_BQ27XXX=m
/proc/config.gz:CONFIG_BATTERY_BQ27XXX_I2C=m
/proc/config.gz:CONFIG_BATTERY_BQ27XXX_HDQ=m
/proc/config.gz:# CONFIG_BATTERY_BQ27XXX_DT_UPDATES_NVM is not set
/proc/config.gz:CONFIG_BATTERY_DA9030=m
/proc/config.gz:CONFIG_BATTERY_DA9052=m
/proc/config.gz:CONFIG_BATTERY_DA9150=m
/proc/config.gz:CONFIG_BATTERY_AXP20X=m
/proc/config.gz:CONFIG_BATTERY_MAX17040=m
/proc/config.gz:CONFIG_BATTERY_MAX17042=m
/proc/config.gz:CONFIG_BATTERY_MAX1721X=m
/proc/config.gz:CONFIG_BATTERY_TWL4030_MADC=m
/proc/config.gz:CONFIG_BATTERY_RX51=m
/proc/config.gz:CONFIG_BATTERY_GAUGE_LTC2941=m
/proc/config.gz:CONFIG_BATTERY_RT5033=m
/proc/config.gz:CONFIG_HID_BATTERY_STRENGTH=y
/proc/config.gz:CONFIG_USB_STORAGE_USBAT=m
/proc/config.gz:CONFIG_USB_XUSBATM=m
gzip: and.gz: No such file or directory
gzip: zgrep.gz: No such file or directory
gzip: ACPI.gz: No such file or directory
Battery:   ID-1: BAT0 charge: 58.8 Wh condition: 58.8/60.2 Wh (98%) volts: 65.5/14.0 model: ASUS 1015PE
           type: Li-ion serial:   status: Charging
[ayhon@matrix ~]$
Do you mean that I boot into my laptop through a USB and then paste the output?
Exactly. Just boot off a usb stick as if you wanted to install whatever os is on it.
Then open a terminal and paste the output here.
If at all possible try an os other than manjaroi3 - if you've got a gentoo or fedora live system that would be especially useful.
Ok, I have a pendrive around that has TAILS in it. I'll use that. Give me a couple of minutes
Im having trouble getting the output, but the battery works in Regolith Linux. It does show.
I couldn't get TAILS to load. It is an old laptop :confused:
Battery 0: Discharging, 70%, 03:00:18 remaining
Battery 0: design capacity 5200 mAh, last full capacity 4871 mAh = 93%
Adapter 0: off-line
Thermal 0: ok, 69.0 degrees C
Cooling 2: LCD 5 of 10
Cooling 3: Processor 0 of 10
  native-path:          BAT0
  vendor:               ASUS
  model:                1015PE
  power supply:         yes
  updated:              Sat 13 Jul 2019 02:21:45 PM UTC (20 seconds ago)
  has history:          yes
  has statistics:       yes
  battery
    present:             yes
    rechargeable:        yes
    state:               discharging
    warning-level:       none
    energy:              34.5276 Wh
    energy-empty:        0 Wh
    energy-full:         52.6068 Wh
    energy-full-design:  56.16 Wh
    energy-rate:         9.9144 W
    voltage:             11.173 V
    time to empty:       3.5 hours
    percentage:          65%
    capacity:            93.6731%
    icon-name:          'battery-full-symbolic'
  History (charge):
    1563027705	65.000	discharging
  History (rate):
    1563027705	9.914	discharging
gzip: /proc/config.gz: No such file or directory
Battery    BAT0: charge: 36.1 Wh 68.7% condition: 52.6/56.2 Wh (94%) volts: 11.2/10.8
           model: ASUS 1015PE Li-ion serial: N/A status: Discharging cycles: 0
Ahhm, when I wrote
I was asking for an output of
and another output of
The "and" was not part of that...
Ok, next:
Alright, looks like a manjaroi3 issue then. Give me a moment.
Good one .. I almost knee-jerk posted "Do a Power-Cycle!"
Sorry, I don't get it.
The output he gets when booting manjaroi3 is bs, in a live system on the other hand it makes sense - to me that looks like a problem with manjaroi3: either the kernel or some package that isn't working.
But sure maybe I missed something obvious - then please tell me...
I am sorry for the miscommunication...
I meant that I, without thinking was going to simply post 'do a power cycle' as a suggested solution
(a 'power-cycle' is usually completely draining machine, fully charging, fully discharging, leaving full for hours and fully discharging and fully full for hours ... it can help fix random 'bad reports' of battery)
But because you found software output correctly displaying percentage and discharge, it seems you are correct it is a DE/WM/i3 issue, or in some way it is displayed.
Thus my suggestion would have been unhelpful, and you had done a good job finding evidence and problem solving. I was actually just saying 'good on you'.
Ah ok, thanks for clearing that up - you had me worried there for a moment that I had done something stupid :sweat_smile:
Ok, looking at the output of zgrep BAT /proc/config.gz:
You've got a lot of modules that you don't need - makes sense because you're using a generic kernel that needs to work with diverse hardware (sry, couldn't resist :innocent:)
Possible but unlikely scenario: You have some driver conflict because of all those modules but then more people should have that problem...
Now here is what is different on my system:
CONFIG_ACPI_BATTERY=y
You've got this as CONFIG_ACPI_BATTERY=m
Following LKKDb try sudo modprobe battery
That should load the module.
But maybe zgrep ACPI /proc/config.gz will tell us more.
Also, your system is updated, right? Just want to make sure the problem is not related to outdated software... (edit: just to be thorough please post acpi -v and upower --version)
Since we can assume that this is a manjaro/i3 issue, let's maybe ask @oberon for help - afaIk he works on manjaroi3.
Ooof, what a brain fart. Here you go.
CONFIG_BATMAN_ADV=m
[ayhon@matrix ~]$ zgrep ACPI /proc/config.gz
CONFIG_X86_64_ACPI_NUMA=y
# Power management and ACPI options
CONFIG_ARCH_SUPPORTS_ACPI=y
CONFIG_ACPI=y
CONFIG_ACPI_LEGACY_TABLES_LOOKUP=y
CONFIG_ARCH_MIGHT_HAVE_ACPI_PDC=y
CONFIG_ACPI_SYSTEM_POWER_STATES_SUPPORT=y
# CONFIG_ACPI_DEBUGGER is not set
CONFIG_ACPI_SPCR_TABLE=y
CONFIG_ACPI_LPIT=y
CONFIG_ACPI_SLEEP=y
# CONFIG_ACPI_PROCFS_POWER is not set
CONFIG_ACPI_REV_OVERRIDE_POSSIBLE=y
CONFIG_ACPI_EC_DEBUGFS=y
CONFIG_ACPI_AC=m
CONFIG_ACPI_BUTTON=y
CONFIG_ACPI_VIDEO=y
CONFIG_ACPI_FAN=y
CONFIG_ACPI_TAD=m
CONFIG_ACPI_DOCK=y
CONFIG_ACPI_CPU_FREQ_PSS=y
CONFIG_ACPI_PROCESSOR_CSTATE=y
CONFIG_ACPI_PROCESSOR_IDLE=y
CONFIG_ACPI_CPPC_LIB=y
CONFIG_ACPI_PROCESSOR=y
CONFIG_ACPI_IPMI=m
CONFIG_ACPI_HOTPLUG_CPU=y
CONFIG_ACPI_PROCESSOR_AGGREGATOR=y
CONFIG_ACPI_THERMAL=y
CONFIG_ACPI_NUMA=y
CONFIG_ARCH_HAS_ACPI_TABLE_UPGRADE=y
CONFIG_ACPI_TABLE_UPGRADE=y
CONFIG_ACPI_DEBUG=y
CONFIG_ACPI_PCI_SLOT=y
CONFIG_ACPI_CONTAINER=y
CONFIG_ACPI_HOTPLUG_MEMORY=y
CONFIG_ACPI_HOTPLUG_IOAPIC=y
CONFIG_ACPI_SBS=m
CONFIG_ACPI_HED=y
CONFIG_ACPI_CUSTOM_METHOD=m
CONFIG_ACPI_BGRT=y
# CONFIG_ACPI_REDUCED_HARDWARE_ONLY is not set
CONFIG_ACPI_NFIT=m
CONFIG_HAVE_ACPI_APEI=y
CONFIG_HAVE_ACPI_APEI_NMI=y
CONFIG_ACPI_APEI=y
CONFIG_ACPI_APEI_GHES=y
CONFIG_ACPI_APEI_PCIEAER=y
CONFIG_ACPI_APEI_MEMORY_FAILURE=y
CONFIG_ACPI_APEI_EINJ=m
CONFIG_ACPI_APEI_ERST_DEBUG=m
CONFIG_ACPI_WATCHDOG=y
CONFIG_ACPI_EXTLOG=m
CONFIG_ACPI_CONFIGFS=m
CONFIG_X86_ACPI_CPUFREQ=m
CONFIG_X86_ACPI_CPUFREQ_CPB=y
CONFIG_HOTPLUG_PCI_ACPI=y
CONFIG_HOTPLUG_PCI_ACPI_IBM=m
CONFIG_PNPACPI=y
CONFIG_ATA_ACPI=y
CONFIG_PATA_ACPI=m
CONFIG_ACPI_I2C_OPREGION=y
# ACPI drivers
CONFIG_GPIO_ACPI=y
# ACPI drivers
CONFIG_SENSORS_ACPI_POWER=m
# ACPI INT340X thermal drivers
CONFIG_ACPI_THERMAL_REL=m
CONFIG_MFD_INTEL_LPSS_ACPI=m
CONFIG_SND_SOC_ACPI=m
CONFIG_SND_SST_IPC_ACPI=m
CONFIG_SND_SOC_INTEL_SST_ACPI=m
CONFIG_SND_SST_ATOM_HIFI2_PLATFORM_ACPI=m
CONFIG_SND_SOC_ACPI_INTEL_MATCH=m
CONFIG_UCSI_ACPI=m
CONFIG_MMC_SDHCI_ACPI=m
CONFIG_DMA_ACPI=y
CONFIG_XEN_ACPI_PROCESSOR=m
CONFIG_XEN_ACPI=y
CONFIG_THINKPAD_ACPI=m
CONFIG_THINKPAD_ACPI_ALSA_SUPPORT=y
# CONFIG_THINKPAD_ACPI_DEBUGFACILITIES is not set
# CONFIG_THINKPAD_ACPI_DEBUG is not set
# CONFIG_THINKPAD_ACPI_UNSAFE_LEDS is not set
CONFIG_THINKPAD_ACPI_VIDEO=y
CONFIG_THINKPAD_ACPI_HOTKEY_POLL=y
CONFIG_ACPI_WMI=m
CONFIG_ACPI_TOSHIBA=m
CONFIG_ACPI_CMPC=m
CONFIG_ACPI_ALS=m
CONFIG_INTEL_TH_ACPI=m
[ayhon@matrix ~]$
Actually, I did try charging it to the fullest and then discharging it, because I wanted to see how long the battery was going to last if I couldn't see the percentage.
It didn't work though :confused:
It is, I updated it next thing after installing. Just to be sure, I'll run pacman -Syyuu again. Before that:
[ayhon@matrix ~]$ acpi -v
acpi 1.7
Copyright (C) 2001 Grahame Bowland.
              2008-2012 Michael Meskes.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
[ayhon@matrix ~]$ upower --version
UPower client version 0.99.10
UPower daemon version 0.99.10
[ayhon@matrix ~]$
I'm going to try loading the module you mentioned. If it doesn't work, I'll pacman -Syyuu and try again.
After running sudo modprobe battery, the output of zgrep BAT /proc/config.gz appears to be unchanged. At least, CONFIG_ACPI_BATTERY=m is still there. The full output is:
CONFIG_BATMAN_ADV=m
[ayhon@matrix ~]$
Also, I have my system updated
[ayhon@matrix ~]$ sudo pacman -Syyuu
 core                                      149,0 KiB  1065K/s 00:00 [######################################] 100%
 extra                                    1758,6 KiB  3,53M/s 00:00 [######################################] 100%
 community                                   5,3 MiB  3,69M/s 00:01 [######################################] 100%
 multilib                                  183,2 KiB  4,07M/s 00:00 [######################################] 100%
 there is nothing to do
[ayhon@matrix ~]$
That's normal. /proc/config.gz is just telling you how your kernel is configured and not what modules are loaded at any given time.
Bummer! That would have been a nice fix :wink:
Ok, looks good, same here.
Ok, I have 0.99.9-r1 but seems unlikely that that would be a problem.
You could of course check the version in the live system but that is almost certainly a dead end.
