Hi all,
when i installed some updates and virtualbox via pamac i did a killall to pamac. after that i get the error message when i do sudo pacman -Syu:
i googled and found some suggestions on how to fix it but nothing worked for me:
https://wiki.manjaro.org/index.php?title=Pacman_troubleshooting#Errors_about_Keys
https://wiki.manjaro.org/index.php?title=Pacman_troubleshooting#.22GPGME_error:_No_data.22_Error
does anyone has an idea?
thank you!
Search more and you will find
thank you! the error messages after GPGME error messages are gone now.
But when I try to install virtualbox with:
sudo pacman -Syu virtualbox
I still get an error regarding a pgp-signature that is damaged:
it asks me to remove the invalid files and then cancels the installation:
Help is very much appreciated…
try this:
sudo pacman -S manjaro-keyring
sudo pacman -Syyu
this will update the new keys and disable the revoked keys
Great. I think it worked. Thank you. I followed all the (additional) steps again from here: Pacman troubleshooting - Manjaro
system
Closed
6
