I am logged into Manjaro using Chrome Remote Desktop, could that be causing this issue?
Are there any other logs I can share to help debug this issue? Note that I can install and upgrade packages from the command line using sudo pamac install but nothing in the UI that requires escalation works.
This is just a wild guess, but this is what I immediately thought when I saw āā¦Remote Desktopā along with you mentioning that is works with CLI.
Iām thinking the remote client tries to authenticate against the clientās credentials, while in CLI it authenticates as per usual, with PAM.
Now I know Iām possibly, likely even wrong about this, but since it is remote, perhaps this can be confirmed or not by using something else, if only to test. Perhaps something like VNC.
@anon12891489 I donāt have a proc entry in my fstab:
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=B65A-BE5F /boot/efi vfat umask=0077 0 2
UUID=f137a55a-3150-4781-9f00-46044bfcfe2f / ext4 defaults,noatime 0 1
UUID=b9c6be8d-177b-469c-9ed3-1bce98a9bd1a swap swap defaults,noatime 0 0
UUID=F4CAFC8BCAFC4B7E /mnt/bigdrive ntfs-3g defaults,nofail 0 2
UUID=ddf5fb4a-dc87-4a8a-afe1-0c4f1cb26ca3 /mnt/raid1 ext4 defaults,nofail,noatime 0 2
I searched online and came across this question and tried to run pkexec but it failed. Iām not sure if this has anything to do with my current issue?
pkexec echo "yes" ī² 127 ā ī² 8s ļ ī² !1/2 ļ
==== AUTHENTICATING FOR org.freedesktop.policykit.exec ====
Authentication is needed to run `/usr/bin/echo' as the super user
Authenticating as: mango
Password:
polkit-agent-helper-1: error response to PolicyKit daemon: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: No session for cookie
==== AUTHENTICATION FAILED ====
Error executing command as another user: Not authorized
This incident has been reported.
@Mirdarthos Looks like you were right, it has something to do with chrome remote desktop. I donāt get this error if I login on the machine itself. It works perfectly fine. But searching online doesnāt give me anything
Yea - thatās what Iāve been doing for the past few months and it works as well as expected. Would be nice to have a gui package manager sometimes though.
Maybe. I prefer the command-line. You can actually copy and paste from there to here if you need assistance and itās much easier to write ātype thisā than tell someone āclick thatā. And they canāt find that to click on itā¦
