I am not sure whether I should even post it here. But updating Manjaro, foliate has completely stopped working.
Here is my inxi
output:
System: Kernel: 5.10.68-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 40.4
Machine: Type: Laptop System: Dell product: Inspiron 7559 v: 1.3.0 serial: <filter>
Mobo: Dell model: 0H0CC0 v: A00 serial: <filter> UEFI: Dell v: 1.3.0 date: 12/01/2018
Battery: ID-1: BAT0 charge: 72.8 Wh (100.0%) condition: 72.8/76.1 Wh (95.7%) volts: 12.8
min: 11.4 model: Dell status: Full
CPU: Info: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
rev: 3 cache: L2: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 41621
Speed: 2302 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 2302 2: 2725 3: 2601
4: 2662 5: 2559 6: 2717 7: 1949 8: 2802
Graphics: Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel bus-ID: 00:02.0
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Dell driver: N/A bus-ID: 02:00.0
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-4:2
Display: x11 server: X.org 1.20.13 driver: loaded: modesetting
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 21.2.2
direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.10.68-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell
driver: r8169 v: kernel port: d000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: d000 bus-ID: 05:00.0
IF: wlp5s0 state: up mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8
bus-ID: 1-5:3
Drives: Local Storage: total: 577.55 GiB used: 196.07 GiB (33.9%)
ID-1: /dev/sda vendor: Transcend model: TS120GMTS820S size: 111.79 GiB
ID-2: /dev/sdb vendor: Western Digital model: WDS500G2B0A size: 465.76 GiB
Partition: ID-1: / size: 92.46 GiB used: 57.93 GiB (62.7%) fs: ext4 dev: /dev/sda3
ID-2: /boot/efi size: 299.4 MiB used: 25.6 MiB (8.6%) fs: vfat dev: /dev/sda1
ID-3: /home size: 195.8 GiB used: 138.11 GiB (70.5%) fs: ext4 dev: /dev/sdb3
Swap: ID-1: swap-1 type: partition size: 17 GiB used: 0 KiB (0.0%) dev: /dev/sda2
Sensors: System Temperatures: cpu: 60.0 C mobo: 29.8 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 0
Info: Processes: 282 Uptime: 35m Memory: 15.49 GiB used: 3.19 GiB (20.6%) Init: systemd
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1665 Client: shell wrapper
v: 5.1.8-release inxi: 3.3.06
And here is the error message that I got
** (com.github.johnfactotum.Foliate:16770): CRITICAL **: 08:56:02.377: g_irepository_find_by_name: assertion 'typelib != NULL' failed
** (com.github.johnfactotum.Foliate:16770): CRITICAL **: 08:56:02.378: g_irepository_find_by_name: assertion 'typelib != NULL' failed
(com.github.johnfactotum.Foliate:16770): GLib-GObject-WARNING **: 08:56:02.378: cannot register existing type 'TrackerSparqlConnection'
(com.github.johnfactotum.Foliate:16770): GLib-CRITICAL **: 08:56:02.378: g_once_init_leave: assertion 'result != 0' failed
(com.github.johnfactotum.Foliate:16770): GLib-GObject-CRITICAL **: 08:56:02.378: g_type_register_static: assertion 'parent_type > 0' failed
(com.github.johnfactotum.Foliate:16770): GLib-GObject-WARNING **: 08:56:02.378: cannot add private field to invalid (non-instantiatable) type '<invalid>'
(com.github.johnfactotum.Foliate:16770): GLib-GObject-CRITICAL **: 08:56:02.378: g_object_new_with_properties: assertion 'G_TYPE_IS_OBJECT (object_type)' failed
(com.github.johnfactotum.Foliate:16770): Tracker-CRITICAL **: 08:56:02.378: tracker_sparql_backend_load_plugins: assertion 'self != NULL' failed
what should I do? anyone has any better application in mind to read .epub?
