I have been having problems starting Manjaro and had to disable Coolercontrol.
After I could boot into the OS again I activated the coolercontrol service again but starting the app I have mentioned that it did not show the watercooler anymore.
So I tried to update but first I checked the packages:
yay -Sua ✔
:: Searching AUR for updates...
-> Packages not in AUR: khotkeys
-> spectre-meltdown-checker: local (0.46+23+g0f2edb1-1) is newer than AUR (0.46-1)
:: 13 dependencies will also be installed for this operation.
extra/appstream-glib -> 0.8.3-2
extra/cmake -> 4.0.3-1
(make dependency of coolercontrol)
extra/doxygen -> 1.14.0-1
(make dependency of kemoticons)
extra/extra-cmake-modules -> 6.15.0-1
(make dependency of kemoticons, kdelibs4support, ...)
extra/meson -> 1.8.2-2
(make dependency of protonplus)
extra/nodejs -> 24.2.0-1
(make dependency of coolercontrold)
extra/npm -> 11.4.2-1
extra/qt5-doc -> 5.15.17-1
extra/vala -> 0.56.18-4
multilib/lib32-openssl-1.1 -> 1.1.1.w-2
multilib/lib32-vkd3d -> 1.14-1
aur/coolercontrold -> 2.2.1-1
aur/kdesignerplugin -> 5.116.0-2
(make dependency of kdelibs4support)
:: 6 packages to upgrade/install.
6 aur/coolercontrol 1.3.0-1 -> 2.2.1-1
5 aur/kdelibs4support 5.116.0-1 -> 5.116.0-2
4 aur/kemoticons 5.116.0-1 -> 5.116.0-2
3 aur/proton-ge-custom-bin 1:GE_Proton7_29-1 -> 1:GE_Proton10_8-1
2 aur/protonplus 0.4.27-2 -> 0.5.8-1
1 aur/pulseaudio-ctl 1.70-1 -> 1.70-2
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
-> Excluding packages may cause partial upgrades and break systems
So I tried to update them, with no success:
yay -Syu --aur 1 ✘ 60s
(make dependency of kdelibs4support, kdesignerplugin, ...)
AUR Explicit (4): protonplus-0.5.8-1, pulseaudio-ctl-1.70-2, coolercontrol-2.2.1-1, proton-ge-custom-bin-1:GE_Proton10_8-1
AUR Dependency (3): kdelibs4support-5.116.0-2, kemoticons-5.116.0-2, coolercontrold-2.2.1-1
AUR Make Dependency (1): kdesignerplugin-5.116.0-2
Sync Check Dependency (1): appstream-glib-0.8.3-2
Sync Dependency (2): lib32-vkd3d-1.14-1, lib32-openssl-1.1-1.1.1.w-2
Sync Make Dependency (8): cmake-4.0.3-1, vala-0.56.18-4, meson-1.8.2-2, npm-11.4.2-1, doxygen-1.14.0-1, qt5-doc-5.15.17-1, nodejs-24.2.0-1, extra-cmake-modules-6.15.0-1
:: PKGBUILD up to date, skipping download: kdelibs4support
:: PKGBUILD up to date, skipping download: protonplus
:: PKGBUILD up to date, skipping download: pulseaudio-ctl
:: PKGBUILD up to date, skipping download: kdesignerplugin
:: PKGBUILD up to date, skipping download: kemoticons
:: PKGBUILD up to date, skipping download: coolercontrold
:: (0/2) Failed to download PKGBUILD: proton-ge-custom-bin
:: (0/2) Failed to download PKGBUILD: coolercontrol
-> error fetching proton-ge-custom-bin: fatal: not a git repository (or any of the parent directories): .git
context: exit status 128
error fetching coolercontrol: fatal: not a git repository (or any of the parent directories): .git
Since everything I found told to install it with yay I was flabbergasted as to why the update did not work.
Then I found an article that said uninstall via pacman and reinstall via yay.
I did that with the same result
Now I am not just unable to update it, I uninstalled it and cannot get it back not knowing why because everywhere it says to install it like that.
e.g.:
Then I looked at this coolercontrol-liqctld · main · CoolerControl / CoolerControl · GitLab (so apparently it is a git repository thus no clue why the error says otherwise) and none of those commands work, they all seem to miss some rule but which I dont know.
Thats the part about Linux I dont get. You find a site that is giving command suggestions but they are not complete.
Does someone know how I can get coolercontrol back on my Manjaro? The pump of the watercooler is much more silent in idle, when it is installed.
It also would be useful to have an updated proton-ge-custom-bin because I can use that for gaming with and without Steam.
