When I try to run bleachbit in terminal, it does not run and I get:
$ bleachbit
Error: too many environment variables: >= MAX_ENVS (256)
I also get the same error when I try to install an AUR package.
What is going on?
$ bleachbit
What is going on?
That means you have too many environment variables defined. You can check how many you have with:
env | wc -l
You can also see them with plain
env
They usually are defined in you shell’s .rc -files. Check them if necessary
Yes, I added a lot of variables to my .bashrc file, too many. I commented out a bunch of them.
Thank you
This topic was automatically closed 3 hours after the last reply. New replies are no longer allowed.
