Backintime generated kernel level EXT4-fs errors
I randomly execute journalctl -k --priority 3 --boot 0 from time to time to check for important information I may need to pay attention to… and today it honed me in on a cluster of journal entries related to backintime
"Look for the two `EXT4-fs error` lines"; about 12 lines in
Feb 01 13:59:36 AM4-5600X-Linux plasmashell[1022867]: INFO: Lock
Feb 01 13:59:36 AM4-5600X-Linux python[1022867]: backintime (<userid>/1): INFO: Lock
Feb 01 13:59:36 AM4-5600X-Linux plasmashell[1022867]: INFO: Take a new snapshot. Profile: 1 Main profile
Feb 01 13:59:36 AM4-5600X-Linux python[1022867]: backintime (<userid>/1): INFO: Take a new snapshot. Profile: 1 Main profile
Feb 01 13:59:36 AM4-5600X-Linux plasmashell[1022867]: INFO: Call rsync to take the snapshot
Feb 01 13:59:36 AM4-5600X-Linux python[1022867]: backintime (<userid>/1): INFO: Call rsync to take the snapshot
Feb 01 13:59:43 AM4-5600X-Linux plasmashell[1022867]: INFO: Save config file
Feb 01 13:59:43 AM4-5600X-Linux plasmashell[1022867]: INFO: Save permissions
Feb 01 13:59:43 AM4-5600X-Linux python[1022867]: backintime (<userid>/1): INFO: Save config file
Feb 01 13:59:43 AM4-5600X-Linux python[1022867]: backintime (<userid>/1): INFO: Save permissions
Feb 01 13:59:49 AM4-5600X-Linux plasmashell[1022867]: INFO: Create info file
Feb 01 13:59:49 AM4-5600X-Linux python[1022867]: backintime (<userid>/1): INFO: Create info file
Feb 01 13:59:49 AM4-5600X-Linux kernel: EXT4-fs error (device nvme3n1p1): htree_dirblock_to_tree:1072: inode #38297640: comm rsync: Directory block failed checksum
Feb 01 13:59:49 AM4-5600X-Linux kernel: EXT4-fs error (device nvme3n1p1): ext4_empty_dir:3068: inode #38297640: comm rsync: Directory block failed checksum
Feb 01 13:59:49 AM4-5600X-Linux plasmashell[1022867]: WARNING: Command "rsync -a --delete -s /tmp/tmp4d6tsyhw/ /data/sn550/backintime/AM4-5600X-Linux/<userid>/1/20230115-230001-242" returns 23 | rsync: [generator] readdir("/data/sn550/backintime/AM4-5600X-Linux>
Feb 01 13:59:49 AM4-5600X-Linux plasmashell[1022867]: cannot delete non-empty directory: backup/home/<userid>/.npm/_cacache/index-v5/68/88
Feb 01 13:59:49 AM4-5600X-Linux plasmashell[1022867]: rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1336) [sender=3.2.7]
Feb 01 13:59:49 AM4-5600X-Linux plasmashell[1022867]: ERROR: Last rsync command failed with return code "23". See previous WARNING message in the logs for details.
Feb 01 13:59:49 AM4-5600X-Linux python[1022867]: backintime (<userid>/1): WARNING: Command "rsync -a --delete -s /tmp/tmp4d6tsyhw/ /data/sn550/backintime/AM4-5600X-Linux/<userid>/1/20230115-230001-242" returns 23 | rsync: [generator] readdir("/data/sn550/backint>
Feb 01 13:59:49 AM4-5600X-Linux python[1022867]: backintime (<userid>/1): WARNING: CONTINUE: backup/home/<userid>/.npm
Feb 01 13:59:49 AM4-5600X-Linux python[1022867]: backintime (<userid>/1): ERROR: Last rsync command failed with return code "23". See previous WARNING message in the logs for details.
Feb 01 13:59:56 AM4-5600X-Linux plasmashell[1022867]: INFO: Unlock
Feb 01 13:59:56 AM4-5600X-Linux python[1022867]: backintime (<userid>/1): INFO: Unlock
Feb 01 13:59:56 AM4-5600X-Linux plasmashell[1022867]: Back In Time
Feb 01 13:59:56 AM4-5600X-Linux plasmashell[1022867]: Version: 1.3.3
Feb 01 13:59:56 AM4-5600X-Linux plasmashell[1022867]: Back In Time comes with ABSOLUTELY NO WARRANTY.
Feb 01 13:59:56 AM4-5600X-Linux plasmashell[1022867]: This is free software, and you are welcome to redistribute it
Feb 01 13:59:56 AM4-5600X-Linux plasmashell[1022867]: under certain conditions; type `backintime --license' for details.
I ran backintime manually a couple times and duplicated the error.
Thinking there might be an issue with the filesystem/disk, i ran…
e2fsck
$ sudo umount /dev/nvme3n1p1
$ sudo e2fsck -vf /dev/nvme3n1p1
e2fsck 1.46.5 (30-Dec-2021)
Pass 1: Checking inodes, blocks, and sizes
Inode 12 extent tree (at level 2) could be narrower.  Optimize<y>? yes
Inode 11666897 extent tree (at level 1) could be shorter.  Optimize<y>? yes
Inode 68685017 extent tree (at level 1) could be shorter.  Optimize<y>? yes
Inode 89141649 extent tree (at level 1) could be shorter.  Optimize<y>? yes
Inode 110626785 extent tree (at level 1) could be shorter.  Optimize<y>? yes
Pass 1E: Optimizing extent trees
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
NVME_SN550_BAK: ***** FILE SYSTEM WAS MODIFIED *****
     2247717 inodes used (1.84%, out of 122101760)
        6367 non-contiguous files (0.3%)
        3971 non-contiguous directories (0.2%)
             # of inodes with ind/dind/tind blocks: 0/0/0
             Extent depth histogram: 2142434/1541/1
   386483084 blocks used (79.14%, out of 488377600)
           0 bad blocks
          71 large files
     1200201 regular files
      911882 directories
           0 character device files
           0 block device files
           5 fifos
     7420377 links
      135620 symbolic links (103728 fast symbolic links)
           0 sockets
     9668085 files
$ sudo mount /dev/nvme3n1p1
The “inode optimizations” seemed to correct the issue as backintime no longer triggered then EXT4-fs errors… but I’d like to ask some questions before i feel good about this “solution”:
  1. Is it possible the filesystem just required the fschk? (like maybe an issue cropped up during shutdown/unmounting?)
  2. Is it possible that what went on with the file system might actually be pointing to the disk? It’s not quite a year old, but you never know.
  3. maybe my manual backintime executions forced some “bad data” passed the retention period and were deleted
Any observations that would help confirm what I’ve done is “good”, or any additional checks I should make would be appreciated.
