I have recently switched to Manjaro GNOME (from Ubuntu), so the install very fresh. Since I installed it at night, I immediately ran into this issue: I can’t change the backlight brightness from the maximum brightness.
Whether I use function keys or any of the below commands, the brightness setting says it is changed, but the brightness stays on full.
echo 5 | sudo tee /sys/class/backlight/intel_backlight/brightness
xbacklight -25
gdbus call --session --dest org.gnome.SettingsDaemon.Power --object-path /org/gnome/SettingsDaemon/Power --method org.freedesktop.DBus.Properties.Set org.gnome.SettingsDaemon.Power.Screen Brightness "<int32 50>"
I have already tried adding these kernel options:
acpi_backlight=video
acpi_backlight=vendor
acpi_backlight=native
acpi_backlight=none
i915.enable_dpcd_backlight=1
But none of them seem to change anything.
Does anyone have an idea how I could fix this?
inxi --full --verbosity=7 --filter --no-host
output:
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
Desktop: GNOME 3.38.3 tk: GTK 3.24.26 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Laptop System: TOSHIBA product: SATELLITE P50-C v: PSPTSE-00Q003DU
serial: <filter>
Mobo: FF50 model: 06F2 v: Type2 - Board Version serial: <filter>
UEFI: INSYDE v: 5.10 date: 09/11/2015
ID-1: BAT1 charge: 15.8 Wh condition: 20.3/44.1 Wh (46%) volts: 15.9/14.8
model: Panasonic PA5195U-1BRS type: Li-ion serial: N/A status: Charging
cycles: 844
RAM: total: 7.69 GiB used: 2.37 GiB (30.8%)
RAM Report:
Info: Dual Core model: Intel Core i7-5500U bits: 64 type: MT MCP
arch: Broadwell rev: 4 L2 cache: 4 MiB bogomips: 19160
Speed: 798 MHz min/max: 500/3000 MHz Core speeds (MHz): 1: 798 2: 798
3: 798 4: 798
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
Device-1: Intel HD Graphics 5500 vendor: Toshiba driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:1616 class ID: 0300
Device-2: NVIDIA GM108M [GeForce 930M] vendor: Toshiba driver: nvidia
v: 460.39 bus ID: 09:00.0 chip ID: 10de:1346 class ID: 0302
Device-3: Chicony TOSHIBA Web Camera - HD type: USB driver: uvcvideo
bus ID: 2-7:4 chip ID: 04f2:b446 class ID: 0e02
Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.3.4
direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Toshiba driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:160c class ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Toshiba
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9ca0
class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Wireless 3160 driver: iwlwifi v: kernel port: 6040
bus ID: 07:00.0 chip ID: 8086:08b3 class ID: 0280
IF: wlp7s0 state: up mac: <filter>
vendor: Toshiba driver: r8169 v: kernel port: 4000 bus ID: 08:00.0
chip ID: 10ec:8168 class ID: 0200
IF: enp8s0 state: down mac: <filter>
Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
v: 0.8 bus ID: 2-6:3 chip ID: 8087:07dc class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 931.51 GiB used: 13.69 GiB (1.5%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 4M scheme: GPT
ID-1: / size: 595.74 GiB used: 13.63 GiB (2.3%) fs: ext4 dev: /dev/dm-0
mapped: luks-c17cda1f-6283-4cff-be0d-25f09732593e label: N/A
uuid: 04f53f7b-91e4-4c50-a456-8e3312341813
ID-2: /boot/efi size: 96 MiB used: 57.7 MiB (60.1%) fs: vfat
dev: /dev/sda2 label: ESP uuid: A437-BCAB
ID-1: swap-1 type: partition size: 7.92 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda8 label: N/A
uuid: 93998e19-b253-4260-856f-6eee42a66852
ID-1: /dev/sda1 size: 1024 MiB fs: ntfs label: WinRE
uuid: F09236C092368B5C
ID-2: /dev/sda3 size: 128 MiB fs: ntfs label: N/A uuid: 86E0FBEEE0FBE27B
ID-3: /dev/sda5 size: 477 MiB fs: ntfs label: N/A uuid: AA4E24154E23D939
ID-4: /dev/sda6 size: 12.53 GiB fs: ntfs label: Recovery
uuid: 001040D51040D378
ID-5: /dev/sda7 size: 303.11 GiB fs: ext4 label: N/A
uuid: 276fe933-51d6-4877-857d-2711520b5871
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
chip ID: 8087:8001 class ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 11 rev: 2.0
Device-1: 2-1:2 info: Logitech Unifying Receiver type: Keyboard,Mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
chip ID: 046d:c534 class ID: 0301
Device-2: 2-6:3 info: Intel Bluetooth wireless interface type: Bluetooth
driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:07dc
class ID: e001
Device-3: 2-7:4 info: Chicony TOSHIBA Web Camera - HD type: Video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b446
class ID: 0e02
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0
speed: 5 Gb/s chip ID: 1d6b:0003 class ID: 0900
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 203 Uptime: 17m wakeups: 1 Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1231 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.3.01
