autostart a script in openbox (SOLVED)
In the latest openbox, I have a script to autostart on boot, I put the executable script in the $HOME/.config/autostart but does not work, also tried to make a subfolder autostart-scripts with the script and does not work.
What is the proper way?
thanks,
This should help
See the mention of ~/.config/openbox/autostart and test it out.
Openbox cannot run scripts at boot - but it is possible at login.
Add a line to the autostart script - roughly like below - save the file - it will run at login.
nano ~/.config/openbox/autostart
~/.local/bin/myscript &
thanks!
