Good day I’m using a thinkpad x1 9 generation. After looking everywhere I just can’t find any solution to this issue even after I have reconfigured Alsamixer…
Here is the issue My volume has to be 100% all the time to listen video on youtube some video are super loud some are absolutely low as hell. I’m going to compare this to Windows never had an issue before seem like its proper to manjaro kde. Now I know we can raise the volume on the laptop to 150% but some say that is not good at all for the speakers is this true? I’m the only one with this issue of low volume on thinkpad? the application volume are set to the max too… everything is pretty much looking good and still I’m having a lot of issue to hear anything… Thanks legends!
Welcome to Manjaro forum
On KDE there may be an audio issue with sound servers PulseAudio and Pipewire running concurrently
Please post response to this command to show system information
inxi -Fazy
But an issue with the volume control or loss of audio output might be due to the audio codec not being detected correctly in ALSA
Please post response to this command to show ALSA information
sudo alsa-info.sh --upload
good day thanks for the answer! First inxi -Fazy
Kernel: 5.12.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=4440475e-cd69-41c5-bc80-1ac1e577813f rw quiet apparmor=1
security=apparmor resume=UUID=bd55c49b-70a1-42f2-9d5f-9e3909eea15a
udev.log_priority=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20XWCTO1WW v: ThinkPad X1 Carbon Gen 9
serial: Chassis: type: 10 serial:
Mobo: LENOVO model: 20XWCTO1WW v: SDK0J40709 WIN serial:
UEFI: LENOVO v: N32ET47W (1.23 ) date: 03/26/2021
ID-1: BAT0 charge: 55.9 Wh (94.7%) condition: 59.0/57.0 Wh (103.4%)
volts: 17.1 min: 15.4 model: SMP 5B10W13973 type: Li-poly serial:
status: Discharging cycles: 8
Info: Quad Core model: 11th Gen Intel Core i7-1165G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 8C (140) stepping: 1 microcode: 78
cache: L2: 12 MiB
bogomips: 44864
Speed: 1257 MHz min/max: 400/4700 MHz Core speeds (MHz): 1: 1257 2: 1098
3: 716 4: 1288 5: 1131 6: 964 7: 1171 8: 1122
Device-1: Intel Iris Xe Graphics vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 3-4:3
chip-ID: 174f:2455 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,intel,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.0x12.5")
s-diag: 599mm (23.6")
Monitor-1: eDP-1 res: 1920x1200 hz: 60 dpi: 162 size: 301x188mm (11.9x7.4")
diag: 355mm (14")
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 21.0.3
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.12.2-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.28 running: no
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel port: 3000
bus-ID: 00:14.3 chip-ID: 8086:a0f0 class-ID: 0280
IF: wlp0s20f3 state: up mac:
Local Storage: total: 476.94 GiB used: 26.23 GiB (5.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X081N
lanes: 4 rotation: SSD serial: rev: 41710C20 scheme: GPT
ID-1: / raw-size: 459.74 GiB size: 451.46 GiB (98.20%)
used: 26.23 GiB (5.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 16.9 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 38.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 240 Uptime: 5m wakeups: 161 Memory: 15.36 GiB
used: 2.49 GiB (16.2%) Init: systemd v: 247 tool: systemctl Compilers:
gcc: 10.2.0 Packages: 1227 pacman: 1219 lib: 328 flatpak: 0 snap: 8
Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
Second with Alsa
cat: ‘/sys/module/snd_soc_skl_hda_dsp/parameters/*’: No such file or directory
Uploading information to www.alsa-project.org … Done!
Your ALSA information is located at http://alsa-project.org/db/?f=2f7a68da6b8b5ee4b3267826ded9da4c83f1fe8a
Please inform the person helping you.
Hope this help thanks you!
