Hello Together,
I was expecting that Geary could access the contacts from the Contacts application, but it doesn’t.
I ma basically on a fresh install, and wanted to check if I like the combination of Geary,Contacts and Calendar over Thunderbird.
But this would be a show stopper.
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: GNOME 3.38.3 tk: GTK 3.24.26
wm: gnome-shell dm: GDM 3.38.2.1 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASUSTeK model: P7H55D-M EVO v: Rev 1.xx serial: <filter> BIOS: American Megatrends v: 1604
date: 07/22/2010
Memory: RAM: total: 11.66 GiB used: 2.33 GiB (19.9%)
CPU: Info: Quad Core model: Intel Core i5 750 bits: 64 type: MCP arch: Nehalem rev: 5 L2 cache: 8 MiB bogomips: 21354
Speed: 1201 MHz min/max: 1200/2668 MHz boost: enabled Core speeds (MHz): 1: 1201 2: 1201 3: 1201 4: 1201
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts
ept est flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl
nx pae pat pbe pdcm pebs pge pni popcnt pse pse36 pti rdtscp rep_good sep smx ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology xtpr
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Juniper XT [Radeon HD 5770] vendor: Hightech Information System
driver: radeon v: kernel bus ID: 01:00.0 chip ID: 1002:68b8 class ID: 0300
Display: wayland server: X.org 1.20.10 compositor: gnome-shell driver: loaded: radeon
note: n/a (using device driver) - try sudo/root resolution: <missing: xdpyinfo>
OpenGL: renderer: AMD JUNIPER (DRM 2.50.0 / 5.9.16-1-MANJARO LLVM 11.1.0) v: 3.3 Mesa 20.3.4 compat-v: 3.1
direct render: Yes
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:3b56 class ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Juniper HDMI Audio [Radeon HD 5700 Series]
vendor: Hightech Information System driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 1002:aa58
class ID: 0403
Device-3: Logitech Webcam C210 type: USB driver: snd-usb-audio,uvcvideo bus ID: 4-1.6.4:5 chip ID: 046d:0819
class ID: 0102 serial: <filter>
Sound Server: ALSA v: k5.9.16-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK M4A785/P7P55 driver: r8169
v: kernel port: d800 bus ID: 02:00.0 chip ID: 10ec:8168 class ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Bluetooth: Message: No Bluetooth data was found.
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 3.7 TiB used: 16.01 GiB (0.4%)
ID-1: /dev/sda vendor: Western Digital model: WD30EURS-63SPKY0 size: 2.73 TiB speed: 3.0 Gb/s serial: <filter>
rev: 0A80 scheme: MBR
ID-2: /dev/sdb vendor: OCZ model: AGILITY3 size: 55.9 GiB speed: 3.0 Gb/s rotation: SSD serial: <filter> rev: 2.22
scheme: GPT
ID-3: /dev/sdc vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB speed: 3.0 Gb/s rotation: SSD
serial: <filter> rev: 033 scheme: MBR
ID-4: /dev/sdh type: USB vendor: SanDisk model: Cruzer Slice size: 7.45 GiB serial: <filter> rev: 1.20 scheme: MBR
Optical-1: /dev/sr0 vendor: TSSTcorp model: CDDVDW TS-H663C rev: KG01 dev-links: cdrom
Features: speed: 52 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition: ID-1: / size: 398.69 GiB used: 13 GiB (3.3%) fs: ext4 dev: /dev/sdc3 label: N/A
uuid: 68253f77-e6ec-4dd2-a023-7b1c1c17a749
ID-2: /run/media/brotsalami/MULTIBOOT size: 7.44 GiB used: 3 GiB (40.4%) fs: vfat dev: /dev/sdh1 label: MULTIBOOT
uuid: 1902-245E
ID-3: /run/timeshift/backup size: 23.39 GiB used: 24 KiB (0.0%) fs: ext4 dev: /dev/sdb3 label: N/A
uuid: 0c006769-2f15-4484-9969-beebe7b908c5
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/sda1 size: 100 MiB fs: ntfs label: System-reserviert uuid: 80CA075ECA075038
ID-2: /dev/sda2 size: 1.64 TiB fs: ntfs label: Daten uuid: AC804022803FF206
ID-3: /dev/sda3 size: 525.35 GiB fs: ntfs label: N/A uuid: DA1211BD1211A015
ID-4: /dev/sdb1 size: 27.95 GiB fs: swap label: N/A uuid: 40d48af4-7d32-400f-8fa0-4249188d3a1b
ID-5: /dev/sdb2 size: 4.01 GiB fs: vfat label: N/A uuid: 126E-FC5C
ID-6: /dev/sdc1 size: 100 MiB fs: ntfs label: System-reserviert uuid: 80CA075ECA075038
ID-7: /dev/sdc2 size: 525.35 GiB fs: ntfs label: N/A uuid: DA1211BD1211A015
ID-8: /dev/sdh4 size: 273 MiB fs: iso9660 label: 2.6.5-21-i686 uuid: 2020-03-02-14-08-30-00
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 8087:0020
class ID: 0900
Device-1: 1-1.2:3 info: Alcor Micro Flash Card Reader/Writer type: Mass Storage driver: usb-storage interfaces: 1
rev: 2.0 speed: 480 Mb/s chip ID: 058f:6362 class ID: 0806 serial: <filter>
Device-2: 1-1.4:4 info: SanDisk Cruzer Slice type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s chip ID: 0781:5566 class ID: 0806 serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003 class ID: 0900
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-6: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 8087:0020
class ID: 0900
Hub-7: 4-1.6:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 05e3:0608 class ID: 0900
Device-1: 4-1.6.2:4 info: Logitech MX510 Optical Mouse type: Mouse driver: hid-generic,usbhid interfaces: 1
rev: 2.0 speed: 1.5 Mb/s chip ID: 046d:c01d class ID: 0301
Device-2: 4-1.6.3:6 info: Novatek Micro Keyboard (Labtec Ultra Flat Keyboard) type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s chip ID: 0603:00f2 class ID: 0300
Device-3: 4-1.6.4:5 info: Logitech Webcam C210 type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4
rev: 2.0 speed: 480 Mb/s chip ID: 046d:0819 class ID: 0102 serial: <filter>
Sensors: System Temperatures: cpu: 50.0 C mobo: 29.0 C gpu: radeon temp: 61.0 C
Fan Speeds (RPM): cpu: 615 psu: 0 case-1: 969
Power: 12v: 12.32 5v: N/A 3.3v: 3.39 vbat: N/A
Info: Processes: 232 Uptime: 35m wakeups: 0 Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1418 Shell: Zsh
v: 5.8 running in: gnome-terminal inxi: 3.3.01
Thanks for any hints
brotsalami
