Hola Amigos!. Esta es mi primer publicación, llevo unos 6 meses en linux y me encontré con un problema. El lector de tarjetas SD interno de mi Laptop es detectado, pero al conectar una SD no puedo montarla ni acceder al contenido.
Esta es mi salida del comando inxi:
Kernel: 6.1.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=es_MX keytable=latam
tz=America/Mexico_City misobasedir=manjaro misolabel=MANJARO_XFCE_220
quiet systemd.show_status=1 splash apparmor=1 security=apparmor
driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Desktop: Xfce v: 4.18.0 tk: Gtk v: 3.24.35 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8478 v: 70.55 serial: <superuser required> UEFI: Insyde
v: F.20 date: 05/07/2019
ID-1: BAT1 charge: 15.6 Wh (100.0%) condition: 15.6/52.8 Wh (29.6%)
volts: 12.9 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
RAM: total: 7.65 GiB used: 5.08 GiB (66.3%)
Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xB4
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1925 high: 2300 min/max: 800/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2300 2: 2300 3: 2300
4: 2300 5: 2300 6: 2300 7: 800 8: 800 bogomips: 36812
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae
pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2
xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1c8d class-ID: 0300
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD
Integrated Webcam type: USB driver: uvcvideo bus-ID: 1-5:4
chip-ID: 05c8:03bc class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x056e built: 2017 res: 1920x1080 hz: 60
dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Sound API: ALSA v: k6.1.1-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.74 TiB used: 1.78 TiB (65.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010B7E610
type: HDD rpm: 5400 serial: <filter> rev: 1A03 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Kingston model: DT 100 G2
size: 7.46 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: A-Data model: HD710 PRO
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 9501 scheme: MBR
ID-1: /run/media/manjaro/ACAHDD raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1.78 TiB (97.8%) fs: ntfs dev: /dev/sdc1 maj-min: 8:33 label: ACAHDD
uuid: E28889FC8889D009
ID-1: /dev/dm-0 maj-min: 254:0 mapped: ventoy size: 3.51 GiB fs: iso9660
ID-2: /dev/sda1 maj-min: 8:1 size: 91.41 GiB fs: ext4 label: N/A
uuid: ba195372-20ab-4956-a8c8-e98e34c1fec8
ID-3: /dev/sda2 maj-min: 8:2 size: 7.97 GiB fs: swap label: N/A
uuid: 066fae32-db45-4bee-85c6-57ea6289b068
ID-4: /dev/sda3 maj-min: 8:3 size: 606 MiB fs: vfat label: N/A
uuid: D616-FBF3
ID-5: /dev/sda4 maj-min: 8:4 size: 100 GiB fs: exfat label: N/A
uuid: E7EC-B7ED
ID-6: /dev/sda5 maj-min: 8:5 size: 100 GiB fs: exfat label: N/A
uuid: F3DF-781A
ID-7: /dev/sdb1 maj-min: 8:17 size: 7.42 GiB fs: exfat label: ARTURO_USB
uuid: 0247-1D55
ID-8: /dev/sdb2 maj-min: 8:18 size: 32 MiB fs: vfat label: VTOYEFI
uuid: 1968-9ADA
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-1:2 info: Toshiba Kingston DataTraveler 102/2.0 / HEMA Flash
Drive 2 GB PNY Attache 4GB Stick type: Mass Storage driver: usb-storage
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA chip-ID: 0930:6545
class-ID: 0806 serial: <filter>
Device-2: 1-3:3 info: [Maxxter] Optical Gaming Mouse [Xtrem]
type: Mouse,Keyboard driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 100mA chip-ID: 18f8:0f97 class-ID: 0301
Device-3: 1-5:4 info: Cheng Uei Precision Industry (Foxlink) HP Wide
Vision HD Integrated Webcam type: Video driver: uvcvideo interfaces: 2
rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 05c8:03bc class-ID: 0e02
Device-4: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Device-1: 2-2:2 info: A-DATA HD710 PRO type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 125f:a75a class-ID: 0806 serial: <filter>
System Temperatures: cpu: 49.0 C pch: 59.0 C mobo: N/A
Processes: 279 Uptime: 3h 12m wakeups: 1 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1138 libs: 310 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.24
Encontré este comando en la red para ver los dispositivos y obtengo esta salida para el lector de tarjetas:
$lspci
02:00.0 Unassigned class [ff00]: Alcor Micro AU6625 PCI-E Flash card reader controller
Que deberia hacer ahora?. De antemano muchas gracias!
