I’ve heard that it’s possible and that there is a way for only nvidia gpu but when I try it X just fails to start and I get a black screen. The only way to fix it is to remove the X11 config form tty and reboot.
So is overclocking possible on optimus and if it is how?
Inxi -F
Host: vidakov-laptop Kernel: 5.17.15-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.24.5 Distro: Manjaro Linux
Type: Laptop System: HP product: HP Pavilion Laptop 15-eg0xxx
v: Type1ProductConfigId serial: <superuser required>
Mobo: HP model: 8850 v: 34.27 serial: <superuser required> UEFI: Insyde
v: F.11 date: 01/15/2021
ID-1: BAT0 charge: 40.2 Wh (100.0%) condition: 40.2/40.2 Wh (100.0%)
Info: quad core model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
cache: L2: 5 MiB
Speed (MHz): avg: 2604 min/max: 400/4700 cores: 1: 1296 2: 1502 3: 3632
4: 3512 5: 3018 6: 3903 7: 2374 8: 1602
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] driver: i915 v: kernel
Device-2: NVIDIA TU117M [GeForce MX450] driver: nvidia v: 515.48.07
Device-3: Luxvisions Innotech HP Wide Vision HD Camera type: USB
driver: uvcvideo
Display: x11 server: X.Org v: 21.1.3 with: Xwayland v: 22.1.2 driver: X:
loaded: modesetting,nvidia gpu: i915 resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.2
Device-1: Intel Tiger Lake-LP Smart Sound Audio
driver: sof-audio-pci-intel-tgl
Sound Server-1: ALSA v: k5.17.15-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.52 running: yes
Device-1: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8822ce
IF: wlo1 state: up mac: 64:6c:80:26:38:43
Device-1: Realtek Bluetooth Radio type: USB driver: btusb
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
Local Storage: total: 476.94 GiB used: 305.92 GiB (64.1%)
ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8H size: 476.94 GiB
ID-1: / size: 468.09 GiB used: 305.92 GiB (65.4%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) file: /swapfile
System Temperatures: cpu: 55.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 244 Uptime: 9h 42m Memory: 15.4 GiB used: 3.05 GiB (19.8%)
Shell: Zsh inxi: 3.3.19
Edit: I’m also trying to overclock the gpu with green with envy
