Everytime I start my machine I have to put again the WiFi password, because It says "the obtaining of secret keys failed to Name of my WiFi red "
And it fails too to open my google account sync through dolphin.
$ inxi --full --verbosity=7 --filter --no-host
System: Kernel: 5.11.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: KDE Plasma 5.21.2
tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Acer product: Nitro AN515-53 v: V1.28 serial: <filter>
Mobo: CFL model: Freed_CFS v: V1.28 serial: <filter> UEFI: Insyde v: 1.28 date: 08/05/2019
Battery: ID-1: BAT1 charge: 11.1 Wh condition: 30.6/48.9 Wh (62%) volts: 14.4/15.2 model: LG PABAS0241231
type: Li-ion serial: <filter> status: Discharging
Memory: RAM: total: 7.62 GiB used: 2.92 GiB (38.4%)
CPU: Info: Quad Core model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Kaby Lake note: check rev: A
L2 cache: 8 MiB bogomips: 36812
Speed: 900 MHz min/max: 800/1100 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900
7: 899 8: 900
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts
clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept
ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics: Device-1: Intel UHD Graphics 630 vendor: Acer Incorporated ALI driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:3e9b class ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Acer Incorporated ALI driver: nvidia
v: 460.56 bus ID: 01:00.0 chip ID: 10de:1c8c class ID: 0300
Device-3: Quanta HD User Facing type: USB driver: uvcvideo bus ID: 1-5:3 chip ID: 0408:a061
class ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel,nvidia
resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a348 class ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9 class ID: 0403
Sound Server: ALSA v: k5.11.2-1-MANJARO
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 6000
bus ID: 00:14.3 chip ID: 8086:a370 class ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI
driver: r8169 v: kernel port: 3000 bus ID: 07:00.1 chip ID: 10ec:8168 class ID: 0200
IF: enp7s0f1 state: down mac: <filter>
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8
bus ID: 1-14:4 chip ID: 8087:0aaa class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 1.11 TiB used: 152.5 GiB (13.5%)
ID-1: /dev/nvme0n1 vendor: Kingston model: RBUSNS8154P3256GJ1 size: 238.47 GiB speed: 15.8 Gb/s
lanes: 2 rotation: SSD serial: <filter> rev: E8FK12.3 temp: 39.9 C scheme: GPT
ID-2: /dev/sda vendor: Kingston model: SA400S37960G size: 894.25 GiB speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 61K1 scheme: GPT
Partition: ID-1: / size: 48.97 GiB used: 31.24 GiB (63.8%) fs: ext4 dev: /dev/nvme0n1p1 label: N/A
uuid: e99abc05-7c41-49d5-ad13-fff3e92bc02a
ID-2: /boot/efi size: 501 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 label: N/A
uuid: 3DD6-87A7
ID-3: /home size: 176.15 GiB used: 50.54 GiB (28.7%) fs: ext4 dev: /dev/nvme0n1p2 label: N/A
uuid: 15b1b083-41c1-4724-92b3-ae52b26ccd61
ID-4: /tera size: 879.19 GiB used: 70.73 GiB (8.0%) fs: ext4 dev: /dev/sda1 label: N/A
uuid: e8988339-f122-4565-bc8b-b1f16b09c368
Swap: ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p3
label: N/A uuid: f5cb4b57-d6d3-4c08-b595-2c4edc0c74f8
Unmounted: Message: No Unmounted partitions found.
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
class ID: 0900
Device-1: 1-1:2 info: [Maxxter] Optical gaming mouse type: Mouse,Keyboard driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 1.5 Mb/s chip ID: 18f8:0f99 class ID: 0301
Device-2: 1-5:3 info: Quanta HD User Facing type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s chip ID: 0408:a061 class ID: 0e02
Device-3: 1-14:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0aaa class ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 8 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
class ID: 0900
Sensors: System Temperatures: cpu: 55.0 C mobo: N/A
Info: Processes: 258 Uptime: 15m wakeups: 1 Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0
Packages: pacman: 1617 Shell: Zsh v: 5.8 running in: yakuake inxi: 3.3.01
$ journalctl -p2 -b -0
-- Journal begins at Thu 2021-01-21 17:59:07 -05, ends at Mon 2021-03-15 19:39:43 -05. --
mar 15 19:22:15 uwu systemd-coredump[1394]: Process 1324 (gdrive.so) of user 1000 dumped core.
Stack trace of thread 1324:
#0 0x00007f091200d044 n/a (/usr/lib/qt/plugins/kf5/kio/gdrive.so + 0x8044)
#1 0x0000000000000005 n/a (n/a + 0x0)
mar 15 19:22:17 uwu systemd-coredump[1631]: Process 1628 (gdrive.so) of user 1000 dumped core.
Stack trace of thread 1628:
#0 0x00007f9a6bfdc044 n/a (/usr/lib/qt/plugins/kf5/kio/gdrive.so + 0x8044)
mar 15 19:22:46 uwu signond[2092]: credentialsaccessmanager.cpp 478 openCredentialsSystem Failed to open secrets DB.
mar 15 19:32:59 uwu signond[6061]: credentialsaccessmanager.cpp 478 openCredentialsSystem Failed to open secrets DB.
$ journalctl -p2 -b -1
-- Journal begins at Thu 2021-01-21 17:59:07 -05, ends at Mon 2021-03-15 19:41:04 -05. --
mar 15 18:44:54 uwu signond[24474]: credentialsaccessmanager.cpp 478 openCredentialsSystem Failed to open secrets DB.
mar 15 18:52:47 uwu signond[32570]: credentialsaccessmanager.cpp 478 openCredentialsSystem Failed to open secrets DB.
mar 15 19:21:27 uwu systemd-coredump[56981]: Process 1666 (python3) of user 1000 dumped core.
Stack trace of thread 1666:
#0 0x00007f93f9466394 g_log_writer_default (libglib-2.0.so.0 + 0x5d394)
#1 0x00007f93f9463be9 g_log_structured_array (libglib-2.0.so.0 + 0x5abe9)
#2 0x00007f93f9464141 g_log_structured_standard (libglib-2.0.so.0 + 0x5b141)
#3 0x00007f93f83f8907 n/a (libgdk-3.so.0 + 0x92907)
#4 0x00007f93f8cbfaa5 _XError (libX11.so.6 + 0x43aa5)
#5 0x00007f93f8cbc6f8 n/a (libX11.so.6 + 0x406f8)
#6 0x00007f93f8cbc795 n/a (libX11.so.6 + 0x40795)
#7 0x00007f93f8cbd1ea _XEventsQueued (libX11.so.6 + 0x411ea)
#8 0x00007f93f8caea92 XPending (libX11.so.6 + 0x32a92)
#9 0x00007f93f83f4233 n/a (libgdk-3.so.0 + 0x8e233)
#10 0x00007f93f945d03f g_main_context_check (libglib-2.0.so.0 + 0x5403f)
#11 0x00007f93f94b0ab2 n/a (libglib-2.0.so.0 + 0xa7ab2)
#12 0x00007f93f945c0d3 g_main_loop_run (libglib-2.0.so.0 + 0x530d3)
#13 0x00007f93eca7677f gtk_main (libgtk-3.so.0 + 0x1df77f)
#14 0x00007f93f9389acd n/a (libffi.so.7 + 0x6acd)
#15 0x00007f93f938903a n/a (libffi.so.7 + 0x603a)
#16 0x00007f93f9598b65 n/a (_gi.cpython-39-x86_64-linux-gnu.so + 0x2ab65)
#17 0x00007f93f95975b2 n/a (_gi.cpython-39-x86_64-linux-gnu.so + 0x295b2)
#18 0x00007f93fa27198f PyObject_Call (libpython3.9.so.1.0 + 0x14b98f)
#19 0x00007f93fa2527bd _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12c7bd)
#20 0x00007f93fa24e9ad n/a (libpython3.9.so.1.0 + 0x1289ad)
#21 0x00007f93fa260b0e _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13ab0e)
#22 0x00007f93fa25451e _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12e51e)
#23 0x00007f93fa26096a _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13a96a)
#24 0x00007f93fa24fed7 _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x129ed7)
#25 0x00007f93fa24e9ad n/a (libpython3.9.so.1.0 + 0x1289ad)
#26 0x00007f93fa24e371 _PyEval_EvalCodeWithName (libpython3.9.so.1.0 + 0x128371)
#27 0x00007f93fa310f83 PyEval_EvalCode (libpython3.9.so.1.0 + 0x1eaf83)
#28 0x00007f93fa3213dd n/a (libpython3.9.so.1.0 + 0x1fb3dd)
#29 0x00007f93fa1bd536 PyRun_SimpleFileExFlags (libpython3.9.so.1.0 + 0x97536)
#30 0x00007f93fa332dba Py_RunMain (libpython3.9.so.1.0 + 0x20cdba)
#31 0x00007f93fa303fa9 Py_BytesMain (libpython3.9.so.1.0 + 0x1ddfa9)
#32 0x00007f93f9f80b25 __libc_start_main (libc.so.6 + 0x27b25)
#33 0x000055d659cc404e _start (python3.9 + 0x104e)
Stack trace of thread 1852:
#0 0x00007f93fa04d37f __poll (libc.so.6 + 0xf437f)
#1 0x00007f93f94b0baf n/a (libglib-2.0.so.0 + 0xa7baf)
#2 0x00007f93f945b3b1 g_main_context_iteration (libglib-2.0.so.0 + 0x523b1)
#3 0x00007f93f945b402 n/a (libglib-2.0.so.0 + 0x52402)
#4 0x00007f93f9489fc1 n/a (libglib-2.0.so.0 + 0x80fc1)
#5 0x00007f93f9f41299 start_thread (libpthread.so.0 + 0x9299)
#6 0x00007f93fa058053 __clone (libc.so.6 + 0xff053)
Stack trace of thread 1854:
#2 0x00007f93f945c0d3 g_main_loop_run (libglib-2.0.so.0 + 0x530d3)
#3 0x00007f93f9251d18 n/a (libgio-2.0.so.0 + 0x101d18)
Stack trace of thread 1769:
#0 0x00007f93f9f4d9ba __futex_abstimed_wait_common64 (libpthread.so.0 + 0x159ba)
#1 0x00007f93f9f47260 pthread_cond_wait@@GLIBC_2.3.2 (libpthread.so.0 + 0xf260)
#2 0x00007f93f6bafcec n/a (iris_dri.so + 0x4edcec)
#3 0x00007f93f6bae4c8 n/a (iris_dri.so + 0x4ec4c8)
#4 0x00007f93f9f41299 start_thread (libpthread.so.0 + 0x9299)
#5 0x00007f93fa058053 __clone (libc.so.6 + 0xff053)
Stack trace of thread 1768:
Stack trace of thread 1770:
Stack trace of thread 1767:
mar 15 19:21:29 uwu systemd-coredump[56982]: Process 1635 (gwe) of user 1000 dumped core.
Stack trace of thread 1635:
#0 0x00007f49313c3394 g_log_writer_default (libglib-2.0.so.0 + 0x5d394)
#1 0x00007f49313c0be9 g_log_structured_array (libglib-2.0.so.0 + 0x5abe9)
#2 0x00007f49313c1141 g_log_structured_standard (libglib-2.0.so.0 + 0x5b141)
#3 0x00007f492f9b7907 n/a (libgdk-3.so.0 + 0x92907)
#4 0x00007f4930c38aa5 _XError (libX11.so.6 + 0x43aa5)
#5 0x00007f4930c356f8 n/a (libX11.so.6 + 0x406f8)
#6 0x00007f4930c35795 n/a (libX11.so.6 + 0x40795)
#7 0x00007f4930c361ea _XEventsQueued (libX11.so.6 + 0x411ea)
#8 0x00007f4930c27a92 XPending (libX11.so.6 + 0x32a92)
#9 0x00007f492f9b3233 n/a (libgdk-3.so.0 + 0x8e233)
#10 0x00007f49313ba03f g_main_context_check (libglib-2.0.so.0 + 0x5403f)
#11 0x00007f493140dab2 n/a (libglib-2.0.so.0 + 0xa7ab2)
#12 0x00007f49313b83b1 g_main_context_iteration (libglib-2.0.so.0 + 0x523b1)
#13 0x00007f493118ae0e g_application_run (libgio-2.0.so.0 + 0xcce0e)
#14 0x00007f49315fbacd n/a (libffi.so.7 + 0x6acd)
#15 0x00007f49315fb03a n/a (libffi.so.7 + 0x603a)
#16 0x00007f49314f5b65 n/a (_gi.cpython-39-x86_64-linux-gnu.so + 0x2ab65)
#17 0x00007f49314f45b2 n/a (_gi.cpython-39-x86_64-linux-gnu.so + 0x295b2)
#18 0x00007f49322b098f PyObject_Call (libpython3.9.so.1.0 + 0x14b98f)
#19 0x00007f49322917bd _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12c7bd)
#20 0x00007f493228d9ad n/a (libpython3.9.so.1.0 + 0x1289ad)
#21 0x00007f493229fb0e _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13ab0e)
#22 0x00007f493228f10b _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12a10b)
#23 0x00007f493229f96a _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13a96a)
#24 0x00007f493229351e _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12e51e)
#25 0x00007f493228d9ad n/a (libpython3.9.so.1.0 + 0x1289ad)
#26 0x00007f493228d371 _PyEval_EvalCodeWithName (libpython3.9.so.1.0 + 0x128371)
#27 0x00007f493234ff83 PyEval_EvalCode (libpython3.9.so.1.0 + 0x1eaf83)
#28 0x00007f49323603dd n/a (libpython3.9.so.1.0 + 0x1fb3dd)
#29 0x00007f493235bc7b n/a (libpython3.9.so.1.0 + 0x1f6c7b)
#30 0x00007f49321fd20b n/a (libpython3.9.so.1.0 + 0x9820b)
#31 0x00007f49321fc5e3 PyRun_SimpleFileExFlags (libpython3.9.so.1.0 + 0x975e3)
#32 0x00007f4932371dba Py_RunMain (libpython3.9.so.1.0 + 0x20cdba)
#33 0x00007f4932342fa9 Py_BytesMain (libpython3.9.so.1.0 + 0x1ddfa9)
#34 0x00007f4931fbfb25 __libc_start_main (libc.so.6 + 0x27b25)
#35 0x000056450531604e _start (python3.9 + 0x104e)
Stack trace of thread 1940:
#0 0x00007f493208c37f __poll (libc.so.6 + 0xf437f)
#1 0x00007f493140dbaf n/a (libglib-2.0.so.0 + 0xa7baf)
#2 0x00007f49313b90d3 g_main_loop_run (libglib-2.0.so.0 + 0x530d3)
#3 0x00007f49311bfd18 n/a (libgio-2.0.so.0 + 0x101d18)
#4 0x00007f49313e6fc1 n/a (libglib-2.0.so.0 + 0x80fc1)
#5 0x00007f4931f80299 start_thread (libpthread.so.0 + 0x9299)
#6 0x00007f4932097053 __clone (libc.so.6 + 0xff053)
Stack trace of thread 2237:
#1 0x00007f4924459654 n/a (libpulse.so.0 + 0x33654)
#2 0x00007f49244429a9 pa_mainloop_poll (libpulse.so.0 + 0x1c9a9)
#3 0x00007f492444d281 pa_mainloop_iterate (libpulse.so.0 + 0x27281)
#4 0x00007f492444d331 pa_mainloop_run (libpulse.so.0 + 0x27331)
#5 0x00007f492445d7fe n/a (libpulse.so.0 + 0x377fe)
#6 0x00007f49241e55fc n/a (libpulsecommon-14.2.so + 0x565fc)
#7 0x00007f4931f80299 start_thread (libpthread.so.0 + 0x9299)
#8 0x00007f4932097053 __clone (libc.so.6 + 0xff053)
Stack trace of thread 2243:
#0 0x00007f4931f8c9ba __futex_abstimed_wait_common64 (libpthread.so.0 + 0x159ba)
#1 0x00007f4931f88d33 __new_sem_wait_slow64.constprop.0 (libpthread.so.0 + 0x11d33)
#2 0x00007f4932273cb0 PyThread_acquire_lock_timed (libpython3.9.so.1.0 + 0x10ecb0)
#3 0x00007f4932355ee1 n/a (libpython3.9.so.1.0 + 0x1f0ee1)
#4 0x00007f4932355adb n/a (libpython3.9.so.1.0 + 0x1f0adb)
#5 0x00007f49322a18c7 n/a (libpython3.9.so.1.0 + 0x13c8c7)
#6 0x00007f493228f10b _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12a10b)
#7 0x00007f493228d9ad n/a (libpython3.9.so.1.0 + 0x1289ad)
#8 0x00007f493229fb0e _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13ab0e)
#9 0x00007f493228f10b _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12a10b)
#10 0x00007f493228d9ad n/a (libpython3.9.so.1.0 + 0x1289ad)
#11 0x00007f493229fb0e _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13ab0e)
#12 0x00007f493228f10b _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12a10b)
#13 0x00007f493228e1cf n/a (libpython3.9.so.1.0 + 0x1291cf)
#14 0x00007f493229fb0e _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13ab0e)
#15 0x00007f49322917bd _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12c7bd)
#16 0x00007f493229f96a _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13a96a)
#17 0x00007f493228f10b _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12a10b)
#18 0x00007f493229f96a _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13a96a)
#20 0x00007f493229f96a _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13a96a)
#21 0x00007f493228f10b _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12a10b)
#22 0x00007f493229f96a _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13a96a)
#23 0x00007f493228f10b _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12a10b)
#24 0x00007f493229f96a _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13a96a)
#25 0x00007f49322b01c4 n/a (libpython3.9.so.1.0 + 0x14b1c4)
#26 0x00007f493239eb86 n/a (libpython3.9.so.1.0 + 0x239b86)
#27 0x00007f493237a5e4 n/a (libpython3.9.so.1.0 + 0x2155e4)
#28 0x00007f4931f80299 start_thread (libpthread.so.0 + 0x9299)
#29 0x00007f4932097053 __clone (libc.so.6 + 0xff053)
Stack trace of thread 1936:
#2 0x00007f49313b83b1 g_main_context_iteration (libglib-2.0.so.0 + 0x523b1)
#3 0x00007f49313b8402 n/a (libglib-2.0.so.0 + 0x52402)
Stack trace of thread 2242:
#1 0x00007f4931f88b98 __new_sem_wait_slow64.constprop.0 (libpthread.so.0 + 0x11b98)
#2 0x00007f4932273bec PyThread_acquire_lock_timed (libpython3.9.so.1.0 + 0x10ebec)
#3 0x00007f492fec6263 n/a (_queue.cpython-39-x86_64-linux-gnu.so + 0x2263)
#4 0x00007f492fec6437 n/a (_queue.cpython-39-x86_64-linux-gnu.so + 0x2437)
#5 0x00007f493229697b n/a (libpython3.9.so.1.0 + 0x13197b)
#6 0x00007f493228fc9a _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12ac9a)
#7 0x00007f493229f96a _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13a96a)
#8 0x00007f49322917bd _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12c7bd)
#9 0x00007f493229f96a _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13a96a)
#10 0x00007f493228f10b _PyEval_EvalFrameDefault (libpython3.9.so.1.0 + 0x12a10b)
#11 0x00007f493229f96a _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13a96a)
#13 0x00007f493229f96a _PyFunction_Vectorcall (libpython3.9.so.1.0 + 0x13a96a)
#14 0x00007f49322b01c4 n/a (libpython3.9.so.1.0 + 0x14b1c4)
#15 0x00007f493239eb86 n/a (libpython3.9.so.1.0 + 0x239b86)
#16 0x00007f493237a5e4 n/a (libpython3.9.so.1.0 + 0x2155e4)
#17 0x00007f4931f80299 start_thread (libpthread.so.0 + 0x9299)
#18 0x00007f4932097053 __clone (libc.so.6 + 0xff053)
mar 15 19:21:37 uwu signond[32570]: Challenge produces CRASH!
mar 15 19:21:37 uwu signond[32570]: signonsessioncore.cpp 397 replyError Deprecated error code: 2
mar 15 19:21:42 uwu kernel: watchdog: watchdog0: watchdog did not stop!
