Kernel: 6.1.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1 Desktop: GNOME v: 43.5
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05 serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <superuser required>
UEFI-[Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
ID-1: BAT0 charge: 42.4 Wh (100.0%) condition: 42.4/60.0 Wh (70.7%) volts: 17.1 min: 15.4
model: Celxpert L19C4PC0 status: full
Info: 8-core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 8 MiB
Speed (MHz): avg: 1533 high: 3528 min/max: 1400/2900 boost: enabled cores: 1: 1400 2: 3528
3: 1400 4: 1400 5: 1400 6: 1400 7: 1400 8: 1400 9: 1397 10: 1397 11: 1400 12: 1400 13: 1397
14: 1396 15: 1417 16: 1397 bogomips: 92668
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia v: 530.41.03
arch: Turing bus-ID: 01:00.0
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 bus-ID: 05:00.0
temp: 42.0 C
Device-3: Chicony Integrated Camera driver: uvcvideo type: USB bus-ID: 1-3:2
Display: x11 server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1 driver: X:
loaded: amdgpu,nvidia dri: radeonsi gpu: amdgpu resolution: 1920x1080~120Hz
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 05:00.6
API: ALSA v: k6.1.26-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.70 status: active
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: 2000 bus-ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 04:00.0
IF: wlp4s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth driver: btusb v: 0.8 type: USB bus-ID: 3-3:3
Local Storage: total: 476.94 GiB used: 340.33 GiB (71.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB temp: 40.9 C
ID-1: / size: 459.72 GiB used: 340.33 GiB (74.0%) fs: ext4 dev: /dev/nvme0n1p1
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) dev: /dev/nvme0n1p2
System Temperatures: cpu: 57.1 C mobo: N/A gpu: amdgpu temp: 42.0 C
Processes: 360 Uptime: 7m Memory: available: 15 GiB used: 3.21 GiB (21.4%) Init: systemd
Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1697 Client: gnome-shell v: 43.5 inxi: 3.3.27
The brightness slider doesn’t change the brightness. Even on the Fn keys it doesn’t work. The slider just moves without changing the brightness. I’ve tried three kernels, 6.1, 6.2 and 6.3.
