is there a output if you call
hwclock -h
and
sudo systemctl status systemd-timesyncd
hwclock -h
and
Please provide the output of:
sudo cat /etc/systemd/system/hwclock-sync.service
You did not create the file.
$ sudo systemctl edit --full hwclock-sync.service
OR
$ sudo nano /etc/systemd/system/hwclock-sync.service
Then copy:
[Unit]
Description=Sync the hardware clock in BIOS
DefaultDependencies=no
Before=shutdown.target poweroff.target
[Service]
Type=oneshot
ExecStart=/usr/bin/hwclock -w
TimeoutSec=5
[Install]
WantedBy=shutdown.target
run $ sudo systemctl enable --now hwclock-sync.service
Then enable sudo timedatectl set-local-rtc true
Sorry i put hwclock-sync.service outside of system .
Now is in place.
[joe@joe-Manjaro ~]$ sudo cat /etc/systemd/system/hwclock-sync.service
[sudo] password for joe:
[Unit]
[Service]
Type=oneshot
TimeoutSec=5
[Install]
Now this should work:
And then …
[joe@joe-Manjaro ~]$ timedatectl
Local time: Δευ 2023-03-27 17:47:18 EEST
Universal time: Δευ 2023-03-27 14:47:18 UTC
RTC time: Δευ 2023-03-27 17:47:18
Time zone: Europe/Athens (EEST, +0300)
System clock synchronized: yes
NTP service: active
RTC in local TZ: yes
Warning: The system is configured to read the RTC time in the local time zone.
This mode cannot be fully supported. It will create various problems
with time zone changes and daylight saving time adjustments. The RTC
time is never updated, it relies on external facilities to maintain it.
If at all possible, use RTC in UTC by calling
'timedatectl set-local-rtc 0'.
