Autofs is moved to AUR. Replacement?
Hi!
autofs is moved to AUR. I guess because there is a replacement better than autofs. Isn’t there?
The aim is to auto-mount (on appearing in LAN) and auto-unmount (on disappearing) SMB resources. And I’d want to avoid long filesystem locks on resource down.
Have you, please, got some suggestions?
Hi @student975, and welcome!
Will a Systemd sutomount unit not do the trick?
Look here for examples: [root tip] systemd mount unit samples
