Pretty sure I’ve seen topics opened after that which, once solved, closed 3 hrs after the last reply, which in one case was immediately. However I haven’t been paying attention in the last few days, so .
The timer starts at the time of the last reply. IMO it should start when the thread is solved and be reset when a new reply is created.
Well it starts when the thread is marked solved, but the start value is from the last reply. So if the last reply is older than the time period, then the thread is immediately locked.
If memory serves, it happened at least once about a week ago.
Which makes perfect sense. Sometimes Quite often the original poster abandons the thread without marking a solution, even though the issue has been solved — it’s all part of the selfish/narcissistic atmosphere of the time. And then someone comes along who notices this and marks a solution, but because the thread was abandoned days earlier, it then immediately gets closed.
Threads that have not been closed are like a magnet for necro-bumpers. We regularly have to split or delete posts that are added to threads which are already months or years old, due to newbies already having discovered how to write — albeit poorly — before having learned how to read.
Ah, but not when it’s a fresh thread, the last reply is ~3hrs old, and the OP marks it solved, then immediatly tries to ask a follow up question only to find the thread is locked.
This is probably because the default timeout for those particular threads was still set to 3 hours. It all depends on when the thread was created — i.e. before or after the timer template was modified.
This is certainly true, just as some threads go on and on forever due to the original poster either being obtuse, or a help vampire, or both.
We account for the “internationality” (is this even a word?) of the forum. Between USA and Australia there are about 15-20 hours of “lost” time (in sleeping/working), so i think the minimum for everybody to have a fair chance globally is 2 days as it is now.
This is true, but there is sometimes good reason to allow additional comments.
if there are additional, relevant details which improve the resource - and sometimes comments about the solution accepted.
if there are interesting alternative solutions.
So extending the clock hopefully serves to improve the coffin and give more time for good people to polish the nails. I believe there are currently over 124,000 nails - but it’s an extremely large coffin and so there’s no need to panic just yet.
