//EDIT: higher resolution of same image (easier to clean up before resize) (//EDITception: no it is actually same file dimension, but still a slight difference)
🫵 <= emoticon from character (not really readable)
To me it is not really the same issue, here the image is correct, it is not just very visible because of the nature of the emoticon itself (dotted line face), hard to make it better, as the shape is defined with little dots, can’t think of a compromise that would work on dark and light theme, with the dotted shape or eyes/mouth.
