Hey guys, i’ve installed manjaro more or less 2 months ago and the thing is…until manjaro, my laptop baterry had 98% health after 4 or 5 months using Linux Mint. Now it’s 88% and 5 days ago it was 93%
I don’t have a clue why this is happening since i’ve always used it the same way(plugged in).
The laptop has only 6 months of usage.
Additionally, yesterday i noticed that even though i was using it on AC, the battery was discharging.
With powertop this is the higher power consumption
Power est. Usage Events/s Category Description
13.7 W 3,3 pkts/s Device Network interface: wlp8s0 (iwlwifi)
If the battery health continue to drop this fast, pretty soon (1 or 2 months) i won’t have battery anymore and this could be a good reason to change back to mint or windows(nightmare) as fast as i can. I don’t like this idea, because i really like manjaro, but i’m quite upset about my battery.
I get this impresion that all that started after the latests updates
Could you please help me find out if it’s related to my SO? I hope it’s not!!
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=e11e54c9-51f1-4666-b412-dcd1af2d354f rw quiet apparmor=1
security=apparmor resume=UUID=ff41e01c-df92-4fce-976d-3ead2b218fd0
udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Acer product: Nitro AN515-54 v: V1.30 serial: <filter>
Mobo: CFL model: Octavia_CFS v: V1.30 serial: <filter> UEFI: Insyde v: 1.30
date: 05/11/2020
ID-1: BAT1 charge: 50.9 Wh condition: 50.9/57.5 Wh (88%) volts: 16.9/15.4
model: LGC AP18E8M type: Li-ion serial: <filter> status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M275/M280
status: Discharging
Info: Quad Core model: Intel Core i5-9300H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 8 MiB
bogomips: 38408
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Acer Incorporated ALI driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Acer Incorporated ALI driver: nvidia v: 455.45.01
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f91
Device-3: Chicony HD User Facing type: USB driver: uvcvideo bus ID: 1-5:4
chip ID: 04f2:b64f serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11
driver: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:a348
Sound Server: ALSA v: k5.10.2-2-MANJARO
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 3000
bus ID: 07:00.0 chip ID: 10ec:8168
IF: enp7s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 3000
bus ID: 08:00.0 chip ID: 8086:2723
IF: wlp8s0 state: up mac: <filter>
Local Storage: total: 1.03 TiB used: 374.15 GiB (35.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: IM2P33F8BR1-128GB
size: 119.24 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: S1107B0L temp: 34.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-21Z10T0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 1A02
ID-1: / raw size: 114.7 GiB size: 112.4 GiB (97.99%) used: 14.54 GiB (12.9%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw size: 550 MiB size: 548.9 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw size: 931.51 GiB size: 915.89 GiB (98.32%)
used: 359.61 GiB (39.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
Kernel: swappiness: 10 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 4 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 57.0 C mobo: N/A
Processes: 257 Uptime: 3h 40m wakeups: 44 Memory: 15.48 GiB
used: 3.64 GiB (23.5%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1310 lib: 412 flatpak: 0 Shell: Bash v: 5.1.0 running in: konsole
inxi: 3.2.01
