Hello,
i switched to the newest kernel and got an issue with audio/video. audio and video (for example youtube-videos) lag of a big gap and aren’t synchronized anymore. yes some may say okay switch back to an older kernel but i want to figure out what might cause this trouble. i think it’s because it’s the pulseaudi-pipewire-issue and hope that some members can advice how to detect the issue.
btw. there are several advices at internet and here in the forums how to install pipewire and uninstall pulseaudio, but times have changed so it seems some of them are already outdated. may someone give me a link or advice how to uninstall pulseaudio and replace it complete with pipewire with the actual procedure ?
my basic inxi:
Kernel: 5.19.1-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=b8ddf48f-df06-4600-91b1-746ba323dc6b rw quiet audit=0
usbcore.autosuspend=-1 psmouse.synaptics_intertouch=1 nmi_watchdog=0
intel_pstate=disable optimus-manager.startup=nvidia nvidia_drm.modeset=1
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Acer product: Predator PH317-52 v: V1.19
serial: <superuser required>
Mobo: CFL model: Sienna_CFS v: V1.19 serial: <superuser required>
UEFI: Insyde v: 1.19 date: 07/13/2018
ID-1: BAT1 charge: 42.9 Wh (100.0%) condition: 42.9/48.9 Wh (87.6%)
volts: 16.4 min: 15.2 model: LG PABAS0241231 type: Li-ion serial: <filter>
status: full
Device-1: hid-44:2a:60:e1:2d:d0-battery model: Apple Wireless Keyboard
serial: N/A charge: N/A status: discharging
Device-2: hid-58:1f:aa:ec:10:cf-battery model: Siegberts Maus serial: N/A
RAM: total: 31.2 GiB used: 13.84 GiB (44.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-8300H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xA (10) microcode: 0xF0
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 2300 min/max: 800/2301 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 2300 2: 2300 3: 2300
4: 2300 5: 2300 6: 2300 7: 2300 8: 2300 bogomips: 36812
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Acer
Incorporated ALI driver: i915 v: kernel arch: Gen-9.5 process: Intel 14nm
built: 2016-20 ports: active: none off: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: Acer
Incorporated ALI driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm
non-free: 515.xx+ status: current (as of 2022-07) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-1 empty: none bus-ID: 01:00.0
chip-ID: 10de:1c8c class-ID: 0300
Device-3: Realtek HD WebCam type: USB driver: uvcvideo bus-ID: 1-5:3
chip-ID: 0bda:5621 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1440 s-dpi: 161 s-size: 404x227mm (15.91x8.94")
s-diag: 463mm (18.24")
Monitor-1: HDMI-A-1 mapped: HDMI-0 note: disabled pos: primary
model: BenQ EL2870U serial: <filter> built: 2018 res: 2560x1440 hz: 60
dpi: 105 gamma: 1.2 size: 621x341mm (24.45x13.43") diag: 708mm (27.9")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: eDP-1 mapped: eDP-1-1 note: disabled model: ChiMei InnoLux
0x1738 built: 2014 res: 2560x1440 dpi: 128 gamma: 1.2
size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9
modes: 1920x1080
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Acer Incorporated
ALI driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.19.1-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Cannon Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:a370 class-ID: 0280
IF: oth_3 state: down mac: <filter>
vendor: Acer Incorporated ALI driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.1 chip-ID: 10ec:8168
class-ID: 0200
IF: oth_1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
bus-ID: 1-1.7:9 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: oth_2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Message: Output throttled. IPs: 3; Limit: 10; Override: --limit [1-x;-1
all]
driver: btusb v: 0.8 bus-ID: 1-1.5.2:10 chip-ID: 0a12:0001 class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 2.1
lmp-v: 4.0 sub-v: 22bb hci-v: 4.0 rev: 22bb
Info: acl-mtu: 310:10 sco-mtu: 64:8 link-policy: rswitch hold sniff park
link-mode: peripheral accept service-classes: rendering, capturing, object
transfer, audio, telephony
Device-2: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: N/A bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e000
Local Storage: total: 476.94 GiB used: 47.91 GiB (10.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 PRO 512GB
lanes: 4 type: SSD serial: <filter> rev: 1B2QEXP7 temp: 49.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 47.91 GiB
(10.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: b8ddf48f-df06-4600-91b1-746ba323dc6b
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB
(0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
uuid: 3A58-37BB
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-1:2 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 1a40:0201 class-ID: 0900
Device-1: 1-1.3:4 info: Prolific PL2305 Parallel Port type: Printer
driver: usblp interfaces: 1 rev: 1.0 speed: 12 Mb/s power: 100mA
chip-ID: 067b:2305 class-ID: 0701
Hub-3: 1-1.5:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0605 class-ID: 0900
Device-1: 1-1.5.1:8 info: Microsoft Nano Transceiver v1.0 for Bluetooth
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 045e:0745 class-ID: 0300
Device-2: 1-1.5.2:10 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
mode) type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Device-3: 1-1.5.3:11 info: Prolific PL2303 Serial Port / Mobile Action
MA-8910P type: <vendor specific> driver: pl2303 interfaces: 1 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 067b:2303 class-ID: 0000
Device-4: 1-1.6:7 info: Logitech Cordless Mouse+Keyboard Receiver
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 98mA chip-ID: 046d:c505 class-ID: 0301
Device-5: 1-1.7:9 info: ASIX AX88179 Gigabit Ethernet type: Network
driver: ax88179_178a interfaces: 1 rev: 2.1 speed: 480 Mb/s power: 248mA
Device-6: 1-5:3 info: Realtek HD WebCam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:5621
Device-7: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: N/A rev: 2.0 speed: 12 Mb/s chip-ID: 8087:0aaa
class-ID: e000
Hub-4: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 58.0 C pch: 65.0 C mobo: N/A gpu: nvidia
temp: 55 C
Processes: 273 Uptime: 44m wakeups: 4 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: pacman: 1566 lib: 366 flatpak: 0 Shell: Bash v: 5.1.16
running-in: konsole inxi: 3.3.20
