Auto logout when using Intellij debug where should I start to fix it?
When I click debug to start or stop a process in Intellij , there is a big chance to close all current process and logout. Where should I start to fix it?
Ensure you have enabled and adequate amount of swap configured - match with your work requirements.
Lack of the above may cause OOM killer to kick your processes and log you off.
thanks I found that I have no swap partition on my pc. Already set that see if the issue occurs again.
swap already set to 5G (32G mem total) still get the issue .
Log : this time the screen struck at black background with manjaro logo. No login session came out. Struck at the stage before login session. I press ctrl alt f3 go to tty3 you can check it in the log.
I use command journalctl --since "5 min ago" to get this after I enter tty3.
A lot of info about " dbusmenu_menuitem_show_to_user " but I cant get enough infomation from google
Apr 16 13:45:24 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:25 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:26 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:28 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:29 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:31 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:34 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:35 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:36 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:37 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:38 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:39 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:40 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:41 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:42 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:43 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:45 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:46 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:47 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:48 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:49 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:50 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:51 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:52 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:53 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:54 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:55 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:56 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:57 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:57 ori i3[45663]: Already up to date.
Apr 16 13:45:57 ori i3[45668]: On branch master
Apr 16 13:45:57 ori i3[45668]: Your branch is up to date with 'origin/master'.
Apr 16 13:45:57 ori i3[45668]: nothing to commit, working tree clean
Apr 16 13:45:57 ori GitPullNote.py[45679]: Already up to date.
Apr 16 13:45:57 ori GitPullNote.py[45684]: On branch master
Apr 16 13:45:57 ori GitPullNote.py[45684]: Your branch is up to date with 'origin/master'.
Apr 16 13:45:57 ori GitPullNote.py[45684]: nothing to commit, working tree clean
Apr 16 13:45:58 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:45:58 ori i3[45675]: Everything up-to-date
Apr 16 13:45:58 ori GitPullNote.py[45691]: Everything up-to-date
Apr 16 13:46:05 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:46:06 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:46:07 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:46:08 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:46:09 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:46:10 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:46:13 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:46:14 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:47:08 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:47:09 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:47:13 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:47:24 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:47:25 ori java[18835]: dbusmenu_menuitem_show_to_user: assertion 'DBUSMENU_IS_MENUITEM(mi)' failed
Apr 16 13:48:58 ori GitPullNote.py[45995]: Already up to date.
Apr 16 13:48:58 ori GitPullNote.py[46000]: On branch master
Apr 16 13:48:58 ori GitPullNote.py[46000]: Your branch is up to date with 'origin/master'.
Apr 16 13:48:58 ori GitPullNote.py[46000]: nothing to commit, working tree clean
Apr 16 13:48:58 ori i3[46010]: Already up to date.
Apr 16 13:48:59 ori i3[46015]: On branch master
Apr 16 13:48:59 ori i3[46015]: Your branch is up to date with 'origin/master'.
Apr 16 13:48:59 ori i3[46015]: nothing to commit, working tree clean
Apr 16 13:48:59 ori GitPullNote.py[46007]: Everything up-to-date
Apr 16 13:48:59 ori i3[46022]: Everything up-to-date
Apr 16 13:49:01 ori plasmashell[1165]: org.kde.plasma.pulseaudio: No object for name "alsa_output.usb-Generic_USB_Audio-00.HiFi__hw_Audio__sink.monitor"
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/ldac
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSink/aptx_hd
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/aptx_hd
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSink/aac
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/aac
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSink/sbc
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/sbc
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSink/sbc_xq
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/sbc_xq
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/faststream
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/faststream_duplex
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSink/opus_05
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/opus_05
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Apr 16 13:49:01 ori bluetoothd[684]: Endpoint unregistered: sender=:1.181 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Apr 16 13:49:01 ori pipewire-pulse[968]: mod.protocol-pulse: client 0x5598eb36d010 [java]: ERROR command:-1 (invalid) tag:4294967295 error:25 (Input/output error)
Apr 16 13:49:01 ori plasmashell[1165]: org.kde.plasma.pulseaudio: No object for name "alsa_output.usb-Generic_USB_Audio-00.HiFi__hw_Audio__sink"
Apr 16 13:49:01 ori plasmashell[1165]: org.kde.plasma.pulseaudio: No object for name "auto_null"
Apr 16 13:49:01 ori plasmashell[1165]: org.kde.plasma.pulseaudio: No object for name "auto_null.monitor"
Apr 16 13:49:01 ori espanso[1385]: 13:49:01 [daemon(1385)] [INFO] keyboard layout change detected, restarting worker...
Apr 16 13:49:01 ori espanso[1401]: 13:49:01 [worker(1401)] [INFO] engine eventloop has terminated, propagating exit event...
Apr 16 13:49:01 ori espanso[1401]: 13:49:01 [worker(1401)] [INFO] waiting for engine exit mode...
Apr 16 13:49:10 ori systemd[1]: Started Getty on tty3.
Apr 16 13:49:10 ori kernel: fbcon: Taking over console
Apr 16 13:49:10 ori kernel: Console: switching to colour frame buffer device 240x67
Apr 16 13:49:10 ori systemd[1]: systemd-vconsole-setup.service: Deactivated successfully.
Apr 16 13:49:10 ori systemd[1]: Stopped Virtual Console Setup.
Apr 16 13:49:10 ori systemd[1]: Stopping Virtual Console Setup...
Apr 16 13:49:10 ori systemd[1]: Starting Virtual Console Setup...
Apr 16 13:49:10 ori systemd[1]: Finished Virtual Console Setup.
Apr 16 13:49:14 ori login[46048]: pam_unix(login:session): session opened for user lizhe(uid=1000) by lizhe(uid=0)
Apr 16 13:49:14 ori systemd-logind[619]: New session 3 of user lizhe.
Apr 16 13:49:14 ori systemd[1]: Started Session 3 of User lizhe.
Apr 16 13:49:14 ori login[46048]: LOGIN ON tty3 BY lizhe
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/ldac
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSink/aptx_hd
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/aptx_hd
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSink/aac
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/aac
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSink/sbc
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/sbc
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSink/sbc_xq
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/sbc_xq
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/faststream
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/faststream_duplex
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSink/opus_05
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/opus_05
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Apr 16 13:49:15 ori bluetoothd[684]: Endpoint registered: sender=:1.206 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Apr 16 13:49:27 ori systemd[1]: Started Getty on tty2.
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/ldac
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSink/aptx_hd
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/aptx_hd
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSink/aac
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/aac
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSink/sbc
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/sbc
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSink/sbc_xq
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/sbc_xq
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/faststream
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/faststream_duplex
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSink/opus_05
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/opus_05
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Apr 16 13:49:28 ori bluetoothd[684]: Endpoint unregistered: sender=:1.206 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Apr 16 13:49:31 ori espanso[1385]: 13:49:31 [daemon(1385)] [ERROR] could not restart worker, as the exit process has timed out
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/ldac
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSink/aptx_hd
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_hd
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSink/aac
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aac
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSink/sbc
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/sbc
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSink/sbc_xq
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/sbc_xq
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/faststream
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/faststream_duplex
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSink/opus_05
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/opus_05
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Apr 16 13:49:34 ori bluetoothd[684]: Endpoint registered: sender=:1.207 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Apr 16 13:49:50 ori NetworkManager[616]: <info>  [1713246590.1023] dhcp6 (wlo1): state changed new lease, address=240e:341:3148:a700:54b1:21ff:6371:2
Apr 16 13:49:50 ori systemd[1]: Starting Network Manager Script Dispatcher Service...
Apr 16 13:49:50 ori systemd[1]: Started Network Manager Script Dispatcher Service.
Apr 16 13:50:00 ori systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
I have a couple of topics the past few weeks - various issues with IntelliJ - some related to xorg-wayland.
You should be able to find them using the forum :mag:
While the community ediion is in the repo - it is still proprietary JetBrains software.
I have no idea why it misbehaves - I suggest you search their bugtracker
