Battery and heating issue
i have battery and heating issue.
laptop shows that battrey is full but it is not.
laptop suddenly shutdown without any warning.
battery indicator show that it is full but it is not.
and laptop get heat in normal use.
please give solution, i dont want to leave manjaro
Please provide more information on the hardware and software you use with
inxi --full --verbosity=7 --filter --no-host
and information on your battery with
acpi -V
and post the output as explained here by putting it between ``` at the beginning and the end of each output.
  Kernel: 5.6.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.3.0
  Desktop: KDE Plasma 5.18.5 tk: Qt 5.14.2 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
  v: Type1ProductConfigId serial: <filter> Chassis: type: 10
  serial: <filter>
  Mobo: HP model: 8478 v: 70.55 serial: <filter> UEFI: Insyde v: F.20
  date: 05/07/2019
  ID-1: BAT1 charge: 22.0 Wh condition: 50.0/52.8 Wh (95%)
  volts: 10.8/11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
  serial: <filter> status: Discharging
  RAM: total: 7.54 GiB used: 3.18 GiB (42.1%)
  RAM Report:
  Topology: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP
  arch: Kaby Lake rev: A L2 cache: 8192 KiB bogomips: 36812
  Speed: 800 MHz min/max: 800/4000 MHz Core speeds (MHz): 1: 800 2: 800
  3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
  art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
  est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp
  hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
  invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr
  mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs
  pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg
  sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
  v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
  Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile]
  vendor: Hewlett-Packard driver: nvidia v: 440.82 bus ID: 01:00.0
  chip ID: 10de:1c8d
  Display: x11 server: X.Org 1.20.8 driver: modesetting,nvidia
  unloaded: intel,nouveau alternate: fbdev,nv,vesa compositor: kwin_x11
  resolution: 1920x1080~60Hz
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2)
  v: 4.6 Mesa 20.0.6 direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
  driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a348
  Sound Server: ALSA v: k5.6.12-1-MANJARO
  Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi
  v: kernel port: 5000 bus ID: 00:14.3 chip ID: 8086:a370
  vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000
  bus ID: 03:00.0 chip ID: 10ec:8168
  Local Storage: total: 931.51 GiB used: 20.84 GiB (2.2%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS721010A9E630
  size: 931.51 GiB speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
  rev: A3T0 scheme: GPT
  ID-1: / size: 141.10 GiB used: 20.76 GiB (14.7%) fs: ext4
  dev: /dev/sda7 label: N/A uuid: 5aac5ea3-4711-4eb5-baf3-75131394e195
  ID-2: /boot/efi size: 256.0 MiB used: 84.3 MiB (32.9%) fs: vfat
  dev: /dev/sda1 label: SYSTEM uuid: 1492-7FF4
  ID-3: /var/lib/snapd/snap/core/9066 raw size: 93.9 MiB
  size: <root required> used: <root required> fs: squashfs
  dev: /dev/loop0 label: N/A uuid: N/A
  ID-1: /dev/sda2 size: 16.0 MiB fs: <root required> label: N/A uuid: N/A
  ID-2: /dev/sda3 size: 150.00 GiB fs: ntfs label: Windows
  uuid: 4EF8E61BF8E60157
  ID-3: /dev/sda4 size: 235.64 GiB fs: ntfs label: New Volume
  uuid: 884CABFD4CABE3E2
  ID-4: /dev/sda5 size: 400.28 GiB fs: ntfs label: New Volume
  uuid: E446AF3446AF0680
  ID-5: /dev/sda6 size: 980.0 MiB fs: ntfs label: Windows RE tools
  uuid: D8F8C977F8C95482
  Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
  speed: 480 Mb/s chip ID: 1d6b:0002
  Device-1: 1-3:2 info: Sunplus Innovation Optical Mouse type: Mouse
  driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
  chip ID: 1bcf:0007
  Device-2: 1-5:3 info: Lite-On HP Wide Vision HD Camera type: Video
  driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
  chip ID: 04ca:707f serial: <filter>
  Device-3: 1-14:4 info: Intel type: Bluetooth driver: btusb
  interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aaa
  Hub: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1
  speed: 10 Gb/s chip ID: 1d6b:0003
  System Temperatures: cpu: 63.0 C mobo: 29.8 C
  Processes: 288 Uptime: 1h 12m Init: systemd v: 245 Compilers:
  gcc: 9.3.0 Shell: bash v: 5.0.16 running in: konsole inxi: 3.0.37
acpi -V
Battery 0: Discharging, 43%, 01:00:46 remaining
Battery 0: design capacity 4550 mAh, last full capacity 4307 mAh = 94%
Adapter 0: off-line
Thermal 0: ok, 29.8 degrees C
Thermal 0: trip point 0 switches to mode critical at temperature 119.0 degree
s C
Thermal 1: ok, 27.8 degrees C
Thermal 1: trip point 0 switches to mode critical at temperature 119.0 degree
s C
Thermal 1: trip point 1 switches to mode active at temperature 71.0 degrees C
Thermal 1: trip point 2 switches to mode active at temperature 55.0 degrees C
Thermal 1: trip point 3 switches to mode active at temperature 50.0 degrees C
Thermal 1: trip point 4 switches to mode active at temperature 45.0 degrees C
Thermal 2: ok, 10.0 degrees C
Thermal 2: trip point 0 switches to mode hot at temperature 99.0 degrees C
Cooling 0: Fan 0 of 1
Cooling 1: INT3400 Thermal no state information available
Cooling 2: Processor 0 of 10
Cooling 3: SEN2 no state information available
Cooling 4: Processor 0 of 10
Cooling 5: iwlwifi_1 no state information available
Cooling 6: Processor 0 of 10
Cooling 7: Processor 0 of 10
Cooling 8: Fan 0 of 1
Cooling 9: Processor 0 of 10
Cooling 10: Fan 0 of 1
Cooling 11: pch_cannonlake no state information available
Cooling 12: Fan 0 of 1
Cooling 13: B0D4 no state information available
Cooling 14: Processor 0 of 10
Cooling 15: SEN4 no state information available
Cooling 16: Processor 0 of 10
Cooling 17: x86_pkg_temp no state information available
Cooling 18: Processor 0 of 10
Cooling 19: Fan 0 of 1
Cooling 20: intel_powerclamp no state information available
I don't really see any temperature issues. What type of work do you do while this problem occurs?
