I have a multi-monitor setup and I am trying to configure pscircle by Ruslan Kuchumov as my background for my secondary monitor (“HDMI-1” according to xrandr
By default, it prints to the X11 root window, which I don’t know how to find and the documentation suggest that "as pscircle is not tested yet in multi-display environment [sic] to make it work correctly, I suggest trying the following options:
- specify
--output-display=...
argument to print the image to the correct display or, - change
DISPLAY
environment variable before running the program, or - output image to the file using --output=…“argument and then set it as the wallpaper using external comand (e.g.
feh
I trie dto set the --output-display option by doing output--display="HDMI-1"
but that gave an error:
pscircle --output-display="HDMI-1"
Unable to open display: 'HDMI-1'
So instead I did just did pscircle --output=/home/usr/Pictures/pscircle.png
which worked perfectly except for the fact that the output image has root permissions and so can’t be set as the wallpaper.
(I should note, I created the ~/.config/systemd/user/pscircle.service
file and tried to change the parameters there but I must have bad syntax because those never seemed to work, and all the CLI arguments did)
Hopefully this is enough background, and I’m sorry for the long post, but my questions are:
Where can I view my monitors X11 root window so I can use the program as default if that works? If not, how can I write this in a way so that I can set it as my background (i.e. the file is written without root permissions).
As usual, I’m probably drastically misunderstanding something, so if so I would love pointers as to where my misconceptions are.
EDIT: I missed this in the documentation: " GNOME, KDE, XFCE and, probably, some other DE do not display X11 root window as desktop wallpaper. But you can still save the image to the file (by using --output=path.png
) and either:
- Set the path to the image in wallpaper system config. DE is likely to update the wallpaper automatically, when the image has changed."
So the X11 route seems moot but I’d still like to know where in the FS the x11 root window is, and this still leaves me with a file that is not usable as a wallpaper as it has root permissions
