Awesome August (2016) Screenshots
screenshots
#41
after messing up with removal of gnome [accidently gd too] and chroot into the installation to instll slim, enable it and reset… here is my shot ! [of the slim log in screen and my i3]
thanks for viewing :slight_smile:
#42
wow amazing…
so pretty login screen
#43
really kewl
#44
Formatted a machine for non-profit down the street.
Heres the admin[me] account desktop. Trying out a blueish look.
Icon Set = Numix-Circle + Custom Colors from “numix-folders” package
Theme = Numix-ArchBlue
Cursor = Breeze-Snow
#45
And here is the ‘user’ side for them :disappointed_relieved:
Icons = windows10-icons
Theme = gtk-theme-windows10
Cursor = xcursor-ize-vision
#46
thank you kowalski :slight_smile:
#47
thanks lizzias… :slight_smile:
#48
My 1st JWM shot [installed alongside budgie / openbox / i3 after i removed gnome] still wondering where to get the weather code for the default conky as in jwm edition ! help will be appreciable !
notice the start menu “M” thats also customized… working more to tweak more !
#49
You forgot to put that one Manjaro wallpaper that looks like the default Windows 10 one :slight_smile:
#50
Just couldnt bring myself to do it. :innocent:
#51
#52
'LLo,
At the end, with 16/9 screen, all on the left side isn’t such a bad idea ! :bulb:
#53
current grub menu bg…
#54
All on left side ! (& a little E-effect on the e-bar fly over :wink:)
#55
Hey! What plugin do you use to display window buttons?
#56
Just standart Xfce plugin with disabled text labels.
#57
Ah, so it’s not launchers it’s already opened apps. Thanks :slight_smile:
#58
There is standart launcher plugin also, I just don’t use it.
#59
Yeah, but there will be two icons of an app then (launcher + launched window). so I preffer xfce4-dockbarx-plugin but its third-party-ishizm confuses me a little bit and I would like to have a native XFCE4 dockbar.
#60
it looks like you are using the netbook edition of manjaro.
is this correct?
