I may have another option for you.
I’ve long kept my devices synchronized using samba and grsync (a GUI front-end for rsync). It works, but it is far more than what I need, and thus, complexifies what should be a simple task.
In short, it seemed like using an excavator when all I need to do is transplant a few bulbs.
Earlier this week, due to coverage of a new release, I learned about syncthing. Also this week, I added (yet another) laptop to the fleet. So it seemed like a good time to try something new.
Last night I spent a few minutes—maybe an hour—installing Syncthing, then a few hours watching it sync several terabytes over the LAN to the new-to-me laptop. While that was happening, I added my existing two laptops and watched them scan their drives, then sync a handful of files each.
Just marvelous!
What I have are needs similar to yours:
- I’m the only one who ever uses my computers. No heavy security requirements.
- I don’t particularly need to open files from another device. I only want to keep things synchronized so I always have the most-recent copy on every device.
- When I add or change a file anywhere, it gets synced everywhere with a minimum of fuss and without me having to remember what I added or changed and where.
- I don’t have to have every device on, any two at a time will do. Asynchronous syncing, as it were.
What I don’t have for you is a step-by-step recipe for setting this up. Sorry.
I have only about a hour’s worth of actual experience it setting it up. I made, and recovered from, a few mistakes along the way. Mainly misinterpreting stuff. I’m not sure if it’s set up optimally for my needs, and I haven’t explored all its options.
Yet—yet, it still works well enough that if I were to do nothing else (Ha! Like that could happen.) it meets my requirements.
I also don’t have a Windows box in the house, but Syncthing has versions for Windows, Mac and interestingly, Android.
The Android version will get some attention here because I’ve found syncing my photos with KDE Connect to be tedious. I currently sync my pictures through ProtonDrive, (part of the Proton VPN family, not to be confused with the Proton that gamers use). Which, although simple on the phone end, still requires me to remember to transfer the photos on the PC end. And I’ve been copying music to the phone with a USB cable.
Anyway, what I offer is another avenue of investigation.
syncthing is in the official repositories (Extra) and the documents are here: Welcome to Syncthing’s documentation! — Syncthing documentation
