Auto adjust gamma on startup
Dear people, my monitor has some weird gamma settings, so to correct them I run the following command:
xrandr --output DP-0 --mode 2560x1440 --pos 0x0 --rotate normal --gamma 1.270:1.270:1.270
yes, its only on my primary display and with this command, it works like a charm.
How can I avoid running this everytime I startup my sistem? is it possible to leave it by default or run it when the system starts?
Eddited to add some system information:
██████████████████  ████████   barclow@PC-Gabo
██████████████████  ████████   OS: Manjaro Linux x86_64
██████████████████  ████████   Host: MS-7C37 3.0
████████            ████████   Kernel: 5.13.12-1-MANJARO
████████  ████████  ████████   Uptime: 13 mins
████████  ████████  ████████   Packages: 1184 (pacman), 8 (flatpak), 8 (snap)
████████  ████████  ████████   Shell: zsh 5.8
████████  ████████  ████████   Resolution: 1920x1080, 2560x1440
████████  ████████  ████████   DE: GNOME 40.4
████████  ████████  ████████   WM: Mutter
████████  ████████  ████████   WM Theme: Adwaita-maia-compact-dark
████████  ████████  ████████   Theme: Adwaita-maia-compact-dark [GTK2/3]
████████  ████████  ████████   Icons: Papirus-Dark-Maia [GTK2/3]
                               Terminal: gnome-terminal
                               CPU: AMD Ryzen 7 3700X (16) @ 3.600GHz
                               GPU: NVIDIA GeForce RTX 3070
                               Memory: 2890MiB / 23960MiB
As you’re running Gnome, that has already been answered here:
Next time, search before posting? :pray:
:+1:
