After changing to a new AX210 adapter I can no longer connect to wifi after resuming from sleep. I can still see all the usable networks but it tries and fails to establish a connection. This only happens following a suspend, it doesn’t occur after hibernation even if the session before had this issue.
journalctl -u NetworkManager | tail
Feb 10 23:47:04 ganglion-01 NetworkManager[11706]: <info> [1676044024.2254] device (wlp58s0): supplicant interface state: authenticating -> disconnected
Feb 10 23:47:04 ganglion-01 NetworkManager[11706]: <info> [1676044024.2254] device (p2p-dev-wlp58s0): supplicant management interface state: authenticating -> disconnected
Feb 10 23:47:12 ganglion-01 NetworkManager[11706]: <warn> [1676044032.7826] device (wlp58s0): Activation: (wifi) association took too long, failing activation
Feb 10 23:47:12 ganglion-01 NetworkManager[11706]: <info> [1676044032.7827] device (wlp58s0): state change: config -> failed (reason 'ssid-not-found', sys-iface-state: 'managed')
Feb 10 23:47:12 ganglion-01 NetworkManager[11706]: <info> [1676044032.7829] manager: NetworkManager state is now DISCONNECTED
Feb 10 23:47:12 ganglion-01 NetworkManager[11706]: <info> [1676044032.7848] device (wlp58s0): set-hw-addr: set MAC address to AE:D4:58:C2:87:07 (scanning)
Feb 10 23:47:12 ganglion-01 NetworkManager[11706]: <warn> [1676044032.7874] device (wlp58s0): Activation: failed for connection 'WIFINAME'
Feb 10 23:47:12 ganglion-01 NetworkManager[11706]: <info> [1676044032.7876] device (wlp58s0): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Feb 10 23:47:12 ganglion-01 NetworkManager[11706]: <info> [1676044032.8146] device (wlp58s0): supplicant interface state: disconnected -> inactive
Feb 10 23:47:12 ganglion-01 NetworkManager[11706]: <info> [1676044032.8146] device (p2p-dev-wlp58s0): supplicant management interface state: disconnected -> inactive
sudo lshw -C network
*-network
description: Wireless interface
product: Wi-Fi 6 AX210/AX211/AX411 160MHz
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:3a:00.0
logical name: wlp58s0
version: 1a
serial: f4:c8:8a:b7:12:ef
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=5.15.91-1-MANJARO firmware=66.f1c864e0.0 ty-a0-gf-a0-66.uc ip=192.168.86.111 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: irq:16 memory:dc200000-dc203fff
inxi -Fazy
Kernel: 5.15.91-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=d7737d6c-758c-4ace-933d-05aad7acbdcb rw apparmor=1
security=apparmor udev.log_priority=3 mem_sleep_default=deep
resume=UUID=d7737d6c-758c-4ace-933d-05aad7acbdcb resume_offset=15343616
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: Dell product: XPS 13 9360 v: N/A
Mobo: Dell model: 0N0TW9 v: A02 serial: <superuser required> UEFI: Dell
v: 2.21.0 date: 06/02/2022
ID-1: BAT0 charge: 32.2 Wh (53.7%) condition: 60.0/60.0 Wh (100.0%)
volts: 7.6 min: 7.6 model: SMP DELL TP1GT61 type: Li-poly serial: <filter>
status: N/A
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3151 high: 3401 min/max: 400/3400 scaling:
driver: intel_pstate governor: performance cores: 1: 2710 2: 2757 3: 3400
4: 3401 5: 3400 6: 2742 7: 3400 8: 3400 bogomips: 28808
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Microdia Integrated Webcam HD type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 0c45:670c class-ID: 0e02
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :1 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Sharp 0x1449 built: 2015 res: 1920x1080 hz: 60
dpi: 166 gamma: 1.2 size: 294x165mm (11.57x6.5") diag: 337mm (13.3")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound API: ALSA v: k5.15.91-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 3a:00.0 chip-ID: 8086:2725
class-ID: 0280
IF: wlp58s0 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-3:2
chip-ID: 8087:0032 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 232.89 GiB used: 177.71 GiB (76.3%)
model: SSD 970 EVO Plus 250GB size: 232.89 GiB block-size: physical: 512 B
rev: 2B2QEXM7 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 177.67 GiB (78.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 35.5 MiB (11.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 16 GiB used: 1.37 GiB (8.6%) priority: -2
file: /swapfile
System Temperatures: cpu: 44.0 C pch: 35.5 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 283 Uptime: 3h 56m wakeups: 4 Memory: 7.65 GiB
used: 3.25 GiB (42.5%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1755
pm: pacman pkgs: 1744 libs: 526 tools: gnome-software,pamac,yay pm: flatpak
pkgs: 11 Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.24
