Hi folks, I was just running the latest update, from the GUI. It was a really long download - maybe a couple of hours - and my machine crashed at the very last minute! When it automatically restarted I just get the GRUB options screen and neither of the two offered work. They throw up the message:
error: file ‘/boot/vmlinuz-6.1-x86_64’ not found.
error: you need to load the kernel first.Press any key to continue…
So, I’ve chrooted from a live usb stick and ran the following in Terminal:
[manjaro /]# pacman-mirrors -f 5 && pacman -Syyu
::INFO => Mirror status: https://repo.manjaro.org/status.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
0.887 United_States : https://southfront.mm.fcix.net/manjaro/
1.043 United_States : https://ridgewireless.mm.fcix.net/manjaro/
0.726 United_States : https://forksystems.mm.fcix.net/manjaro/
0.836 United_States : https://nocix.mm.fcix.net/manjaro/
2.583 New_Zealand : https://mirror.2degrees.nz/manjaro/
::INFO Writing mirror list
::United_States : https://forksystems.mm.fcix.net/manjaro/stable
::United_States : https://nocix.mm.fcix.net/manjaro/stable
::United_States : https://southfront.mm.fcix.net/manjaro/stable
::United_States : https://ridgewireless.mm.fcix.net/manjaro/stable
::New_Zealand : https://mirror.2degrees.nz/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
error: failed to synchronize all databases (unable to lock database)
[manjaro /]# mhwd-kernel -li && mhwd -l -li
Currently running: 5.15.28-1-MANJARO (linux515)
error: could not open file /var/lib/pacman/local/cuda-12.2.2-1/desc: No such file or directory
* linux515
* linux61
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2023.03.23 false PCI
0000:03:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
network-r8168 2023.09.12 true PCI
0000:01:00.0 (0300:10de:1e82) Display controller nVidia Corporation:
video-nvidia-470xx 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
0000:00:02.0 (0380:8086:0162) Display controller Intel Corporation:
