After using this command to boot in terminal mode I have no connection to Wifi:
systemctl set-default multi-user.target
Using nmcli command and the password to connect fails… Only nmtui succeeds to connect but I would like to be automatically. In the past it worked perfectly. Don’t know what changed.
I check the NetworkManager service and it is running and enabled. When I have a graphical environment (KDE) it connects automatically.
● NetworkManager.service - Network Manager
Loaded: loaded (/usr/lib/systemd/system/NetworkManager.service; enabled; preset: disabled)
Active: active (running) since Tue 2023-02-21 18:07:00 EET; 1min 24s ago
Docs: man:NetworkManager(8)
Main PID: 690 (NetworkManager)
Tasks: 3 (limit: 18858)
Memory: 13.4M
CPU: 108ms
CGroup: /system.slice/NetworkManager.service
└─690 /usr/bin/NetworkManager --no-daemon
Φεβ 21 18:07:04 chris-inspiron155510 NetworkManager[690]: <info> [1676995624.7634] device (wlp0s20f3): state change: need-auth -> failed (reason 'no-secrets', sys-iface-state: 'managed')
Φεβ 21 18:07:04 chris-inspiron155510 NetworkManager[690]: <info> [1676995624.7638] manager: NetworkManager state is now DISCONNECTED
Φεβ 21 18:07:04 chris-inspiron155510 NetworkManager[690]: <warn> [1676995624.7641] device (wlp0s20f3): Activation: failed for connection 'My_SSID'
Φεβ 21 18:07:04 chris-inspiron155510 NetworkManager[690]: <info> [1676995624.7643] device (wlp0s20f3): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Φεβ 21 18:07:04 chris-inspiron155510 NetworkManager[690]: <info> [1676995624.7840] device (wlp0s20f3): set-hw-addr: set MAC address to **:**:**:**:**:** (scanning)
Φεβ 21 18:07:04 chris-inspiron155510 NetworkManager[690]: <info> [1676995624.7853] device (wlp0s20f3): supplicant interface state: disconnected -> interface_disabled
Φεβ 21 18:07:04 chris-inspiron155510 NetworkManager[690]: <info> [1676995624.7853] device (p2p-dev-wlp0s20f3): supplicant management interface state: disconnected -> interface_disabled
Φεβ 21 18:07:04 chris-inspiron155510 NetworkManager[690]: <info> [1676995624.7854] manager: startup complete
Φεβ 21 18:07:04 chris-inspiron155510 NetworkManager[690]: <info> [1676995624.8084] device (wlp0s20f3): supplicant interface state: interface_disabled -> inactive
Φεβ 21 18:07:04 chris-inspiron155510 NetworkManager[690]: <info> [1676995624.8084] device (p2p-dev-wlp0s20f3): supplicant management interface state: interface_disabled -> inactive
