I recently installed Manjaro. After turning my computer on, and choosing Manjaro in the dual boot options, it fails to load with 3 messages showing up on the screen-
[Failed] Failed to launch authorization manager
[Depend] Dependency failed for modem manager
Following this, there is a completely black screen
Fixed: updated glibc
Thank you for sharing!
Could you do me a favour though and add the output of ldd --version
so that ne next person knows the minimum version to use…
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
