Out of nowhere (no recent major changes or updates on the system, at least as far as I remember pacman-mirrors threw this one:
[frog ~]# pacman-mirrors
Pacman-mirrors version 4.21.5
File "/usr/bin/pacman-mirrors", line 28, in <module>
pm.run()
File "/usr/lib/python3.9/site-packages/pacman_mirrors/pacman_mirrors.py", line 93, in run
cliFn.parse_command_line(self, gtk_available=GTK_AVAILABLE)
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/cliFn.py", line 176, in parse_command_line
exit_code = mirror_status.print_status(self)
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/mirror_status.py", line 64, in print_status
system_branch, mirrors_pacman = get_local_mirrors()
File "/usr/lib/python3.9/site-packages/pacman_mirrors/functions/mirror_status.py", line 31, in get_local_mirrors
return mirror_branch, urls
UnboundLocalError: local variable 'mirror_branch' referenced before assignment
I could get it to “behave” again by just executing pacman-mirrors --geoip.
But I think this error might be easy to fix and I would even look into it. Any points in the right direction on how to submit fixes/file bugs would be helpful. In this case I suppose it needs to be filed in archlinux/pacman right? Thanks for any hints. Manjaro/Arch newbie here
