Automatic reboot when shutdown | HP-ProBook 470-G0
#1
Hello, I’ll try to be as clear and efficient as possible.
Problem : Every time the computer shuts down, the power lights and fan stop, then the computer automatically reboots 3 seconds after. Only way I can shut down my computer is through a hard shutdown with pressing the power button for a long time (and I’d rather avoid doing that too often).
My computer is a HP-ProBook 470-G0, here is the output of inxi -Fxxxz :
  Host: esteban-pc Kernel: 4.19.6-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 8.2.1 Desktop: Xfce 4.13.2git-UNKNOWN tk: Gtk 3.24.1 info: xfce4-panel
  wm: xfwm4 dm: LightDM 1.28.0 Distro: Manjaro Linux
  Type: Laptop System: Hewlett-Packard product: HP ProBook 470 G0
  v: A2019DD203 serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Hewlett-Packard model: 1948 v: KBC Version 90.0C serial: <filter>
  UEFI: Hewlett-Packard v: 68IRF Ver. F.04 date: 06/24/2013
  ID-1: BAT0 charge: 30.6 Wh condition: 40.4/40.4 Wh (100%) volts: 11.4/10.8
  model: Hewlett-Packard Primary type: Li-ion serial: <filter>
  status: Discharging
  Topology: Dual Core model: Intel Core i5-3230M bits: 64 type: MT MCP
  arch: Ivy Bridge rev: 9 L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20756
  Speed: 1197 MHz min/max: 1200/3200 MHz Core speeds (MHz): 1: 1197 2: 1197
  3: 1197 4: 1197
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0166
  Device-2: AMD Mars [Radeon HD 8670A/8670M/8750M] vendor: Hewlett-Packard
  driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:6600
  Display: x11 server: X.Org 1.20.3 driver: ati,intel,radeon
  unloaded: modesetting alternate: fbdev,vesa resolution: 1600x900~60Hz
  OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 4.2 Mesa 18.2.6
  compat-v: 3.0 direct render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:1e20
  Sound Server: ALSA v: k4.19.6-1-MANJARO
  Device-1: Ralink RT3290 Wireless 802.11n 1T/1R PCIe
  vendor: Hewlett-Packard driver: rt2800pci v: 2.3.0 port: 3000
  bus ID: 04:00.0 chip ID: 1814:3290
  vendor: Hewlett-Packard driver: r8168 v: 8.045.08-NAPI port: 2000
  bus ID: 05:00.0 chip ID: 10ec:8168
  IF: enp5s0 state: down mac: <filter>
  Local Storage: total: 465.76 GiB used: 205.94 GiB (44.2%)
  ID-1: /dev/sda vendor: Toshiba model: MQ01ABF050 size: 465.76 GiB
  speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 2C scheme: GPT
  ID-1: / size: 448.49 GiB used: 205.94 GiB (45.9%) fs: ext4 dev: /dev/dm-0
  ID-2: swap-1 size: 8.80 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/dm-1
  System Temperatures: cpu: 59.0 C mobo: N/A gpu: radeon temp: 54 C
  Processes: 183 Uptime: 8m Memory: 7.64 GiB used: 1.23 GiB (16.0%)
  Init: systemd v: 239 Compilers: gcc: 8.2.1 Shell: bash v: 4.4.23
  running in: xfce4-terminal inxi: 3.0.27
Based on my previous research, here is what I tried :
  • Remove any USB device or mouse plugged in before shutdown
  • Shutdown with systemctl poweroff instead of using the button
  • Disable the “Wake on LAN” option in my BIOS
  • Adding acpi=force at the end of GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub then running sudo update-grub
  • Adding acpi=noirq at the end of GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub then running sudo update-grub
I even tried completely disabling USB port in the BIOS just to check if it made any difference.
None of these made any difference.
If I can provide any more useful information I’d be glad to.
#2
It sounds like a hardware problem…
Are you dual-booting?
Have you tried to shutdown from LightDM?
#3
No, I’m not dual-booting.
What do you mean by “shutdown from LightDM” ? You mean shutdown using the GUI ? If so, I have tried that and it didn’t work.
It may be a hardware problem but there wasn’t any problem when I was using Windows 10 or Ubuntu before, no automatic reboot on shutdown. The only difference is :
  • It don’t remember if my Windows 10 was booting in UEFI or Legacy :confused:
  • Ubuntu was booting on Legacy
  • Manjaro is booting on UEFI because I couldn’t make it boot in Legacy (the first screen wouldn’t show up)
closed #4
