Hi all,
Yesterday for some reason my manjaro build would not recognize my battery charging. So here are my specs
System: Host: tommy-pc Kernel: 5.4.97-1-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.20.5 Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 20L5000WUS v: ThinkPad T480 serial: <superuser required>
Mobo: LENOVO model: 20L5000WUS v: SDK0J40697 WIN serial: <superuser required> UEFI: LENOVO v: N24ET44W (1.19 )
date: 11/07/2018
Battery: ID-1: BAT0 charge: 1.3 Wh condition: 20.1/24.0 Wh (83%)
ID-2: BAT1 charge: 1.1 Wh condition: 20.8/24.0 Wh (87%)
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP L2 cache: 6 MiB
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Graphics: Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.10 driver: loaded: intel unloaded: modesetting resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.4
Audio: Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.4.97-1-MANJARO
Network: Device-1: Intel Ethernet I219-V driver: e1000e
IF: enp0s31f6 state: down mac: e8:6a:64:b4:ee:85
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi
IF: wlp3s0 state: up mac: d4:3b:04:d3:76:24
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 476.94 GiB used: 82.06 GiB (17.2%)
ID-1: /dev/sda vendor: Silicon Power model: SPCC Solid State Disk size: 476.94 GiB
Partition: ID-1: / size: 191.25 GiB used: 82.06 GiB (42.9%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 1022 MiB used: 280 KiB (0.0%) fs: vfat dev: /dev/sda1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Info: Processes: 218 Uptime: 13h 18m Memory: 7.55 GiB used: 2.35 GiB (31.1%) Shell: Bash inxi: 3.3.01
Now here’s my problem. My battery’s have been stuck at 6% no matter how long I use my computer / charge it. I decided to look in /sys/class/power_supply/BAT0/uevent and here is what I find
POWER_SUPPLY_NAME=BAT0
POWER_SUPPLY_STATUS=Unknown
POWER_SUPPLY_PRESENT=1
POWER_SUPPLY_TECHNOLOGY=Li-ion
POWER_SUPPLY_CYCLE_COUNT=219
POWER_SUPPLY_VOLTAGE_MIN_DESIGN=11550000
POWER_SUPPLY_VOLTAGE_NOW=10973000
POWER_SUPPLY_POWER_NOW=0
POWER_SUPPLY_ENERGY_FULL_DESIGN=24020000
POWER_SUPPLY_ENERGY_FULL=20050000
POWER_SUPPLY_ENERGY_NOW=1160000
POWER_SUPPLY_CAPACITY=5
POWER_SUPPLY_CAPACITY_LEVEL=Normal
POWER_SUPPLY_MODEL_NAME=01AV419
POWER_SUPPLY_MANUFACTURER=SANYO
POWER_SUPPLY_SERIAL_NUMBER= 1118
Notice the SUPPLY_STATUS is UNKNOWN even though I am currently charging my computer. Now when I unplug the charger:
POWER_SUPPLY_STATUS=Discharging
POWER_SUPPLY_VOLTAGE_NOW=10989000
It now realizes it is discharging. What is going on here? What can I do to fix this. I do not believe that the batteries are dead yet as there are two of them and I have owned this machine for less than 2 years. Thanks!
